Removing the bevel gear (type 0A5) on a VW Transporter T5
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Gremlin
Avatar-Gremlin
Karma: +91 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post28-10-2011, 15:53    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
Hello everyone;
actual topic:
Okay, I will only provide the translation. Please provide the German text you want me to translate.
I'm currently in the process of trying to remove the oil pan, but the angle gear is in the way.
Vehicle: VW Transporter, year 2005 (model 7HK), 2.5L TDI, 172 hp, 4-Motion.
My plan:
- Remove the right-hand driveshaft, support the engine, loosen/remove the rear engine mounts. Loosen the angle gear (without disconnecting the driveshaft) slightly from the transmission to access the remaining oil pan screws.
1. Would that work? Or, what is the actual workflow?
2. The transmission oil is flowing towards me - as far as I can tell from what I've seen, it has its own oil reservoir? At least SSP_320 doesn't say anything about it...
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post28-10-2011, 20:31    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
Lower the lifting platform, remove the angle gearbox.
You'll start feeling overwhelmed just by lowering it onto the generator platform. With the T4, none of that was necessary!
This is quite a clever design, but it's very difficult to repair. icon_mad.gif icon_mad.gif
And the gear motor with its captivating sound icon_rolleyes.gif.
For someone who just does occasional DIY projects, it's actually not much, depending on the equipment and experience.
reflexsilber met.
Gremlin
Avatar-Gremlin
Post28-10-2011, 20:54    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
Hi Red,
Thank you for the response, even though it has completely destroyed my confidence in being able to do it at the pit.
But I have to agree with you on one thing:
"Easy to repair" is a different matter; even just changing the glow plugs is a nightmare (it can only be done with a 1/4" 10mm long socket, requires a lot of dexterity, the front needs to be in the service position, and the intake manifold needs to be removed).
...But I managed to change the head (see other post) while it was in the service position, WITHOUT having to remove the entire front icon_wink.gif.
...for that, I had a crane to lift it in.
RedR32
Avatar-RedR32
Post28-10-2011, 22:29    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
If you want to get started despite putting in a lot of work, I'm here to offer advice and support.
reflexsilber met.
Gremlin
Avatar-Gremlin
TDI-GTI-4-Motion likes this.
Post29-10-2011, 18:38    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
Hi Red icon_cool.gif.
It was "Grand Battle Day" icon_lol.gif.
At first, I thought about using a stage, but as it usually is, there's no time. And a few friends have old "scissor lift" platforms, but I don't trust them, especially considering how long ago their safety inspections probably expired, and I'm not comfortable with the vehicle weight.
So:
It was a combination of my idea and the lowering of the fare.
At first, I actually managed to remove all the oil pan screws.
Here's the translation:
"To do this, you need to pull the drive shaft straight out. Use a 1/4" extension that's extremely long (about 30cm) along with a 6mm Allen key to remove the screw, and of course, also remove the remaining 4 mounting screws."
Rear motor mount needs to be removed and pushed to the side (the mount should be positioned with its tip facing forward, extending sideways from the tie rod).
It's best to support the motor from the rear, near the gearbox.
Before removing the angle gear, remove any accessible screws. Then, slide the angle gear out approximately 7 cm (you may need to push the driveshaft between the stabilizer bar and the exhaust upwards to do this), which will free up the other components.
"A 1/4" drive with a 11mm socket and swivel head is helpful, especially if the bolt is loose. In that case, a 6mm Allen key with a ball head can also be used (it's actually an M8 internal Torx).
Unfortunately, as expected, it's not going down, even though it seems loose. Oil pan is located at the driver's seat.
Okay, I've loosened the front motor mount, supported the engine, only slightly tightened the rear seat, removed all the front screws, and lowered the whole assembly about 10cm.
Now I had enough space to lower the oil pan.
First, I was cursing because the oil suction tube of the oil pump suddenly sprayed me with a shower... icon_twisted.gif
Remove old sealant with a scraper, degrease, and reassemble in reverse order.
RedR32
Avatar-RedR32
Post29-10-2011, 19:35    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
Okay, great, it works. Thank you for the description.
reflexsilber met.
Gremlin
Avatar-Gremlin
Post02-12-2015, 14:46    Subject: Construction site: AXE T5 engine removal Quote
I'm going to jump back into my old topic right away:
Question:
When lowering the engine carrier, where is the steering linkage detached from the steering column?
My guess is:
Inside the joint piece, in addition to the bearing plate where it passes through, there are 3 pieces. Loosen the screws under the doormat?
chli1976
Karma: +185 / -0   Thank you, like it!
Post02-12-2015, 18:19    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
When removing the engine carrier on a T5, I leave the steering rack attached to the vehicle.
VCDS
Gremlin
Avatar-Gremlin
Post02-12-2015, 18:49    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
"...So, just tie the left and right ropes, and loosen the four screws from the bottom?"
That's another idea; unfortunately, I won't have time to continue working on the "project" until tomorrow evening.
Thank you!
RedR32
Avatar-RedR32
Post02-12-2015, 22:07    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
Gremlin wrote:
...So, just tie the left/right sides, and loosen the 4 screws from the bottom?
Thank you!
I think we did it that way before.
reflexsilber met.
chli1976
Post03-12-2015, 9:21    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
Sure, just tie it up loosely; it will save you a lot of work.
VCDS
Gremlin
Avatar-Gremlin
Post04-12-2015, 11:43    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
Okay.
It lasted about 1.5 hours yesterday. Time:
Because the angle drive and support were in the way, I still decided to remove everything, including the steering gear.
Unfortunately, I didn't mention above that I had already removed the entire front section – including the oil cooler, power steering, water cooler, and radiator; the air conditioning cooler was just set aside.
It was actually quite easy. The steering gear's eccentric screw inside the swivel housing can be removed, allowing the steering gear to be "pushed" sideways – so it doesn't need to be completely detached.
The footrest on the Trapo is designed in such a way that it's cut above the steering column (a clever design, though it might look suspicious...), and can be folded down.
Remove the three screws, and the part will come out completely.
It's also a proposed solution, but each person needs to decide for themselves which approach is better.
Gremlin
Avatar-Gremlin
Post04-12-2015, 21:05    Subject: Re: Construction site: AXE T5 engine removal Quote
Gremlin wrote:
Disassembled, errors found...
 Sefekte Kupplungs-Reibscheibe
 File size:  1.34 MB
 Viewed:  6654 times
RedR32
Avatar-RedR32
Post04-12-2015, 22:09    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
Hey, it looks like it's cracked or broken off. How many kilometers has it driven?
reflexsilber met.
Gremlin
Avatar-Gremlin
Post05-12-2015, 12:43    Subject: Removing the bevel gear (type 0A5) on a VW Transporter T5 Quote
Approximately 187,000 km; I'm not sure how many of those kilometers were driven by the previous owner.
In terms of bodywork, it was top-notch, even though it came from a heating and plumbing company.
And yes: The covering material has detached from the rivets, or a retaining arm has broken off.
While the dual-mass flywheel is still within acceptable limits, the friction surface is discolored blue due to the entire incident (the clutch didn't disengage properly).
Complete set, new, including pressure plate; either LUK or Sachs...
EDIT:
I had to remove the angle gear first during the disassembly of the gearbox, and in the process, some gearbox oil spilled.
What is it filled with?
Just a standard 75W90?
No new posts Document Golf 1J1587, Transmission Console Mounting Not R... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Documentary about Whistling Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Clutch Problems: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Loosen brake caliper Transmission, Chassis, Body & Interior
No new posts Dreieckschraube an der ESP lösen Diesel Engine Technology
No new posts Aggregateträger lösen Transmission, Chassis, Body & Interior
No new posts Zahnriemenrad der Wasserpumpe lösen, wie? Diesel Engine Technology
