Golf 6 TDI: VCDS Scan & Review
maxm3
Post10-06-2017, 21:34    Subject: Golf 6 TDI: VCDS Scan & Review Quote
I would like to buy this Golf for my nephew.
What do you think about the error messages?
Thank you very much!
Saturday, June 10, 2017, 7:50:32 PM: 35427
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x86.
VCDS Version: RKS 17.1.2.0
Data as of: 20170131 DS267.1
Vehicle Identification Number: WVWZZZ1KZAW107951 License Plate:
Vehicle type: 1K (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
Mileage: 154,860 km
01-Motor electronics -- Status: Error 1010.
03-Brake electronics -- Status: Error 0010.
04-Steering angle sensor -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: Error 0010.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block module -- Status: Error 0010.
19-pin diagnostic interface -- Status: Error 0010.
Immobilizer system -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: Error 0010.
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
56-Radio -- Status: Error 0010.
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module (J623-CAYC)
Label file: DRV\03L-906-023-CAY.clb
Part number SW: 03L 997 557 M, HW: 03L 906 023 A.
Part: R4 1.6L TDI H23 9983
Revision: --H23--- Serial Number: 00000000000000
Encoding: 00114016030400080000
Operating number: WSC 01357 011 00200
ASAM Dataset: EV_ECM16TDI02103L997557M 003003
ROD: EV_ECM16TDI02103L906023DB.rod
VCID: 468498C5F92D8E7199-8012
2 error codes found:
7337 - Exhaust gas recirculation system.
P0401 00 [237] - Insufficient flow.
Warning light ON - confirmed - checked since last reset.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 5
Mileage: 154729 km
Date: 2017.06.06
Time: 22:59:12
Motor speed: 1292.25 rpm.
Normalized load value: 12.2%
Vehicle speed: 35 km/h
Coolant temperature: 64 °C
Intake air temperature: 18 °C
Atmospheric pressure: 980 millibars.
Voltage at terminal 30: 14.118 V.
Lost learning counter via OBD: 40.
Air mass: Target value - MAF_SP_MMV: 283.71 mg/stroke.
Air mass: Actual value (mg/stroke) - MAF_MEASURED: 416.647 mg/stroke.
Exhaust gas recirculation valve: Current value - ANG_EGRV[0]: 84.772 %.
Throttle valve actuator: Actual value - ANG_THR[0]: 95.996 %
Boost pressure: Target value - MAP_SP_MMV: 1070.96 hPa.
Boost pressure: Actual value - MAP_MMV: 1072.95 hPa.
Motor torque - TQI_SP: 33.66 Nm
7563 - Exhaust gas recirculation (EGR) valve, donor part 1.
P046C 00 [237] - Implausible signal.
Error priority: 2
Error frequency: 1.
Mileage: 154,701 km
Date: 2017.06.06
Time: 17:39:12
Motor speed: 1673.50 rpm.
Normalized load value: 49.0%
Vehicle speed: 6 km/h
Coolant temperature: 96 °C.
Intake air temperature: 49 °C
Atmospheric pressure: 970 millibars.
Voltage at terminal 30: 13.553 V.
Exhaust gas recirculation valve: Actual value - ANG_EGRV[0]: 3.760 %.
Exhaust gas recirculation valve: Control signal - ANG_SP_EGRV[0]: 0.000 %
High-pressure exhaust gas recirculation control: Control signal - PWM_HBR_EGRV[0]: -20.300 %
Exhaust Gas Recirculation (EGR) High-Pressure Control Valve: Measured value of raw voltage - V_EGRV[0]: 1.396 V.
Exhaust gas recirculation valve: Offset closed - V_EGRV_BOL[0]: 1.299 V
Exhaust gas recirculation valve: Offset open - V_EGRV_TOL[0]: 3.999 V.
Exhaust Gas Recirculation (EGR) High-Pressure Valve: Status - LF_STATE_EGRV_DISP[0]: 76.
Readiness: 1 2 0 0 0
Address 03: Brake Electronics (-----)
Label file: DRV\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 AN, Hardware number: 1K0 907 379 AN.
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Encoding: 113B200D09220001881404E9901A00403000
VCID: 7EF43025E97D16B191-802A
"One error found:"
01314 - Engine Control Unit.
004 - No signal/communication - Intermittent.
Error status: 00100100
Error priority: 2
Error frequency: 1.
Lost Count: 135
Mileage: 154,695 km
Time: 0.
Date: 2011.10.25
Time: 16:06:43
Quantity: 0
Quantity: 0
Quantity: 4608
Quantity: 8194
Quantity: 43776
Quantity: 0
Quantity: 0
Quantity: 0
Address 08: Climate Control/Heating (J255)
Label file: DRV\5K0-907-044.clb
Part number SW: 5K0 907 044 BD, Part number HW: 5K0 907 044 BD.
Component: Climatronic. Part number: H14 0608.
Revision: 00003001
Encoding: 0000000000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 6ED40065B11D663101-803A
13701376 - Functionality restriction due to missing message.
U1111 00 [008] - -
Sporadically - confirmed - checked since last deletion.
Error priority: 6
Error frequency: 7
Lost Count: 135
Mileage: 154,695 km
Date: 2017.06.03
Time: 16:06:43
13701936 - Functionality impaired due to received error value.
U1113 00 [008] - -
Error priority: 6
Error frequency: 1.
Lost Count: 122
Mileage: 153,193 km
Date: 2017.05.15
Time: 16:22:01
Address 09: Central Electronics (J519)
Label file: DRV\1K0-937-08x-09.clb
Part number SW: 1K0 937 084 B, HW: 1K0 937 084 B.
Part: BCM PQ35 B 103 0541
Revision: 00103 AE
Encoding: 40180A3A98251AC040000080500000E443010088724D8560648000200000
VCID: 2D56C769749B5D2978-8078
Subsystem 1 - Part number: 1K1 955 119 E
Label file: DRV\1KX-955-119.CLB
Component: Wiper 14080 21 0501
Encoding: 009795
02195 - Lighting control - Switches and instruments (E20)
002 - Lower limit exceeded - Intermittent.
Error status: 00100010
Error priority: 5.
Error frequency: 16
Lost Count: 134
Mileage: 153,192 km
Time: 0.
Date: 2011.10.06
Time: 16:18:60
Class 15, entry.
Voltage: 14.00 V
one
one
Size 50, SOLD OUT.
text
aus
text
out
text
from
Error priority: 5.
Error frequency: 16
Lost Count: 134
Mileage: 153,192 km
Time: 0.
Date: 2011.10.06
Time: 16:18:60
Address 10: Parking Assist 2 (J446)
Label file: DRV\3C8-919-475.clb
Part number SW: 5K0 919 475 C, HW: 5K0 919 475
Part: PARKING ASSIST 8K H07 0008
Revision: -------- Serial Number: 12940920904241
Encoding: 100001
VCID: 3664E80581CD1EF109-8062
No error codes found.
Address 15: Airbag (J234)
Label file: DRV\5K0-959-655.clb
Part number SW: 5K0 959 655. Part number HW: 5K0 959 655.
Component: Airbag VW10, Part Number: 035 0604.
Serial number: 003C2RA284K2
Encoding: 00003139
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 77FA2501CE4727F9D2-8022
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sens.Fahr.V H01 ----
Serial number: 1A42014AZZZZZZZZZZZZ
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sens.Front.Right H01 ----
Serial number: 660D634AZZZZZZZZZZZZ
Rear side airbag crash sensor (driver's side).
Component: S.Sens.Fahr.H --- ----
Serial number: 1418316EZZZZZZZZZZZZ
Crash sensor for rear side airbag, passenger side.
Component: S.Sensor, Passenger Side, Front.
Serial number: 3028336BZZZZZZZZZZZZ
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY9.lbl
Part number SW: 1K0 953 549 CQ
Part number HW: 1K0 953 549 CQ
Component: J0527 053 0111
Encoding: 0000004
VCID: 030241D1429F7B59FE-8056
Address 17: Control panel module (J285)
Label file: DRV\5K0-920-xxx-17.clb
Part number SW: 5K0 920 860 G, HW: 5K0 920 860 G.
Component: KOMBI H06 0206
Serial number: 00000000000000
Encoding: 170F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 3068DE1D6BA930C153-8064
1416448 - Oil level/temperature sensor.
B1041 29 [008] - implausible signal.
Error priority: 2
Error frequency: 2.
Lost Count: 130
Mileage: 154,264 km
Date: 2017.05.30
Time: 15:40:47
12648448 - Functionality restriction due to missing message.
U1111 00 [008] - -
Error priority: 6
Error frequency: 4
Lost Count: 135
Mileage: 154,695 km
Date: 2017.06.03
Time: 16:06:43
Address 19: Diagnostic interface
Label file: DRV\1K0-907-530-V4.clb
Part number SW: 1K0 907 530 AA, HW: 1K0 907 951.
Component: J533, Gateway, H16 5223.
Revision: H16 Serial Number: 4120K09819081E
Encoding: E9A07F06000202000002
VCID: 66C4784551EDAE7179-8032
"One error found:"
Error priority: 2
Error frequency: 4
Lost Count: 135
Mileage: 154,695 km
Time: 0.
Address 25: Immobilizer (J334)
Label file: DRV\5K0-920-xxx-25.clb
Component: IMMO H06 0206
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 42: Door electric, driver.
Label file: DRV\1K0-959-701-MIN3.lbl
Part number SW: 5K0 959 701 B. Part number HW: 5K0 959 701 B.
Component: Door seal 009 2109
Encoding: 0000180
VCID: 316EDB19A8A339C95C-8064
Address 44: Steering Assist
Label file: DRV\1Kx-909-14x-44.clb
Part number: 1K0 909 144 H
Component: EPS_ZFLS, Size 69 2901
Revision: 00H17000
VCID: 2F6ADD61BE972F394A-807A
"One error found:"
Error priority: 3
Error frequency: 4
Lost Count: 135
Mileage: 154,695 km
Time: 0.
Date: 2011.10.25
Time: 16:48:13
Voltage: 12.13 V
YOU.
Temperature: 25.0°C
Speed: 1498 RPM
Speed: 0.0 km/h
Speed: 0.0 km/h
Quantity: 0
Address 52: Power door lock, front passenger side.
Label file: DRV\1K0-959-702-MAX3.lbl
Part number SW: 5K0 959 702 E, HW: 5K0 959 702 E.
Component: Door seal 009 2123
Encoding: 0000436
VCID: 3566EF095CCB15E900-8060
Address 56: Radio (J503) Label file: DRV\5M0-035-1xx-56.clb
Part number SW: 1K0 035 156 B HW: 1K0 035 156 B
Component: Radio 509 0521
Revision: R0509004 Serial Number: VWZ5Z1I0129913
Encoding: 0000020002
VCID: 224C24553D459251D5-8076
"One error found:"
00870 - Front left bass speaker (R21)
011 - Interruption - Sporadic.
Error status: 00101011
Error priority: 5.
Error frequency: 6.
Lost Count: 126
Mileage: 151,227 km
Time: 0.
Date: 2011.08.29
Time: 12:12:47
Address 62: Door electric, left/right.
Label file: DRV\1K0-959-703-GEN3.lbl
Part number SW: 5K0 959 703 C. Hardware: 5K0 959 703 C.
Component: Door Seal 007 2101
Encoding: 0000144
Operating number: WSC 01357 011 1012552
VCID: 3460D20D57B10CE137-8060
Address 72: Door electric strike, right side.
Label file: DRV\1K0-959-704-GEN3.lbl
Part number SW: 5K0 959 704 C. Hardware: 5K0 959 704 C.
Encoding: 0000144
End----------------------------(Duration: 02:23)-----------------------------
Translated on 08-10-2026, 8:08.
Post10-06-2017, 22:29    Subject: Golf 6 TDI: VCDS Scan & Review Quote
The AGR module is standard on the 1.6 engine. Unfortunately, the effort required to replace it is quite high, so the repair cost can range from around 700€ to 1000€, depending on the workshop and region.
The rest are minor issues, and most of them are likely side effects of the AGR.
Translated on 08-10-2026, 8:09.
Karma: +807 / -0   Thank you, like it!
Post11-06-2017, 10:49    Subject: Golf 6 TDI: VCDS Scan & Review Quote
Hi.
1416448 - Sender for oil level/temperature.
Sporadically - confirmed - checked since the last deletion
It could also be a loose connection or damage caused by rodents to the cable, which was the case with my wife's A3.
The oil level sensor is located at the bottom of the oil pan, and it is easily accessible after removing the underbody panel.
011 - Interruption - Sporadically
I haven't had to do anything to my car since it reached approximately 200,000 km because it's been running perfectly silently.
Translated on 08-10-2026, 8:10.
maxm3
Post11-06-2017, 11:57    Subject: Golf 6 TDI: VCDS Scan & Review Quote
Thank you for the answers!
Translated on 08-10-2026, 8:12.
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Today I was in customer service - read out the measuremen... Diesel Engine Technology
No new posts Passed Emergency AU Exam Today? Diesel Engine Technology
No new posts Audi A3: Low Power? Diagnose & Troubleshooting On-Board Diagnostics (OBD)
No new posts Golf 7 VCDS: Troubleshooting Access Issues On-Board Diagnostics (OBD)
