scrdel Blaumann
Joined: 01/22/2006 Posts: 127 Karma: +4 / -2 Location: im Norden 2002 Volkswagen Passat Free account, no CAN development support
26-07-2015, 15:41 Subject: Oil Change: How to Check & Understand. |
Hi, is there a way for me to find out if the dealer actually performed the oil change they promised?
The service interval has been reset and now displays 29,000 km or 700 days until the next service.
2.0 TDI, 103 kW.
Thank you.
Sven.
Translated on 28-08-2026, 7:30.
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
26-07-2015, 19:55 Subject: Oil Change: How to Check & Understand. |
Yes, it is possible, and it can be done through an oil analysis. You don't know how long the old oil has been in the engine, or what condition it's in. As is well known, the fresh oil is immediately mixed with the remaining oil, so it becomes black right away.
If you lack trust in the dealer, I would change the oil myself...  it's possible that he might have put some cheap, low-quality oil in.
Translated on 28-08-2026, 7:34.
26-07-2015, 22:00 Subject: Oil Change: How to Check & Understand. |
Right, only an oil analysis would provide any information. However, I don't think it's really worthwhile, as it would cost at least 50% of the price of an oil change.
Therefore, my advice is: if there is any doubt, switch.
Translated on 28-08-2026, 7:35.
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
27-07-2015, 6:02 Subject: Oil Change: How to Check & Understand. |
"We can only agree with what has been said before. A very vague possibility, if available, would be to check the production date of the oil filter on the top. If this date is after the second-to-last oil change, you would have some increased certainty. However, like the previous speakers, I would recommend changing it again, because if you already have doubts, it might also be a question of oil quality."
Translated on 28-08-2026, 7:36.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
27-07-2015, 7:26 Subject: Oil Change: How to Check & Understand. |
Why so complicated?
Just take a look at the oil filter or the oil filter housing. Or the drain plug. Can you see any oil residue anywhere? Any oil splatters? Or, conversely, does it look like someone might have cleaned something there recently?
Aside from the fact that an oil change costs a dealer almost nothing... unless there's already a really bad atmosphere, why would a dealer try to rip you off over a small amount?
vwSchrauber Profi-Schrauber
27-07-2015, 8:28 Subject: Oil Change: How to Check & Understand. |
Quote: | Just take a look at the oil filter or the oil filter housing. Or the drain plug. Can you see any oil residue anywhere? Oil splatters? Or, conversely, does it look like something might have been cleaned there recently?
Quote: | | A very vague possibility, if available, would be to check the production date of the oil filter on the top side... If this date is after the second-to-last oil change, you would have some increased certainty | .
Get the oil filter from the exact same dealer and compare the manufacturers (Mann, Mahle, Knecht, Bosch, etc.).
It would be very unlikely that he would receive either of the items from his supplier.
Quote: | | Aside from the fact that an oil change costs a dealer almost nothing... unless there's already a really bad atmosphere, why would the dealer try to rip you off over a small amount? |
Because he's a greedy jerk? I know of a case where, in the past, the old oil filter would be meticulously polished with rags and rust remover to make it look like it had been replaced. This was a dealer with an official brand dealership (!).
Translated on 28-08-2026, 7:38.
scrdel Blaumann
Profile PM Garage |
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
01-08-2015, 17:51 Subject: Oil Change: How to Check & Understand. |
Thank you! Based on their "level of wisdom," I would say they haven't been here for very long.
Of course, without any guarantee.
Translated on 28-08-2026, 7:41.
Profile PM WWW Garage |
