Audi A4 B5 Automatic Transmission Problems?
sebv6
2000 Volkswagen Passat Consumption
Post03-05-2015, 10:17    Subject: Audi A4 B5 Automatic Transmission Problems? Quote
I bought my wife an Audi A4 Avant, manufactured in 1997, with a 1.8L engine and 125 horsepower, equipped with a DFG gearbox. When I changed the transmission oil, I found a creamy white substance inside.
After that, I replaced the water cooler. Unfortunately, the transmission shifts slowly when cold and in a somewhat strange way. I think it won't last much longer.
According to the service manual, a 4-speed DFG transmission is installed. However, it definitely shifts 5 times! There's also no label or identifying letter visible on the transmission itself.
I can get a 1.8t transmission for a good price. It's a KBS CJQ 5-speed. Should that work? Or are there any issues with installing it?
Passat TDI PD AWX 12/2000
Translated on 18-08-2026, 23:38.
Post03-05-2015, 14:36    Subject: Audi A4 B5 Automatic Transmission Problems? Quote
Before you consider a replacement, maybe take another look at the transmission fluid.
It might still be slimy.
Translated on 18-08-2026, 23:39.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post03-05-2015, 16:16    Subject: Audi A4 B5 Automatic Transmission Problems? Quote
Hey,
It would be advisable to open the sliding drawer and clean it properly.
Unfortunately, an oil change won't help with such an old transmission; the only thing that will work is removing the deposits that have accumulated over 20 years in places where they shouldn't be.
Translated on 18-08-2026, 23:40.
sebv6
Post03-05-2015, 17:11    Subject: Audi A4 B5 Automatic Transmission Problems? Quote
I had already performed two oil changes and replaced the speed sensor because the transmission wasn't shifting at all initially.
"There was a lot of sludge in the oil pan. I cleaned the control box and the oil pan thoroughly. However, I didn't disassemble anything. When driving constantly in the fourth and fifth gears, I get the impression that the clutch is slipping."
Very strange. Or perhaps a transmission software update would help?
Translated on 18-08-2026, 23:41.
sebv6
Tagessuppe likes this.
Post07-10-2015, 8:55    Subject: Solution: Find the best solutions now! Quote
Okay, so I've removed the gearbox, disassembled it, and found that half of the friction plates were worn out. I've now replaced them.
After 3000 km of trouble-free driving, the reverse gear suddenly stopped working. Since I had already sold the car and wasn't going to disassemble the transmission again, I bought a damaged car with a manual transmission and converted it.
"No problem at all. You just need to replace the subframe, reprogram the control unit, and do some improvising with the wiring so that it starts and the reverse light works. If the car had ESP, I would also have to completely replace the ABS system. Fortunately, it doesn't."
Translated on 18-08-2026, 23:42.
No new posts Document: Automatic Transmission Leaks 01M Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN: Oil leak at upper internal thread screw, automatic t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Fluid Change 01M Golf III Troubleshooting & Guides
No new posts VW/Audi V6 TDI AKE: Starting Problems Diesel Engine Technology
This topic is locked, you cannot edit or reply. Solved - Problems with Automatic Transmission Touareg 5R On-Board Diagnostics (OBD)
No new posts ZF 5HP19 automatic transmission problems in the VW Passat... Transmission, Chassis, Body & Interior
No new posts VW T4 Front Axle Problems: Repair & Solutions Transmission, Chassis, Body & Interior
