Euro 5 Diesel: MSG Update reveals cheating?
Georg_G
2012 Volkswagen Golf
Post23-06-2017, 17:22    Subject: Euro 5 Diesel: MSG Update reveals cheating? Quote
Hello everyone,
I bought a used 2.0 TDI CFHC model year 2012.
Can I use VCDS to check if the software update for reduced NOx emissions has already been installed?
Here is the excerpt from the Autoscan:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module (J623-CFHC)
Label file: DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 AN, Part number HW: 03L 907 309 R.
Part: R4 2.0l TDI H25 9979
Revision: 42H25--- Serial number: 00000000000000
Encoding: 00190012042400080000
Operating number: WSC 51781 186 12345
ASAM Dataset: EV_ECM20TDI01103L906018AN 003012
ROD: EV_ECM20TDI03L906018AM.rod
VCID: 76CCBF79C9A97BF1C3-8022
No error codes found.
Readiness: 0 0 0 0 0
Best regards, Georg.
Translated on 18-09-2026, 17:14.
chli1976
dieselschrauber likes this.
Post23-06-2017, 19:53    Subject: Euro 5 Diesel: MSG Update reveals cheating? Quote
9979 should be the NOx software.
VCDS
Translated on 18-09-2026, 17:16.
Wirus
Post23-06-2017, 22:10    Subject: Euro 5 Diesel: MSG Update reveals cheating? Quote
You could also simply check the FIN (Financial Identification Number) to see if the update has been applied or not.
http://info.volkswagen.de/de/de/home.html
Karma: +594 / -0   Thank you, like it!
Post23-06-2017, 22:17    Subject: Euro 5 Diesel: MSG Update reveals cheating? Quote
Hello!
I haven't seen it myself yet.
However, in the media, it was reported that a sticker would be attached to the trunk floor with the update.
Translated on 18-09-2026, 17:17.
Post24-06-2017, 6:59    Subject: Euro 5 Diesel: MSG Update reveals cheating? Quote
Where do you buy your cars? Is there no documentation or service booklet available? That would certainly make me suspicious.
If there's no information available, I would suggest contacting VW to inquire about the vehicle's history, if any records exist.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post24-06-2017, 8:39    Subject: Euro 5 Diesel: MSG Update reveals cheating? Quote
The stickers for the spare tire compartment are only available from Skoda; VW and Audi no longer supply them.
Normally, a note should be made on the last pages of the service booklet, but unfortunately, this is often forgotten.
As mentioned before, simply drive to the next car dealership with the VIN and they can identify it within seconds.
Translated on 18-09-2026, 17:18.
Karma: +805 / -0   Thank you, like it!
Post25-06-2017, 16:05    Subject: Euro 5 Diesel: MSG Update reveals cheating? Quote
As a general rule, a note should be made on the last pages of the service booklet, but unfortunately, this is often forgotten.
This was noted in the service booklet by AMAG (Audi Importer Switzerland).
Translated on 18-09-2026, 17:19.
Georg_G
Post25-06-2017, 20:37    Subject: Euro 5 Diesel: MSG Update reveals cheating? Quote
Thank you all for the many answers.
The link from Wirus.
It provided clarification. My car is registered there with an exhaust treatment measure, which probably refers to the update.
There's no sticker in the trunk in my car.
The service booklet is also blank. The last service was in the summer of 2016 at 120,000 km and was normally stamped.
Here's a summary for the CFHC:
Component: R4 2.0l TDI H25 9979 indicates an NOx update.
The car regenerates energy every 200 km with a 50%/50% mix of rural and city driving, and it can sometimes go up to 400 km on longer highway trips. I found these intervals to be a bit short, so I inquired about them. Based on everything I could find (or not find) on the internet, this seems to be consistent with the new software version.
Translated on 18-09-2026, 17:20.
haithamina
Post26-06-2017, 10:37    Subject: Euro 5 Diesel: MSG Update reveals cheating? Quote
In my B8, all service measures were documented both in the service booklet and with stickers inside the spare tire compartment.
haithamina
Translated on 18-09-2026, 17:22.
klahaui
Avatar-klahaui
Post26-06-2017, 12:37    Subject: Euro 5 Diesel: MSG Update reveals cheating? Quote
That's surprising, I used to work as a service advisor at Audi until recently. We never received any stickers, and I sometimes forgot to make certain entries.
Translated on 18-09-2026, 17:23.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. ASZ TDI Euro 3: AGR Valve Replacement & Deactivation Diesel Engine Technology
This topic is locked, you cannot edit or reply. AGR Deactivation: Where to Find Setting? On-Board Diagnostics (OBD)
No new posts TDI Tuning: Performance Upgrade for 10 Euros Diesel Engine Technology
No new posts GRA Lever: €86 - Is It Worth It? Diesel Engine Technology
