Audi A4 B5, ABS/Dashboard insert electrical connection
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post11-07-2017, 17:47    Subject: Audi A4 B5, ABS/Dashboard insert electrical connection Quote
Hello everyone,
My Audi (VIN: PD-AJM, see signature), see signature, is causing me some frustration...
Sporadically, the ABS symbol, the ASR symbol, and the "red" brake symbol appear intermittently (approximately once a month) in the FIZ, accompanied by approximately three beeps.
Initially, it appeared about 3 months ago (without any error logs), and today it has occurred 2 times (but with error logs).
Noteworthy: This happened twice today, with me being slightly leaning to the left and at a slight angle, and with the current weather conditions, I was quite warm.
Is this (hopefully) a well-known error?
Options:
-ABS Control Unit
-Cable break
-AI has a path (which wouldn't be so far-fetched, given the Jaeger AIs)
1 Error found:
01203 - ABS/Control Unit Electrical Connection
03-10 - No signal - Sporadically
P.S.:
The recorded mileage does not match; it has been replaced before, and the vehicle has approximately 410000 km... icon_twisted.gif
Log-242910km.txt
 File name:  Log-242910km.txt
 File size:  3.53 KB
 Downloaded:  669 times
klahaui
Avatar-klahaui
2019 Volkswagen Golf
dieselschrauber likes this.
Post11-07-2017, 18:16    Subject: Audi A4 B5, ABS/Dashboard insert electrical connection Quote
Good evening, could you please check the level of the brake fluid? I've found that a low level on the B5 model always resulted in the brakes being sensitive and making a "beep" sound three times.
Gremlin
Avatar-Gremlin
Post12-07-2017, 6:05    Subject: Audi A4 B5, ABS/Dashboard insert electrical connection Quote
Level can be ruled out; is max.
Was I checked first.
I mean, then only the "Brakes" symbol would appear in the FIZ, without the ABS and ASR symbols.
Regardless; I searched online, and it appears to be a common issue with Passat 3B, A4 B5, etc., which have this type of ABS.
That's the only option: exchange or repair. I'm only considering the latter option, as it's a specific type, which is less common online (ABS, ASR, EDS).
Gremlin
Avatar-Gremlin
Post21-07-2017, 11:48    Subject: Audi A4 B5, ABS/Dashboard insert electrical connection Quote
Hello everyone;
Error cause definitely found!
It is, in fact, the ABS control unit.
After researching online, I soon had certainty about the source of the problem and how to fix it.
**Introduction:**
Not suitable for beginners, and requires a VERY GOOD soldering experience, and therefore professional tools!
A little bit of trembling, and the small bonds next to the actually broken ones have come loose.
And:
If it's already open, the control unit can understandably no longer be sent for repair!
Just for illustration purposes: On the housing side, the connector is approximately 1.3mm in size, estimated.
 File size:  186.32 KB
 Viewed:  3354 times
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electric tailgate Passat B6 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Electric Folding Mirror Control Ibiza 6K1 Price Transmission, Chassis, Body & Interior
No new posts Switchboard Breaker Fault: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Service Interval Display Panel Insert On-Board Diagnostics (OBD)
