dokatoto Guest
10-05-2003, 12:48 Subject: Cannot find the list of measurement data blocks in the database |
Can someone perhaps give me a hint? The search function isn't helping either!
Thank you  .
Translated on 19-07-2026, 12:13.
10-05-2003, 15:08 Subject: Cannot find the list of measurement data blocks in the database |
Translated on 19-07-2026, 12:14.
Profile PM Garage |
dokatoto Guest
10-05-2003, 15:38 Subject: Cannot find the list of measurement data blocks in the database |
No, I already have those.
Please provide the German text you would like me to translate into English. I will then provide only the translation, without any explanations or additional information.
According to the forum, it should be in the error database, but I can't find anything there.
Toto.
10-05-2003, 15:52 Subject: Cannot find the list of measurement data blocks in the database |
dokatoto wrote: |
Instead, provide a listing of the individual measurement blocks in VAG-Com and their function. |
Hi.
The values displayed there also appear in VAGCOM  when the corresponding blocks are selected.
If you're referring to a collection of so-called "label files" that add motor-specific field labels to all readable blocks of data...
I once suggested that in the forum, but I don't think there was enough interest to make the effort worthwhile. Gruß Ulf
Translated on 19-07-2026, 12:16.
Profile PM Garage |
dokatoto Guest
10-05-2003, 18:24 Subject: Cannot find the list of measurement data blocks in the database |
and how do I know which number corresponds to which block and which function?
Do I have to go through all of them until I find the value, for example, that matches the RPM reading on my T3 tachometer...? etc.?
Translated on 19-07-2026, 12:17.
10-05-2003, 20:36 Subject: Cannot find the list of measurement data blocks in the database |
dokatoto wrote: | and how do I know which number corresponds to which block and which function?
Do I have to go through all of them until I find, for example, the RPM value needed to match my T3 tachometer...? |
Hi.
If you want to open the measuring blocks with VAGCOM, you must first enter a block number.
Then you will usually see 4 fields containing the information that is also described in the link mentioned above (for the relevant section).
If you have a suitable label file, it will even show you what is displayed under each field... just give it a try. Gruß Ulf
Translated on 19-07-2026, 12:18.
Profile PM Garage |
dokatoto Guest
11-05-2003, 8:46 Subject: Cannot find the list of measurement data blocks in the database |
That's what I meant. Can you roughly say where the numbers start and end?
Translated on 19-07-2026, 12:19.
11-05-2003, 19:50 Subject: Cannot find the list of measurement data blocks in the database |
dokatoto wrote: | | that's what I meant, can we roughly say where the numbers start and end? |
The field numbers are 10 (for group 000) or 4 (for all other groups).
The group numbers can range into the hundreds depending on the engine type, and many of these slots may be unoccupied. Gruß Ulf
Profile PM Garage |
