Hi there!
GTD refers only to the trim level, so a turbodiesel engine in the GT version. However, the Golf 2 TD was available with five different engines.
1V --> 44 kW (Potter standard with catalytic converter, fuel injection pump without LDA).
JR --> 51 kW
MF --> 51 kW
SB --> 59 kW (turbocharger from the factory).
RA --> 59 kW (turbocharger from the factory).
From which country should it be imported?
What emission standard does it meet?
"At that time, COC (Certificate of Conformity) documents didn't exist yet, so a § 21 final inspection is required. The costs for this will likely range from €150 to €250, depending on the amount of work involved."
Best regards, Rüdi.
Translated on 30-07-2026, 2:19.
