Passat 3C air conditioning not cooling (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » General Tips
blackblizzard
Post09-06-2015, 13:23    Subject: Passat 3C air conditioning not cooling Quote
Here's the problem: The air conditioning is no longer working. In the garage, I checked the sensor readings on the cold engine – they all seem plausible except for the sun sensor, which is always showing a value of 0.
The pressure was 4 bar.
After starting the engine and letting it idle, the pressure increased to approximately 8 bar. The cooling fan only runs for a short time.
What could be the reason for that?
Edit: I repaired the temperature control flap motor on the driver's side and performed a basic adjustment.
Best regards.
Translated on 08-07-2026, 6:59.
Karma: +437 / -0   Thank you, like it!
Post09-06-2015, 14:08    Subject: Re: Air conditioning not cooling on Passat 3C Quote
blackblizzard wrote:
In the garage, I checked the sensor readings with the engine cold - they all seem plausible except for the sun position sensor, which is always showing 0.
Why is 0 implausible? You probably don't have any sunlight in the garage. Artificial light doesn't have the same spectrum as sunlight, which is what the sun sensor measures. Therefore, a reading of 0 is quite plausible.
The pressure was at 4 bar
corresponds to approximately 10°C.
Nach laufenlassen im Standgas erhöhte sich der Druck auf ca. 8 bar. Der Kühlventilator geht nur kurz an.
8 bar is also only about 30°C. There's no need for a fan to start running frantically at that temperature.
What are the target and actual currents flowing to the swashplate, and what information do the bits provide regarding the shutdown condition after you have turned the temperature setting to LO while the engine is running?
Greetings.
Guste.
Translated on 08-07-2026, 7:00.
blackblizzard
Post30-07-2015, 9:52    Subject: Passat 3C air conditioning not cooling Quote
So, the sunlight sensor works perfectly fine in sunlight; it actually has a filter inside.
What's also noticeable is that the vaporization temperature is approximately the same as the ambient temperature.
Unfortunately, I'm stuck.
Translated on 08-07-2026, 7:02.
Post30-07-2015, 14:27    Subject: Passat 3C air conditioning not cooling Quote
Here is some more reading material.
There are also data from a PA 3C posted for comparison purposes.
Translated on 08-07-2026, 7:03.
blackblizzard
Post13-08-2015, 15:37    Subject: Passat 3C air conditioning not cooling Quote
Problem solved, the compressor was defective.
Post13-08-2015, 18:41    Subject: Passat 3C air conditioning not cooling Quote
... then summer can stay... Thank you for the feedback icon_wink.gif.
Ratings - Passat 3C air conditioning not cooling
No new posts Doku A3 8P1, Klimaanlage kühlt nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air conditioner smells bad General Tips
No new posts Touran AC Not Working? Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Air conditioner not cooling during speed fluctuations Transmission, Chassis, Body & Interior
No new posts AC Not Cooling? Troubleshooting & Repair Tips. Transmission, Chassis, Body & Interior
No new posts Air conditioner not cooling - Year of manufacture 2000, c... Transmission, Chassis, Body & Interior
