DPF Reset: Ibiza 2.0 TDI FR - Transfer Learning Values
Blackfrosch
Post21-06-2016, 0:10    Subject: DPF Reset: Ibiza 2.0 TDI FR - Transfer Learning Values Quote
Hello everyone,
I have a vehicle with an EDC17C46 engine control unit (ECU). It has an EA189 engine, which will likely receive an update in the future. I want to be able to compare the AGR (air-fuel ratio) values, fuel consumption, etc., before and after the update. Therefore, I acquired a used ECU and updated it to the latest software version (without WFS).
"Injector learning values, etc., could be read from the adaptation channels. However, I am missing data such as DPF ash mass, etc."
Does anyone know how this works with the newer EDC17 systems? Is the "initialize particulate filter" function in the APKs/login sufficient?
Log-ERB HG 620-VSSZZZ6JZER073409-42460km-Autoscan.txt
 Autoscan des Fahrzeugs
 File name:  Log-ERB HG 620-VSSZZZ6JZER073409-42460km-Autoscan.txt
 File size:  9.65 KB
 Downloaded:  1151 times
Translated on 11-09-2026, 13:13.
Post21-06-2016, 9:19    Subject: DPF Reset: Ibiza 2.0 TDI FR - Transfer Learning Values Quote
The ash level in the DPF should be adjustable, and it should be adjusted based on the filter's mileage (e.g., > 50,000 km).
Have you checked out the adjusted version yet?
Translated on 11-09-2026, 13:14.
Blackfrosch
Post21-06-2016, 15:53    Subject: DPF Reset: Ibiza 2.0 TDI FR - MSG Update Quote
Hi, yes, as I wrote, I checked the adaptation channels. Otherwise, I wouldn't be asking icon_surprised.gif.
I also specifically checked with versions 15.7 and beta 16.5, and both show the same result.
Please provide the text you would like me to translate. I need the text from the attachment to be able to translate it.
"Hello"
 File size:  31.33 KB
 Viewed:  2407 times
Translated on 11-09-2026, 13:15.
Post21-06-2016, 15:56    Subject: DPF Reset: Ibiza 2.0 TDI FR - Transfer Learning Values Quote
Thank you for the Screenshot. I'm not sure what "initialization" refers to in this context. In older engine control units, the actual values displayed are usually the ash mass or ash volume. Is it possible to enter values there?
Please retrieve the ash mass or ash volume from the extended measurement blocks in the old engine control unit beforehand and write it down. icon_idea.gif
Translated on 11-09-2026, 13:16.
Blackfrosch
dieselschrauber likes this.
Post21-06-2016, 22:03    Subject: DPF Reset: Ibiza 2.0 TDI FR - Transfer Learning Values Quote
When initializing, the unit is set to Tkm. I tested this as follows:
1. Default setting: "Reset particle filter learning values."
2. Access permission 12233
3. Adaptation channel "DPF initialization" -> Enter the mileage the DPF has accumulated.
The oil ash volume has been reduced to 0.02 liters, similar to the "source control unit/vehicle." However, the calculated soot mass is 24g, instead of the 12g of the original control unit. I suspect this is because I don't have a differential pressure sensor on my test ECU setup.
Can anyone offer any insights regarding the calculated soot mass? I've also been experimenting with the total kilometers driven (Tkm) during initialization, and I'm observing that both the oil ash volume and the soot mass increase simultaneously.
"Hello"
 Grundeinstellung
 File size:  33.57 KB
 Viewed:  713 times
LOG-01-3291-3301-3351-3361-3371-3381_DPF.csv
 Quellfahrzeug mit original Werks ECU - wie AutoScan oben
 File name:  LOG-01-3291-3301-3351-3361-3371-3381_DPF.csv
 File size:  1.47 KB
 Downloaded:  376 times
Translated on 11-09-2026, 13:18.
dieselschrauber and Blackfrosch likes this.
Post21-06-2016, 22:12    Subject: DPF Reset: Ibiza 2.0 TDI FR - Transfer Learning Values Quote
"I had the DPF cleaned on a Sharan 7N some time ago. Afterwards, I used the initialization procedure you showed, setting the distance to 20,000 km. This resulted in a value of 0.01 for the oil ash volume. Do I need to adjust something to get back to the original value?"
Translated on 11-09-2026, 13:19.
Blackfrosch
Post21-06-2016, 22:46    Subject: DPF Reset: Ibiza 2.0 TDI FR - Transfer Learning Values Quote
Sure, no problem.
I just edited my previous post when you wrote your message. I thought I'd try it out - it's not like anything important is being discussed right now anyway.
"Hello"
Translated on 11-09-2026, 13:20.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Disable ESP: 2.0 TDI 143HP Seat Ibiza (2015) Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi RS 6: Resetting Automatic Transmission Learning Values Electrical Systems, Vehicle Electronics, Multimedia
No new posts Reset Learning Rates: Null Set Correction On-Board Diagnostics (OBD)
No new posts VCDS V158 Learning Values - HELP Transmission, Chassis, Body & Interior
