Seat Ibiza 6L GRA, functions disabled, unlocking not performed
Go to page: 1, 2  Next
prima5-heitzer
Post23-07-2016, 18:00    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
Hello everyone,
I installed a GRA (Gearbox Ratio Adapter) in my Seat Ibiza 6L. After the installation, I entered the LOGIN code mentioned here using VCDS. As far as I can tell, the control unit recognized the GRA. However, the cruise control is not working while driving. I drove faster than 50 km/h and tested all the switch functions.
I have to say that I only received the VCDS today via mail, and I have no experience whatsoever regarding what this device can do. I've already clicked around a bit and tried to query some values.
Can you give me some tips on how to get the cruise control working?
Here's the log for my car.
You're welcome.
Constantin.
Saturday, July 23, 2016, 12:02:49:28312
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x64.
VCDS Version: RKS 15.7.4.1
Data as of: 20160223.
Dealer/Workshop name:
Vehicle Identification Number: VSSZZZ6LZ6R541762 License Plate:
Mileage: 91210 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
Vehicle Identification Number: VSSZZZ6LZ6R541762 Mileage: 91210 km
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module
Label file: DRV\038-906-019-ARL.lbl
Part number: 038 906 019 NT
Part: 1.9L R4 EDC 0000SG 8353
Encoding: 00102
Operating number: WSC 06402
VCID: 76E42BA852A9A58E54-4B40
VSSZZZ6LZ6R541762 SEZ7Z0F3446444
No error codes found.
Readiness: 0 0 1 1 1
Address 03: Brake Electronics Label file: DRV\6R0-907-37x-ESP80.lbl
Part number SW: 6Q0 907 379 AQ, Hardware number: 6Q0 907 379 AQ.
Component: ESP 8.0 front panel. Part number: H04 0002.
Encoding: 0002347
Operating number: WSC 06402 785 00200
VCID: 0C1069406C25CF5E12-5182
Subsystem 1 - Part number: 6Q0 907 379 AQ
H04 0002
Address 08: Climate Control/Heating Module. Label file: DRV\6L0-820-043.lbl
Part number: 6L0 820 043 E
Part: CLIMAtronic PQ24 3805
Operating Number: WSC 00000 000 00000
VCID: 285835D0989D837E16-5182
Subsystem 1 - Part number: 6L0 820 043 E
Component: CLIMAtronic PQ24, part number 3805.
or error codes are not supported by the control unit.
or communication errors occurred.
Address 09: Central Electronics
Label file: DRV\6Qx-937-049-C.lbl
Part number: 6Q1 937 049 D
Part number: 0000 BN-SG. 1S34
Encoding: 00012
VCID: 3C70F9802C053FDE62-5164
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 605 AE.
Part: 0H AIRBAG VW5 0C 0010
Encoding: 12360
Operating number: WSC 06401
VCID: 7AFC3F9866B1C1EE30-5164
"1 error found:"
00588 - Airbag igniter (driver side) (N95)
33-00 - Resistor value too low.
Address 17: Control panel module
Label file: DRV\6L0-920-xx0-17.lbl
Part number: 6LL 920 820.
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V13
Encoding: 00141
VCID: 0302427C117B802663-5164
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Part: 0068 GATEWAY CAN 1S34
Encoding: 00014
VCID: 70E81DB030CD8BBE8E-5164
Address 44: Steering Assist
Label file: DRV\6Q0-423-156.clb
Part number: 6R0 423 156 B
Part: Power Steering Unit - TRW - V277
Encoding: 10131
Operating number: WSC 40274
VCID: 2F6ADECCED73D446D7-5164
Address 46: Comfort System. Label file: DRV\6Q0-959-433.lbl.
Part number: 6Q0 959 433 E.
Component: Comfort Device 0002
Encoding: 00016
VCID: 3D76F484371F36D655-4B40
Address 56: Radio Label file: DRV\1J0-035-18x-56.lbl
Part number: 6L0 035 156 B
Component: seat s04. GRO size: 4100.
Encoding: 00401
VCID: 285835D0C89D837E16-4B58
Ende----------------------------(Duration: 04:2http://shop.dieselschrauber.de-----------------------------
Translated on 05-07-2026, 22:07.
Post24-07-2016, 9:35    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
What is the original engine code installed in your car?
The GRA (Gas Recirculation) is not activated in the engine control unit. What exactly did you do when you tried to activate it?
Translated on 05-07-2026, 22:18.
Post24-07-2016, 14:01    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
I understand that you typed "login" into the authorization field. However, that's only the first part. It will then give you the opportunity to code the GRA.
Post24-07-2016, 14:41    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
@matthiasTDI96Viewing profile: matthiasTDI96: With the control unit, the correct login should be sufficient, which is why I asked what he did. "For the sake of clarity, I remove any duplicate or redundant information from the Autoscan results."
Translated on 05-07-2026, 22:19.
prima5-heitzer
Post26-07-2016, 9:17    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
Hello!
The engine identification code is BUK.
I initially selected the individual control unit (engine control unit) and then, instead of going to the coding section, I went to the login section. In that area, a login code was immediately suggested to me via a pop-up, which I had previously found in this forum. I entered and confirmed this.
I hope you can somewhat follow my description.
Constantine.
Translated on 05-07-2026, 22:20.
Post26-07-2016, 9:40    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
What login code did you enter? Is this the original engine control unit?
prima5-heitzer
Post26-07-2016, 13:15    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
Hello Rainer,
I used the following code: 11463.
To my knowledge, the control unit is original. However, since the car was purchased used, there is certainly no warranty for it.
Best regards, Konstantin.
Translated on 05-07-2026, 22:21.
Post26-07-2016, 14:28    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
Please try logging in again, and if there is a button labeled "Security Access" instead of "Login," please use that.
The activation of the GRA (Gas Recirculation) can be identified in the engine control unit (ECU) data as follows:
Part: 1.9l R4 EDC G000SG 8353
Translated on 05-07-2026, 22:22.
prima5-heitzer
Post27-07-2016, 11:58    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
Sure, thanks!
I will test it and get back to you with feedback afterwards!
prima5-heitzer
Post27-07-2016, 17:39    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
I just re-entered the login information. The control unit now correctly displays the G 1.9l R4 EDC G000SG 8353. When I enter the deactivation code in the login screen, the "G" disappears again.
Unfortunately, the cruise control is still not working.
What's the next step?
Translated on 05-07-2026, 22:23.
Post27-07-2016, 18:00    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
Check the wiring. Then, verify the measurement blocks for the switch positions. Are there any further registrations or configurations required on the steering column control unit, etc., for this vehicle?
Translated on 05-07-2026, 22:24.
prima5-heitzer
Post27-07-2016, 19:25    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
I can certainly double-check the wiring.
"Otherwise, nothing should be changed." I think the slip ring still needs to be replaced because after installing the graphics card, I'm getting an airbag warning light and a scratching noise.
What do I need to do to access the measurement block sections?
Thank you and best regards.
Post27-07-2016, 20:10    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
Do you click on "Measurement Blocks" in VCDS, then select measurement block 6?
See also:
006,0,Speed control system (GRA).
006,1,Speed, (Actual Value)
006.2, Pedal Monitoring, , xx1 = Brake light switch (F)
x1x = Brake pedal switch (F47)
1xx = Clutch pedal switch (F36)
; xx1 = Brake light switch (F)
; x1x = Brake pedal switch (F47)
; 1xx = Clutch pedal switch (F36)
006,3,Accelerator pedal position, Range: 0.0...100.0 %\nTarget value (idle): 0.0 %\nTarget value (full load): 100.0 %
006,4,Speed control system,000 = GRA enabled and inactive
001 = GRA enabled and active
255 = GRA not enabled
; 000 = GRA enabled but inactive.
; 001 = GRA enabled and active.
; 255 = GRA not enabled
Translated on 05-07-2026, 22:26.
prima5-heitzer
Post28-07-2016, 8:51    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
Thank you very much.
I'll see what my [device/program/etc.] comes up with!
VG
Translated on 05-07-2026, 22:28.
Wiesel
dieselschrauber likes this.
Post28-07-2016, 9:47    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
prima5-heitzer wrote:
...I think that the slip ring still needs to be replaced.
Since installing the graphics card, I have an airbag warning light and a scratching noise.
The airbag is connected to its control unit via a cable that runs through a coiled spring.
If you have a problem there after the modification (hopefully the battery was disconnected during the modification).
It's 99% likely that the connector on the steering column is not properly connected.
Sanding is usually caused by dirt between the sandpaper and the surface.
They are running (less commonly, bent grinders).
When you reach the Ibi area, carefully place a soft cloth between...
Insert the abrasive pads and belts, and carefully place the cloth underneath.
Be careful not to bend the grinding wheels.
(irreparably) and rotate the cloth attached to the abrasive pads (steer with the cloth).
Micha
Translated on 05-07-2026, 22:29.
prima5-heitzer
Post29-07-2016, 14:47    Subject: Seat Ibiza 6L GRA, functions disabled, unlocking not performed Quote
Hey Micha,
I've disconnected and reconnected the plug several times. The clicking sound is also clearly audible when closing it. I therefore suspect that the problem is not related to the connection.
Cleaning is a good idea, so I can take care of that. The problem is that there were no noises before the GRA was installed. Therefore, I actually suspect that I damaged the slip ring while installing it, specifically while focusing on the cruise control system.
Best regards and have a nice weekend.
Translated on 05-07-2026, 22:31.
No new posts Seat Altea horn not working, cruise control Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Leon 1M: 1st & 2nd Gear Not Working Transmission, Chassis, Body & Interior
No new posts Seat Ibiza stopped working after battery replacement. Electrical Systems, Vehicle Electronics, Multimedia
No new posts GRA Activation Not Working? Troubleshooting Guide. Diesel Engine Technology
No new posts GRA not working after activation Diesel Engine Technology
