A4 8K SAC Clutch: Replacement & Upgrade
chli1976
Post26-10-2016, 20:33    Subject: A4 8K SAC Clutch: Replacement & Upgrade Quote
Today, I replaced the idler pulley bearing on my girlfriend's 2008 Audi A4 (engine code CAGA).
I compressed the printing plate on the press by about 8mm and then released it. When reassembling, I did the same thing, but now the clutch is slipping.
Is this a Sachs pressure plate with an internal adjustment mechanism? Is it possible to somehow lock the adjustment ring in place, similar to how it's done with LUK pressure plates?
VCDS
Translated on 07-10-2026, 12:41.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post27-10-2016, 3:22    Subject: A4 8K SAC Clutch: Replacement & Upgrade Quote
No. That only works with the LUK version.
/viewtopic.php?t=22974&highlight=luk+sachs
Passat Variant BGW 2005
Translated on 07-10-2026, 12:42.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coupling Diesel Engine Technology
No new posts Clutch 1Z Diesel Engine Technology
No new posts LUK Clutch for ALH engine Diesel Engine Technology
No new posts Clutch Wear: Symptoms and Replacement. Diesel Engine Technology
