Which engine control unit (ECU) and which version do I need?
Here is the complete scan.
Wednesday, April 5, 2017, 9:19:42 PM: 60845
VCDS – a Windows-based VAG/VAS emulator – runs on Windows 8 x64.
VCDS version: RKS 17.1.2.0
Data as of: 20170131 DS267.1
Dealer/Workshop name: 7601150907381
Vehicle Identification Number (VIN): WVWZZZ1KZBP134824 License plate:
Vehicle type: 1K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 77
Vehicle Identification Number (VIN): WVWZZZ1KZBP134824. Mileage: 96,660 km.
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate control/heating unit - Status: OK.
09-Central Electrical System -- Status: OK.
Parking Assist System 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-door electric driver -- Status: OK 0000
Steering assist - Status: OK 0000.
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
56-Radio -- Status: OK 0000
77-Phone -- Status: OK 0000
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Feld und lässt das Gras sanft wiegen. Es ist ein wunderschöner Tag."
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze blows through the field, causing the grass to sway softly. It's a beautiful day.
Address 01: Engine Control Module (ECM)
Label file: DRV\03C-906-027-CAV.clb
Part number SW: 03C 906 027 BS, HW: 03C 907 309 B.
Component: MED17.5.5 G 0173
Revision: LAH16--- Serial Number:
Encoding: 0000072
Operating number: WSC 00028 028 00001
VCID: 73E27D6A125885D9EE-8026
No error codes found.
Readiness: 0000 0000
Address 03: Brake Electronics (J104)
Label file: DRV\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 BE, HW: 1K0 907 379 BE.
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Encoding: 143B600D092500FE281306E6901D0040310000
VCID: 76E4447EC12A90F1C9-8022
Address 08: Climate Control/Heating Unit (J255)
Label file: DRV\5K0-907-044.clb
Part number SW: 5K0 907 044 EA, Part number HW: 5K0 907 044 EA.
Component: Climatronic H17 1010
Revision: 00003001
Encoding: 0000000002
Operating number: WSC 00028 028 00024
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 6ED46C1EB17AA83101-803A
Address 09: Central Electronics (J519)
Label file: DRV\1K0-937-08x-09.clb
Part number SW: 1K0 937 086 H, HW: 1K0 937 086 H.
Part number: BCM PQ35 M 103 0615.
Revision: 00103 AD
Encoding: 47180A3A88251A0040080080740081E443710088736D8D60648000200040
VCID: 356683729CACDBE900-8060
Subsystem 1 - Part number: 5K1 955 119
Label file: DRV\1KX-955-119.CLB
Part number: Wiper blade 08021 26 0512.
Encoding: 009795
Subsystem 2 - Part number: 1K0 955 559 AH
Label file: DRV\1K0-955-559-AG.CLB
Component: RLS 180211 05 54 0403
Encoding: 0330AD
Address 10: Parking Assist 2 (J791)
Label file: DRV\1T0-919-475.clb
Part number SW: 1T0 919 475 P, HW: 3T0 919 475 C.
Component: PARKING ASSIST PLA H08 0116
Revision: -------- Serial Number: 13991103481802
Encoding: 10800A
VCID: 4898FA86FB5E56016B-801C
Address 15: Airbag (J234)
Label file: DRV\5K0-959-655.clb
Part number SW: 5C0 959 655 B, HW: 5C0 959 655 B.
Part number: Airbag VW10, 013 0613.
Serial number: 003G5RA13BVL
Encoding: 00003947
Operating number: WSC 00028 790 00055
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 316EB76260C4F7C95C-8064
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME5E51415BZZZ$.
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sensor, Front, Part No. H01.
Serial number: 3582MSME7F11545BZZZ0.
Rear side airbag crash sensor (driver's side).
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME62140801ZZZD
Rear side airbag crash sensor, passenger side.
Component: Side Sensor, Front, Right --- ----
Serial number: 3522QSME42470831ZZZL
Address 16: Steering wheel electronics (J527)
Label file: DRV\5K0-953-569.clb
Part number SW: 5K0 953 507 BA, HW: 5K0 953 549 C.
Component: Steering module 008 0080.
Revision: -------- Serial Number: 90440KBL000GJ
Encoding: 5080140000
ASAM Dataset: EV_SMLSNGKUDS A05001
FILE: EV_SMLSNGKUDS_VW32.rod
VCID: 70E87266AB4EBEC113-8024
Address 17: Control panel module (J285)
Label file: DRV\5K0-920-xxx-17.clb
Part number SW: 5K0 920 871, HW: 5K0 920 871.
Component: COMBINATION H20 0420
Serial number: 00000000000000
Encoding: 170F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 6BD2650A82685D1926-803E
Address 19: Diagnostic interface (J533)
Label file: DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 C, HW: 1K0 907 951.
Component: J533 Gateway H37 0614.
Revision: H37 Serial Number: 190211F2003380
Encoding: 350000
VCID: 3068B26663CEFEC153-8064
Address 25: Immobilizer (J334)
Label file: DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234, HW: 5K0 953 234.
Component: IMMO H20 0420
Serial number:
Encoding: 000000
Operating number: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADC600E8D9244115D-803E
Address 2E: Media Player 3 (J650) Label file: DRV\5N0-035-342.lbl
Part number SW: 5N0 035 342 D. Part number HW: 5N0 035 342 D.
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial Number: 7669456721
Encoding: 010000
VCID: 28585A065B1EB6018B-807C
Address 42: Door electric driver
Label file: DRV\1K0-959-701-MIN3.lbl
Part number SW: 5K0 959 701 D. Part number HW: 5K0 959 701 D.
Component: Door seal 009 2149
Coding: 0000052
VCID: 3362BD6A52D8C5D92E-8066
Address 44: Steering Assist
Label file: DRV\1Kx-909-14x-44.clb
Part number: 1K0 909 144 M
Component: EPS_ZFLS, Size 69 3201
Revision: 00H20000
VCID: 3460BE7657D6C2E137-8060
Address 52: Power door lock, front passenger side.
Label file: DRV\1K0-959-702-MAX3.lbl
Part number SW: 5K0 959 702 E, Part number HW: 5K0 959 702 E.
Coding: 0000308
VCID: 356683725CACDBE900-8060
Address 56: Radio (J503) Label file: DRV\5M0-035-1xx-56.clb
Part number SW: 1K0 035 186 AA, Hardware part number: 1K0 035 186 AA.
Part number: Radio RCD310, 016 0049.
Revision: 00000000 Serial Number: VWZ1Z2L9152494
Encoding: 0100040004
VCID: 65C613326C8C6B6970-8030
Address 77: Phone (J412)
Label file: DRV\7P6-035-730.clb
Part number SW: 5K0 035 730 F, HW: 5K0 035 730 F.
Component: TELEPHONE H09 2902
Revision: 1B001001 Serial Number: 00007666817432
Encoding: 0100000000010110
Operating number: WSC 52399 001 1048576
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 28585A06531EB6018B-807C
End----------------------------(Duration: 02:0
