Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working
Go to page: 1, 2  Next
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Httpbox
Post05-10-2015, 21:25    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
Hello everyone,
I'm new here and I have a Volkswagen Golf 4 with a silly problem that isn't showing up anywhere in the diagnostics.
When I release the accelerator pedal in this vehicle, the engine still receives fuel and continues to push forward. This problem occurs across all RPM ranges. What could be causing this?
LOG-01-013-001-607.CSV
 File name:  LOG-01-013-001-607.CSV
 File size:  30.34 KB
 Downloaded:  539 times
Translated on 11-07-2026, 6:29.
DieselBär30x
Avatar-DieselBär30x
Post05-10-2015, 21:31    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
What engine (model code) are we talking about?
WHAT happened before or is happening now that has led to the current situation?!
Switch or circuit breaker?
If the VAT law has been changed: Incorrect coding icon_wink.gif.
If the circuit is active: Check the relevant component (Bauteil) in the vehicle's electrical system (MStG) for the clutch pedal switch.
Best regards from Munich!
Translated on 11-07-2026, 6:30.
Httpbox
Post05-10-2015, 21:48    Subject: TDI error Quote
Hello.
The car belongs to my son, who just arrived from Croatia. No modifications have ever been made to it, and it has a manual transmission.
Best regards from the Altmühl Valley.
Translated on 11-07-2026, 6:31.
DieselBär30x
Avatar-DieselBär30x
Post05-10-2015, 21:58    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
DieselBär30x wrote:
Which engine (model code) are we talking about?
Translated on 11-07-2026, 6:32.
Post05-10-2015, 22:03    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
DieselBär30x
Avatar-DieselBär30x
Post05-10-2015, 22:16    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
Hello everyone!
Bertil wrote:
I would like to thank you *Knicks-mach* icon_razz.gif.
Trotzdem bleibt's beim "blöder Fehler" respektive "Suppe schmeckt komisch" - was kann das sein?! icon_wink.gif
Translated on 11-07-2026, 6:33.
Post05-10-2015, 23:29    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
Wenn ich bei diesem Fahrzeug vom Gaspedahl gehe, bekommt der Motor immer noch Treibstoff und schiebt weiter, das Problem ist in jedem Drehzahlbereich, was kann das sein?
...and where is the accelerator pedal position in the log file?
When decelerating from higher RPMs, the fuel supply should be reduced to approximately zero by the idle speed.
Ansonsten verbrennt er evt. Engine oil...
How many kilometers has he run?
Translated on 11-07-2026, 6:34.
Httpbox
Post06-10-2015, 18:50    Subject: Stupid mistake Quote
Hello everyone.
Okay, I've checked everything again. Yes, it's an ALH engine, and the Golf has 118,000 kilometers on it.
'When I turn off the engine in the log, everything resets to zero, but the car still keeps moving. We drove through the mountain passes because of the border controls from Croatia, and it was really difficult driving there. If the car were consuming oil, there would be at least a huge cloud of smoke, and it would also need oil – which it hasn't done in 2000 km.'
LOG-01-015-022-046-061-13F-151-191.CSV
 File name:  LOG-01-015-022-046-061-13F-151-191.CSV
 File size:  8.96 KB
 Downloaded:  394 times
Translated on 11-07-2026, 6:35.
DieselBär30x
Avatar-DieselBär30x
Post06-10-2015, 19:22    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
Please describe what you mean by "schiebt weiter" in more detail.
Does the final surge before releasing the accelerator remain unchanged, or is it just a very slight "continued push," or does that "continued push" only last for about 1-2 seconds before it stops?
As I mentioned before: First, check the clutch switch in the main control unit (ECU) to ensure it's being properly recognized.
Translated on 11-07-2026, 6:36.
Httpbox
Post06-10-2015, 19:40    Subject: Stupid mistake Quote
Hello everyone.
Can I check the clutch switch? I haven't read anything about it yet. The Golf was working fine on Sunday evening, but since Monday, it's been having problems. It sputters whenever I take my foot off the gas, sometimes immediately, and other times after 1-2 seconds.
Translated on 11-07-2026, 6:37.
Karma: +1359 / -0   Thank you, like it!
Post06-10-2015, 19:43    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
The voltage at the RSW sensor appears quite high both in idle and thrust modes. Has the MSW been adjusted?
Please post the values for monitoring control module (MCM) #1 when the engine is idling, and MCM #19 with the ignition on.
Translated on 11-07-2026, 6:38.
Httpbox
Post06-10-2015, 19:59    Subject: Stupid mistake Quote
Okay, I need to do that sometime tomorrow evening.
Translated on 11-07-2026, 6:39.
Karma: +807 / -0   Thank you, like it!
Post06-10-2015, 20:30    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
Wasn't a tuning module also plugged into the wiring harness near the fuel injection pump?
Please don't forget the measurement blocks mentioned by Herbert.
What is the fuel injection quantity in measurement block 1 when the engine is at operating temperature and idling?
Httpbox
Post06-10-2015, 22:04    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
Hello.
No tuning, nothing like that, just fill up the gas and drive. I'll reload the engine control unit values tomorrow evening.
Translated on 11-07-2026, 6:40.
Httpbox
Post07-10-2015, 20:30    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
Okay, here are the logs you requested. I hope this is what you were looking for.
LOG-01-041-108-152-191.CSV
 File name:  LOG-01-041-108-152-191.CSV
 File size:  9.76 KB
 Downloaded:  388 times
LOG-01-034-041-092-108-116-153-193.CSV
 File name:  LOG-01-034-041-092-108-116-153-193.CSV
 File size:  6.47 KB
 Downloaded:  377 times
LOG-01-019-001-xxx.CSV
 File name:  LOG-01-019-001-xxx.CSV
 File size:  25.69 KB
 Downloaded:  386 times
Post08-10-2015, 18:47    Subject: Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Quote
Hi there,
It's not very helpful to combine recordings for the "ignition on" state and the "idle" state, or if you don't specify which state was being measured in other recordings. Was everything recorded while the engine was idling?
So, again:
- MWB 19 only activates when the ignition is on; in addition, MWB 1.
- MWB 1 at idle, along with accelerator pedal position, and clutch switch;
Translated on 11-07-2026, 6:41.
No new posts P2006 - Intake manifold control valve stuck closed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, HVAC failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf III TDI doesn't accelerate smoothly Diesel Engine Technology
No new posts TDI Golf IV: Engine Misfire, 96 kW, 2002 Diesel Engine Technology
No new posts Golf IV TDI: Buying Guide for 90 & 101 HP Models Diesel Engine Technology
No new posts AGR at 100% - Performance and Optimization On-Board Diagnostics (OBD)
