DSG Basic Settings Audi DL501 vs. VW DQ500
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Obermeister
Post15-01-2015, 23:21    Subject: DSG Basic Settings Audi DL501 vs. VW DQ500 Quote
Does the basic setup guide for the DSG 7G apply to both types of DSG transmissions, or only to the 7G transmission used by VW?
Thank you.
Eric.
delvos
Post02-02-2016, 13:00    Subject: DSG Basic Settings Audi DL501 vs. VW DQ500 Quote
"I'm also interested in that, or is the described basic setup applicable to the "dry" 7-speed DSG (DQ200) or the "wet" 7-speed DSG (DQ500)?"
Karma: +795 / -0   Thank you, like it!
Post02-02-2016, 13:12    Subject: DSG Basic Settings Audi DL501 vs. VW DQ500 Quote
Does anyone have information about the respective engine control units (Autoscan)? Then I could check.
delvos
Post02-02-2016, 13:41    Subject: DSG Basic Settings Audi DL501 vs. VW DQ500 Quote
Attached is a picture of my Tiguan with a DQ500 transmission.
Delvos.
Autoscan-1.txt
 Tiguan mit DQ500
Tiguan mit DQ500
 File name:  Autoscan-1.txt
 File size:  15.28 KB
 Downloaded:  778 times
Post02-02-2016, 13:49    Subject: DSG Basic Settings Audi DL501 vs. VW DQ500 Quote
Okay, so the DSG DQ500-7A (Tiguan, transverse engine) has the code "0BH". The Audi DL501 is designed for "0B5" longitudinally mounted engines.
/viewtopic.php?t=27262 has been updated because the basic settings of the 7-speed DSGs are different depending on whether they are installed longitudinally or transversely!
We are still missing an Autoscan from the DL501.
delvos
Post02-02-2016, 14:20    Subject: DSG Basic Settings Audi DL501 vs. VW DQ500 Quote
Thank you!
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A8 air suspension basic settings Transmission, Chassis, Body & Interior
No new posts How to reset DSG from Golf 7R, Audi S3 8V to factory sett... Gasoline Engine Technology
No new posts Default Settings for Steering Angle in Audi S3 8V On-Board Diagnostics (OBD)
No new posts Audi 4-Gang Automatic Transmission (097, CEB) Initial Setup On-Board Diagnostics (OBD)
