Off-Road Vehicles: Explanation and Features
donalexo
Post30-06-2003, 22:27    Subject: Off-Road Vehicles: Explanation and Features Quote
Hello fellow experts!
Can someone explain to me precisely what the term "vehicles with off-road equipment" means within the VAG group?
What suspension modifications are included? Which vehicles are equipped with this as standard?
Thank you for your helpful and informative responses.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 20-10-2026, 23:46.
Gremlin
Post30-06-2003, 22:38    Subject: Off-Road Vehicles: Explanation and Features Quote
I can only speak from experience with my colleague's Passat:
It sits a bit higher and has a pseudo-underbody protection (sorry, I don't trust that plastic part).
It drives like an oil tanker on the rails.
...stays in the forest, but doesn't get stuck right away...
I still advise against it...
edit:
VW writes it like this:
Off-road suspension.
Off-road suspension > reinforced suspension > stiffer damper tuning.
Engine protection cover
CU Gremlin.
Translated on 20-10-2026, 23:48.
DaBibo
Post06-07-2003, 10:24    Subject: SEO: Best Practices for Ranking Higher on Google Quote
However, the protection for the traction motor is a metal plate, not a plastic casing.
Translated on 20-10-2026, 23:49.
Manuel Thomas
Post06-07-2003, 13:43    Subject: Off-Road Vehicles: Explanation and Features Quote
I have these strange side skirt extensions on my A4.
Photo at: http://members.void.at/wuze60/yabbse/index.php?board=7;action=display;threadid=187
Manuel.
No new posts VAG Vehicles 2002: Coolant Leak Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Erwin - Looking for a repair manual for VAG vehicles Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Looking for an explanation for a DPF error. Diesel Engine Technology
This topic is locked, you cannot edit or reply. Explanation of MWB 4 at PD-ASZ (Synchronization Angle)? On-Board Diagnostics (OBD)
No new posts Short Circuit Error Code Explained On-Board Diagnostics (OBD)
No new posts K&N Air Filter: Explained & Reviewed Diesel Engine Technology
