Parking Heater: Incorrect/Missing Initial Settings
Schmierpfote
Karma: +21 / -0   Thank you, like it!
Post14-05-2017, 14:52    Subject: Parking Heater: Incorrect/Missing Initial Settings Quote
Hello everyone in the forum,
I'm having another problem with my Touran 1.9 TDI, engine code BLS, manufactured in June 2010.
Exhaust fumes inside the car. Turbo and DPF are new. No leaks can be detected.
As far as I can tell, the AGR radiator is still the first one and appears to be leak-free.
Before I remove the AGR cooler for a closer inspection, I want to address the error codes from the VCDS scan. The water pump was replaced in December, and I bled the system and started the engine using VCDS, and everything seemed okay at that time.
Two weeks ago, my driver reported a large cloud of smoke coming from under the Touran, similar to what you'd see with a clogged catalytic converter. Please review the scan data.
Thank you for your help, Wolfgang.
Log-NM 18-WVGZZZ1TZAW097744-310300km.txt
 File name:  Log-NM 18-WVGZZZ1TZAW097744-310300km.txt
 File size:  11.68 KB
 Downloaded:  614 times
Translated on 06-09-2026, 7:26.
Back to top Profile PM Email
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2 Throttle Body, cannot set default settings Gasoline Engine Technology
No new posts Brake Electronics: Incorrect or No Calibration On-Board Diagnostics (OBD)
No new posts VW Auxiliary Heater Not Working - Troubleshooting Transmission, Chassis, Body & Interior
No new posts Fuel Injection Timing Off? Diesel Engine Technology
