vag-driver Profi-Schrauber
24-04-2017, 22:56 Subject: ABS Light On: VW Polo 6N1 Troubleshooting |
The ABS light in my wife's Polo has been constantly illuminated since today.
Monday, April 24, 2017, 20:48:54:19385
VCDS â A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS version: RKS 17.1.3.0
Data as of: 20170224 DS267.4
Vehicle Identification Number:
License Plate:
Mileage: 310030 Repair order:
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BĂ€umen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag fĂŒr einen Spaziergang."
Vehicle type: 6N - Volkswagen Polo (1995 > 2002)
Scan: 01 02 03 08 15 17 19 25 41 45 46 55 56
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Unit (ECU)
Label file: 032-906-030-AEE.lbl
Part number: 032 906 030 P
Component: MARELLI 1AV 2136
VCID: 173BFD5975C61DF938-4B32
No error codes found.
Readiness: Not Available.
Address 03: Brake Electronics; Label file: DRV\1J0-907-37x-ABS.lbl
Part number: 1J0 907 379.
Component: ABS ITTAE 20 GI V00
Encoding: 01901
Operating number: WSC 01901
VCID: 6ED5F8BD2ADCBC310B-4AB4
"One error found:"
01276 - ABS hydraulic pump (V64)
16-00 - Signal out of tolerance.
Address 15: Airbag
Label file: DRV\6N0-909-60x-VW2.lbl
Part number: 6N0 909 603 T
Part: AIRBAG VW2 V00
Coding: 00084
Operating number: WSC 00042
VCID: 4383790951DE6159B4-4B96
Address 25: Immobilizer
Label file: DRV\1H0-953-257.lbl
Part number: 1H0 953 257 B
Part number: IMMO VWZ3Z0T3024144 V00
Coding: 09600
Operating number: WSC 00000
VCID: 2A5D34ADD6B4901197-4B18
End----------------------------(Duration: 03:06)-----------------------------
Yesterday, the message was still appearing sporadically.
Address 03: Brake electronics Label file: DRV\1J0-907-37x-ABS.lbl
Encoding: 01901
"One error found:"
16-10 - Signal out of tolerance - Intermittent
The fuse on the cable is fine. What else should I check to make sure that the pump is actually defective? Viele GrĂŒĂe
Andreas
*** Ein Ingenieur muss vordenken. Wenn er anfÀngt nachzudenken ist es schon zu spÀt. ***
Translated on 01-08-2026, 0:26.
25-04-2017, 7:24 Subject: ABS Light On: VW Polo 6N1 Troubleshooting |
"Addendum:"
This morning, the light went out again after starting. However, it turned back on when I reached a speed of over 20 km/h and has remained on since then. Viele GrĂŒĂe
Andreas
Translated on 01-08-2026, 0:36.
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
25-04-2017, 8:56 Subject: ABS Light On: VW Polo 6N1 Troubleshooting |
Step 1 would be to check the fuses for the ABS system (are they blown?), and Step 2 would be to check the control unit or pump.
Translated on 01-08-2026, 0:37.
Profile PM WWW Garage |
25-04-2017, 10:07 Subject: ABS Light On: VW Polo 6N1 Troubleshooting |
"To answer question number 1."
Unfortunately, there is no wiring diagram available for this model on Erwin. Therefore, I could only examine the obvious fuse. Can anyone provide me with a wiring diagram so that we can check all the relevant fuses/relays?
"Please provide me with the text you would like me to translate."
VCDS did not allow the basic setting to be performed. This is probably because of the error message that reappears immediately after being cleared. Viele GrĂŒĂe
Andreas
Translated on 01-08-2026, 0:38.
Mpire Profi-Schrauber
Joined: 10/19/2009 Posts: 351 Karma: +192 / -0 Location: Oberpfalz 2019 Skoda Octavia Premium Support
Turbinchen likes this. |
25-04-2017, 20:17 Subject: ABS Light On: VW Polo 6N1 Troubleshooting |
Hello.
Forget the pump; the error indicates a faulty sensor ring on the rear axle. It's not the sensor itself, but the ring (part number 191614149) on the hub that rotates.
Why I say that.
Because our Lupo TDI had exactly this problem for a long time (about a year).
After restarting, the error disappeared, but it reappeared at a speed of slightly over 20 km/h, just like with you.
I tried replacing all sorts of things without success, but it wasn't until I replaced the rear right wheel bearing that I noticed the damage to the ring. After replacing the entire hub, including the ring, the problem disappeared and never came back.
"Our Lupo has drum brakes on the rear. The adjuster wedge had become stuck and seized up... Now, when you pull the handbrake, the lever where the cable is attached moves too much and rubs against the sensor ring."
Consequently, the small gaps in the ring are compressed, and the wheel speed signal is no longer accurate.
This can also happen due to the accumulation of metallic debris or corrosion of the ring caused by age.
Of course, it could also be on the front, since the ring is also made of thin sheet metal, which is prone to rusting away.
To make your search easier, use VCDS. First, go to the ABS control unit and find the measuring block where you can see the four fields representing all four speeds. Start the engine, start driving, and begin at a slow speed, gradually increasing the speed.
The good signals are consistent and rise synchronously, while the value of the faulty ring fluctuates sporadically and usually lags behind.
The ring is available individually under the part number listed above for âŹ8-10, but I would always recommend replacing both at the same time.
Regards, Mpire. fehlen Dir die Worte, entscheiden die Taten!
Translated on 01-08-2026, 0:40.
Profile PM Garage |
25-04-2017, 20:23 Subject: ABS Light On: VW Polo 6N1 Troubleshooting |
I'm curious about that.
Translated on 01-08-2026, 0:43.
26-04-2017, 8:39 Subject: ABS Light On: VW Polo 6N1 Troubleshooting |
@ Mpire
Thank you for your detailed explanation. The ABS light is now constantly on and won't turn off. I will hopefully investigate it over the weekend and let you know what I find. Viele GrĂŒĂe
Andreas
28-04-2017, 22:16 Subject: ABS Light On: VW Polo 6N1 Troubleshooting |
The ABS light is off. The error seems to have disappeared on its own, as I haven't had a chance to look into it yet.
Despite that, I removed the connector from the control unit to take a look at the contacts. Everything looks perfectly clean and shiny.
The error memory could be cleared, and the error no longer appears. I'm curious to see if it stays that way. Viele GrĂŒĂe
Andreas
Translated on 01-08-2026, 0:44.
