Climate control not cooling, error memory cleared
Go to page: 1, 2  Next
Glatze
Post16-09-2017, 18:29    Subject: Climate control not cooling, error memory cleared Quote
Hello.
The air conditioning hasn't been working since yesterday.
The pipes from the air conditioning unit remain cold, and I don't hear the compressor kicking on.
The climate control system hasn't been serviced in the last 3 years.
Audi A6 4F, manufactured in 2009, 2.7 TDI engine.
How can I check if the compressor is faulty or if there is too little refrigerant?
Surely there should be an error message appearing, right?
 File size:  120.53 KB
 Viewed:  8451 times
Translated on 17-07-2026, 22:59.
Karma: +807 / -0   Thank you, like it!
Post16-09-2017, 21:21    Subject: Climate control not cooling, error memory cleared Quote
By clicking on the label file displayed in the top left corner, you can view and check the compressor's shut-off conditions.
According to your Screenshot, there is pressure, but is the compressor shaft actually rotating?
Translated on 17-07-2026, 23:00.
vag-driver
dieselschrauber likes this.
Post17-09-2017, 9:58    Subject: Re: Air conditioning not cooling, error memory cleared Quote
You can only check the refrigerant level with a climate control service device. The air conditioning system is only very superficially monitored via the OBD (On-Board Diagnostics) system. I wouldn't place too much importance on any error messages that might appear there.
Your compressor will be of a newer design. Therefore, you should first check if the driven disc is still being engaged by the shaft.
Otherwise, you can look at pictures in my old post to see what the disc looks like when the rivets are sheared off.
Andreas
Translated on 17-07-2026, 23:01.
Glatze
Post19-09-2017, 16:54    Subject: Climate control not cooling, error memory cleared Quote
Okay, thank you. From above, it's hard to tell whether the wave is rotating.
I have to go on stage first.
I was connected to the car with VCDS again.
Adjusting values while switching on.
Besides the pressure, which can range from 2.6 to 29 bar.
Please see the attachment.
The pressure gauge occasionally drops to 4 bar when the engine is idling.
 File size:  59.27 KB
 Viewed:  5250 times
 File size:  67.33 KB
 Viewed:  4431 times
Translated on 17-07-2026, 23:03.
dieselschrauber and DieselBär30x likes this.
Post19-09-2017, 17:12    Subject: Climate control not cooling, error memory cleared Quote
The refrigerant pressure seems too low with the system turned off.
I would first make sure the correct amount of filling is used before continuing the search.
Translated on 17-07-2026, 23:05.
Glatze
Post19-09-2017, 18:24    Subject: Climate control not cooling, error memory cleared Quote
Hello.
ok danke
I'll do that sometime.
Glatze
Post22-09-2017, 15:03    Subject: Hello Quote
Hello.
Okay, so I got an update. There was only 45 grams of refrigerant left, so we topped it up, and now we're going to see if there's a leak anywhere.
According to the workshop, too much had been removed.
Translated on 17-07-2026, 23:06.
vag-driver
Post22-09-2017, 15:16    Subject: Subject: Hello Quote
Glatze wrote:
Hello.
Okay, so here's the update. There was only 45 grams of refrigerant left, so we topped it up, and now we're going to see if there's a leak anywhere.
best regards
Up to 100g per year is acceptable. If you know when the air conditioning system was last serviced, you can calculate whether the refrigerant loss falls within that range based on the amount missing.
Hopefully, contrast agent was used so that you can quickly locate any leaks if there are any.
Andreas
Translated on 17-07-2026, 23:07.
Post22-09-2017, 20:51    Subject: Climate control not cooling, error memory cleared Quote
So, there was only 45g of refrigerant left, we topped it up, and now we'll see if it has any leaks anywhere.
Don't hit me for this... but the current pressure readings when the compressor is on or off might be interesting as a clue.
Given the current outdoor temperatures, I estimate the pressure to be around 8 bar with the compressor switched off, and >15 bar with the compressor switched on.
Translated on 17-07-2026, 23:09.
Karma: +649 / -0   Thank you, like it!
Post23-09-2017, 11:52    Subject: Climate control not cooling, error memory cleared Quote
It sounds like that was a poorly run operation. They filled the system with refrigerant first and then tried to find leaks afterward. Before filling, you should always check for leaks using nitrogen (with 25 bar of overpressure) and a small amount of refrigerant with soapy water, or an electronic leak detector. Alternatively, you can also add a dye and use a UV lamp to locate any leaks.
Translated on 17-07-2026, 23:10.
Glatze
Post23-09-2017, 12:40    Subject: Climate control not cooling, error memory cleared Quote
Hello.
Just so you know, I've had the car for 4 years, and I haven't had any AC service done on it. I don't think the previous owner did either.
Contrast agent was also added to the mixture.
Of course, I immediately checked and documented the pressures.
The outside temperature was 17°C.
 File size:  56.79 KB
 Viewed:  846 times
 File size:  58.54 KB
 Viewed:  895 times
Translated on 17-07-2026, 23:11.
Glatze
Post13-02-2018, 12:21    Subject: Climate control not cooling, error memory cleared Quote
Hello.
The climate control is not working again; there's an issue with the data in the non-volatile memory (FS-memory).
00256 - Sensor for refrigerant pressure/temperature (G395).
004 - No signal/communication.
Environmental conditions:
Error status: 01100100
Error priority: 3
Error frequency: 1.
Lost Count: 48
Mileage: 274,900 km
Time: 0.
Date: 2018.02.08
Time: 08:40:48
According to measurement block 51, the pressure is 51 bar.
Is the sensor defective?
Translated on 17-07-2026, 23:13.
Post13-02-2018, 13:15    Subject: Climate control not cooling, error memory cleared Quote
Glatze wrote:
Hello.
Error priority: 3
Error frequency: 1.
Lost Count: 48
Mileage: 274,900 km
Time: 0.
Date: 2018.02.08
Time: 08:40:48
Defective sender or its wiring. Warning: The air conditioning compressor will never turn on below ~5°C. icon_idea.gif
See also:
Translated on 17-07-2026, 23:16.
Glatze
Post13-02-2018, 14:08    Subject: Climate control not cooling, error memory cleared Quote
Hello.
ok danke
With a temperature of 5°C, it is known that...
I will double-check it and, if necessary, replace the sensor.
Translated on 17-07-2026, 23:18.
dieselfreak89
Post01-07-2018, 11:07    Subject: Climate control not cooling, error memory cleared Quote
Okay, it's happened to me too. Yesterday, I drove to university, studied, and the car was parked in direct sunlight all day. When I got back in, there was no cold air coming from the vents. At home, I logged the following values using VCDS: (see attachment).
Approximately one year ago, the air conditioning system was serviced. The car has always cooled down properly, so I rarely set it below 21°C. Using a diagnostic tool, I tested both fans, and they are working perfectly. There are no error codes stored. The pulley is rotating, as far as I can tell from above. Both refrigerant lines feel extremely hot to the touch.
I'm not sure what to do next, and we're now experiencing temperatures above 30°C.
 File size:  259.74 KB
 Viewed:  748 times
Audi A6 4F 3.0 TDI CDYA 176kw
Audi Q3 8U 2.0 TDI CFGC 130kw
VW Tiguan 5N 2.0 TDI CFFB 103kw
Translated on 17-07-2026, 23:20.
vag-driver
Post03-07-2018, 9:25    Subject: Climate control not cooling, error memory cleared Quote
dieselfreak89 wrote:
Both climate control pipes are burning hot to the touch.
The line to the expansion valve should be warm. The line to the compressor should be cold.
Was bedeutet das?
I'm betting on the expansion valve.
Andreas
Translated on 17-07-2026, 23:21.
No new posts Passat 3C air conditioning not cooling General Tips
No new posts A3 Climate Control Not Working: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Light On After ESP Change - No Codes? On-Board Diagnostics (OBD)
No new posts The climate is no longer cooling as it did in the beginning Diesel Engine Technology
No new posts Error memory empty or no communication On-Board Diagnostics (OBD)
No new posts "AdBlue error message, but fault memory is empty." Diesel Engine Technology
