Bleed diesel filter Volkswagen Golf 7 - 1.6 TDI
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
alevuz
Karma: +32 / -0   Thank you, like it!
Post14-02-2017, 22:28    Subject: Bleed diesel filter Volkswagen Golf 7 - 1.6 TDI Quote
Good evening.
Today, I performed a minor service on the vehicle mentioned above, addressing the following issues:
The service indicator could not be reset as usual (using the button).
Can someone please tell me how to get the priming pump running?
(not possible with "initial fuel system filling" and under "fuel pump electrical components").
I then stopped and didn't complete the data transfer because I didn't want to introduce any air into the system.
Generally, I'm shocked (and I've seen quite a bit with the V10 TDI) by how many parts (including 2 auxiliary water pumps, an exhaust flap, intercooler, or whatever that thing is on the intake manifold, etc.) are installed in such a Euro 6 engine!
After 5 years and 150,000 km, you can just throw this car away because a repair to some small, inaccessible part will financially ruin you!
Thank you for your responses...
Sure thing. Please provide the text you would like me to translate from German to English.
Alevuz.
Autoscan:
Tuesday, February 14, 2017, 11:40:57:53341
VCDS - A VAG/VAS emulator based on Windows, running on Windows 10 x86.
VCDS version: RKS 17.1.2.0
Data as of: 20170131 DS267.1
Vehicle Identification Number (VIN): WVWZZZAUZFP085531. License plate: GOLF 7 - ROLAND.
Mileage: 49229 km. Repair order: G7-Roland.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BĂ€umen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag fĂŒr einen Spaziergang."
Vehicle type: AU (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
Vehicle Identification Number (VIN): WVWZZZAUZFP085531. Mileage: 49,229 km.
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: Error 0010.
08 - Climate Control/Heating Unit - Status: Error 0010.
09-Central Electrical System -- Status: OK.
Parking Assist System 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
42-door electric driver -- Status: OK 0000
Steering assist - Status: OK 0000.
52-door electric passenger door - Status: OK 0000.
5F-Information Selection. I -- Status: Error 0010.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Feld und lÀsst das Gras sanft wiegen. Es ist ein wunderschöner Tag."
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze blows through the field, causing the grass to sway softly. It's a beautiful day.
Address 01: Engine Control Module (2D2D2-CXXB)
Label file: DRV\04L-907-309-V1.clb
Part number SW: 04L 906 056, HW: 04L 907 445 B.
Part: R4 1.6L TDI; Part Number: H06 8983.
Revision: 22004001
Encoding: 01114032430401092000
Operating number: WSC 00028 028 00073
ASAM Dataset: EV_ECM16TDI03004L906056 002009
ROD: EV_ECM16TDI03004L906056_002_VW37.rod
VCID: 6ADE67C18DAFB4115D-803E
No error codes found.
Readiness: Not Available.
Address 03: Brake Electronics (J104)
Label file: 5Q0-907-379-IPB-V1.clb
Part number SW: 3Q0 907 379 Q, HW: 3Q0 907 379 F.
Component: ESC H42 0610
Revision: 00000000 Serial Number: 60495000002758
Encoding: 01FA62A124280971077C060341C42580462490E06082A4F30040F07AC002
Operating number: WSC 00028 028 00067
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036.
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 489AFD49F363A6016B-801C
"One error found:"
16401 - Tire pressure warning.
C102D 00 [008] - -
Occasionally - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 1.
Lost Count: 76
Mileage: 39,454 km
Date: 2016.10.23
Time: 12:14:37
Address 08: Climate Control/Heating Module (J255)
Label file: 5G0-907-044.clb
Part number SW: 5G0 907 044 BD. Hardware: 5G0 907 044 BD.
Component: Climatronic H03 1001
Revision: 00001K08
Encoding: 00020104202100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 003018
ROD: EV_ACClimaBHBVW37X_003_VW37.rod
Control unit for the fresh air blower (front).
Refrigerant pressure and refrigerant temperature sensors:
Air quality sensor:
"One error found:"
1048835 - Function limitation due to engine control unit.
P1719 00 [008] - -
Error priority: 6
Error frequency: 1.
Lost Count: 169
Mileage: 49171 km
Date: 2017.02.14
Time: 08:07:04
Voltage at terminal 30: 13.5 V.
Auxiliary heating: multi-stage activation for supplementary heating: activation at level 3.
Auxiliary heating: stepped control - setpoint value: 3.
Auxiliary heating: stepped setpoint: 3.
Auxiliary heating: Control system setpoint level: 3.
Address 09: Central Electronics (J519)
Label file: 5Q0-937-08X-HV1.clb
Part number SW: 5Q0 937 084 AJ, Hardware: 5Q0 937 084 AJ.
Component: BCM MQBAB H, Part Number: H18 0137.
Serial number: 01011504302968
Encoding: 00000846C24102FB4BE44000001C07081000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
FILE: EV_BCMBOSCH_013.rod
VCID: 000A25699BD35E41E3-8054
Wiper motor control unit:
Subsystem 1 - Part number SW: 5G1 955 119 A, HW: 5G1 955 119 A, Label file: DRV\5QX-955-119-V1.CLB
Component: WWS 150206 043 0551
Serial number: 150211075636
Encoding: 0E4DDD
Rain and light sensor:
Subsystem 2 - Part number SW: 5Q0 955 547 A, HW: 5Q0 955 547 A, Label file: DRV\5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M02D20H11M40S45
Encoding: 00A8DD
Address 10: Parking Assist 2 (J791)
Label file: 5Q0-919-298.clb
Part number SW: 5Q0 919 298 F, HW: 5Q0 919 298 F.
Part number: PARKING ASSIST PLA H12 0047.
Revision: -------- Serial Number: 39431503803451
Encoding: 0031061041
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 428EEF61D55F8C51B5-8016
Address 15: Airbag (J234)
Label file: DRV\5Q0-959-655.clb
Part number SW: 5Q0 959 655 D, HW: 5Q0 959 655 D.
Part number: Airbag VW20 014 0385.
Serial number: 003F6R0G8W2N
Encoding: 98CCC000000000005C0000CF004800000065
Operating number: WSC 00028 028 00061
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
FILE: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 418CE06DD0599749AC-8014
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: ----------- HW: 480 001 202 15
Component: SideSensor_Df 001 0887
Serial number: 35767000000C0539231K
Encoding: 2D2D2D
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: ----------- HW: 480 001 202 15
Component: SideSensor_Pf 001 0887
Serial number: 35867000000DBAF82316
Encoding: 2D2D2D
Rear side airbag crash sensor (driver's side).
Subsystem 3 - Part number: SW: ----------- HW: 480 401 202 15
Component: SideSensor_Dr 001 6149
Serial number: 3516502C7198E154F16J
Encoding: 2D2D2D
Rear side airbag crash sensor, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 480 401 202 15
Component: SideSensor_Pr 001 6149
Serial number: 3526502C7198E1553226
Encoding: 2D2D2D
Front airbag crash sensor (driver side):
Subsystem 5 - Part number: SW: ----------- HW: 480 400 502 15
Component: FrontSensor_D 001 6149
Serial number: 3556502AB196FF5290D.
Encoding: 2D2D2D
Address 16: Steering wheel electronics (J527)
Label file: DRV\5Q0-953-549.clb
Part number SW: 5Q0 953 507 AB, Hardware: 5Q0 953 549.
Bauteil: Lenks. Module 007 0070.
Revision: -------- Serial Number: 18021504400166
Encoding: 0600
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 76E643B1C91760F1C9-8022
Address 17: Control panel module (J285)
Label file: DRV\5G0-920-XXX-17.clb
Part number SW: 5G1 920 751, HW: 5G1 920 751.
Component: COMBINATION UNIT 304 4270
Encoding: 07A41A002390000800086A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009037
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 65C414FD64B19B6970-8030
Address 19: Diagnostic Interface (J533)
Label file: DRV\5Q0-907-530-V1.clb
Part number SW: 5Q0 907 530 AA. Part number HW: 5Q0 907 530 K.
Component: GW MQB Low, Part Number: 210 2203.
Revision: -------- Serial Number: 21121410801107
Encoding: 030000040F087300EF000248080F000100010500000000000000000000000
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti_011.rod
VCID: 70EA75A9AB734EC113-8024
Generator:
Battery monitoring control unit:
Subsystem 2 - Part number SW: 5Q0 915 181 G, HW: 5Q0 915 181 G.
Part number: J367-BDM Hella H04 8050.
Serial number: 3430525603
Address 42: Door Electric Driver (J386) Label file: 5QX-959-X93-42.clb
Part number SW: 5Q4 959 593 C, HW: 5Q4 959 593 B.
Component: TSG FS 009 0015
Serial number: 0000137155667
Encoding: 00310320D000020000001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4584F47DC471BB6990-8010
Rear door control module, driver's side.
Subsystem 1 - Part number SW: 5Q4 959 811 A, HW: 5Q4 959 811 A.
Component: Rear panel FHSG DRV 007 0002.
Serial number: 00000000000007936075
Encoding: 010000
Address 44: Steering Assist (J500)
Label file: DRV\5Q0-909-144.clb
Part number SW: 5Q0 909 144 R. Hardware: 5Q0 909 144 R.
Part number: EPS_MQB_ZFLS 126 1061.
Encoding: 0302
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 4380EA65CA458559BE-8016
Address 52: Power door lock, front passenger side (J387) Label file: 5QX-959-X92-52.clb
Part number SW: 5Q4 959 592 C, HW: 5Q4 959 592 B.
Component: TSG BFS 009 0015.
Serial number: 0000136877917
Encoding: 00310120DE00020000801000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 4482E979CF4B826187-8010
Door control module, rear passenger side:
Subsystem 1 - Part number SW: 5Q4 959 812 A, HW: 5Q4 959 812 A.
Component: Rear panel FHSG PSG 007 0002.
Serial number: 00000000000008008755.
Encoding: 090000
Address 5F: Information selection. I (J794)
Label file: 5G0-035-MIB-STD1.clb
Part number SW: 5G0 035 846 A, HW: 5G0 035 846 A.
Component: MU-S-N-ER 041 0430
Serial number: V1F01602152788
Encoding: 02730001FF00000011110001000800031F0100840100010045
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 27585EF55E3D497982-8072
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 5G0 919 605 D, HW: 5G0 919 605 D.
Component: ABT_Std_Nav H60 0030.
Serial number: VWZ8Z9RS406QW1
Storage media:
Subsystem 2 - Part number SW: 5G0 919 866 Q, HW: -----------
Component: ECE 2015 --- 0045
Serial number: --------------------
"One error found:"
6145 - Display and control unit 1 for information electronics.
B129E 07 [009] - Mechanical fault.
Error priority: 6
Error frequency: 1.
Lost Count: 181
Mileage: 43,432 km
Date: 2016.12.13
Time: 07:09:43
Voltage at terminal 30: 14.1 V.
End----------------------------(Duration: 03:44)-----------------------------
Log-GOLF 7 - ROLAND-WVWZZZAUZFP085531-49229km-G7-Roland.txt
 File name:  Log-GOLF 7 - ROLAND-WVWZZZAUZFP085531-49229km-G7-Roland.txt
 File size:  12.3 KB
 Downloaded:  849 times
Touareg V10 TDI (AYH)
Translated on 17-07-2026, 7:33.
Post14-02-2017, 23:35    Subject: Bleed diesel filter Volkswagen Golf 7 - 1.6 TDI Quote
Hello Alevuz,
"So far, I've been doing it this way: I change the filter, then use a 1.5-liter syringe (yes, they exist) to inject diesel into the filter until it's full. I reattach the hoses and then turn the ignition on and off five times. Only after that do I try to start the engine, and so far, this method has worked perfectly."
Unfortunately, these additions are necessary due to emissions regulations, but I'm sure these vehicles will still be able to reach 300,000 kilometers.
The timing belt needs to be replaced at 300,000 km icon_eek.gif, of course, it's not as loose as on older, much simpler cars.
Translated on 17-07-2026, 7:34.
No new posts Fuel system bleeding - Audi A4 3.0 TDI BKN Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bleed Diesel Filter: How To & Why Diesel Engine Technology
No new posts Golf 1 GTD: Bleed Fuel System - How To Diesel Engine Technology
No new posts Golf VII GTI: Bleed Cooling System with VCDS On-Board Diagnostics (OBD)
No new posts Bleed Brakes: DIY Guide & Tips Transmission, Chassis, Body & Interior
