1.9 TDI AHF: More Power for Daily Driving?
Stepho19
Post27-05-2016, 9:43    Subject: 1.9 TDI AHF: More Power for Daily Driving? Quote
Hello, hello!
My old ALH is gone. Now I'm driving an AHF with 110 horsepower in a 4-door wagon. I've been quite satisfied and it's been reliable for a while now. But things shouldn't get boring, so I had an idea.
"First of all, I've already searched the forum and read a few things, but the topics tend to go into detail in specific areas, and I'm looking for some more general ideas and tips. I'm not completely inexperienced with DIY projects, but this would be my first project of this kind."
Now, to the question:
Is it possible and worthwhile to extract some extra power from the AHF engine if it's a daily driver? I drive it 100km every day. I'm not just talking about chip tuning or something similar; I'm generally willing to replace components like pistons and connecting rods with stronger ones.
I've been thinking about the engine, transmission, etc. for a while. My question is basically: what kind of power output can you put into the engine block and cylinder head if the car is used daily for commuting, and what is still reasonably comfortable to drive? A turbo lag wouldn't bother me, but what about, for example, a single-mass flywheel?
I would appreciate any ideas, suggestions, experiences, etc.
Stephen
Translated on 29-09-2026, 13:27.
Karma: +805 / -0   Thank you, like it!
Post27-05-2016, 11:51    Subject: 1.9 TDI AHF: More Power for Daily Driving? Quote
Often, the most effective solution is a software modification (chip tuning), which can increase the power output to 135-140+ horsepower.
Besides potentially replacing other fuel injectors if the mileage is high, no other modifications are really necessary for a daily driver. I won't go into the details here, but I'll refer you to the forum's search function for more information.
Modifications exceeding 140 horsepower require careful and well-considered software adjustments, otherwise the cylinder head gasket is likely to fail. As someone who used to offer such modifications, I wouldn't expect the majority of providers to understand this.
However, even poorly designed software can achieve this if the parameter maps are incorrectly modified.
"See also background information:"
I would advise against using a tuning box for an AHF engine. Without adjusting the boost pressure, it won't work well for long, and it can lead to problems such as a stuck variable geometry turbocharger (VTG) or damage to the turbocharger's bearing due to excessively high exhaust temperatures and excessive soot buildup during operation.
A provider that has the necessary background knowledge, for example, is http://www.softwareoptimierung.at.
And: Be cautious with VP37 injection pumps that have more than 250,000 km (approximately 155,000 miles) on them, as the advance timing mechanism often no longer functions correctly, which can lead to the engine/turbocharger slowly overheating and failing.
Translated on 29-09-2026, 13:31.
No new posts Torque and driving fun in everyday life Technical Articles
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Chip Tuning: More Than Just Performance Diesel Engine Technology
No new posts Soot Buildup: More in Summer? Diesel Engine Technology
No new posts NW Adjustments: More Questions Than Answers Diesel Engine Technology
No new posts More power for standard TD Diesel Engine Technology
