Audi A6: Unlock Immobilizer with Code via OBC
Nemo-X
Post08-10-2017, 23:47    Subject: Audi A6: Unlock Immobilizer with Code via OBC Quote
I would like to ask for your help.
I have an Audi A6 4B, model 1998, and the immobilizer is malfunctioning.
The wiring to the coil in the ignition switch is likely faulty.
(a well-known problem).
I now wanted to enter the 4-digit code via the instrument panel.
to activate the emergency start function and be able to drive.
Unfortunately, I don't know how to confirm the input at the end.
Through trial and error, I eventually entered the wrong code.
and I locked the system, and the display showed "FAIL".
The car is now with the dealer, and the failed attempt has been erased.
The immobilizer is still active.
I would like to repair the coil or cable myself and drive the car home. I have some questions about that:
- If I enter the 4-digit code via the instrument cluster, how do I confirm it?
the input at the end?
- Can the emergency start function be used an unlimited number of times, or is it limited to a certain number of uses, such as once or three times?
- If the system is locked due to incorrect input, then proceed to successfully activate the coil.
Once the system is repaired, does the lock remain in place, or is the lock released when the car is started?
I am grateful for any advice.
Translated on 09-09-2026, 8:31.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post09-10-2017, 7:34    Subject: Audi A6: Unlock Immobilizer with Code via OBC Quote
I haven't heard of this function myself, but the code is five digits long. You need to add a "0" at the beginning of your code and then press Enter.
Where did you even get the code from?
Translated on 09-09-2026, 8:33.
Nemo-X
Post09-10-2017, 12:41    Subject: Audi A6: Unlock Immobilizer with Code via OBC Quote
With the keys, you also receive a plastic tag, which you can...
"Open it, and you'll find various numbers inside."
Beneath a scratch-off field, there is a 4-digit code, which of course only applies to...
fits in a car.
If you want to enter the code using a diagnostic tool, the code must...
To make it a 5-digit number, simply add a "0" in front. For example, change 1234 to 01234.
When entering data via the instrument cluster, it remains a 4-digit display, and you can only...
Enter 4 digits.
The Model 2 has two switches on the instrument panel, one on the left for adjusting the...
Analog clock, located on the right side for displaying daily mileage/distance traveled.
If you pull left and hold, then press right and hold, the field will change.
For the daily mileage, you can enter the code there.
The left switch advances to the next field, while the right switch...
Enter the numbers.
I'm just having trouble with saving it at the end.
ATTENTION: If anyone wants to try this, please be careful when entering the information.
If an incorrect code is entered, the WFS will be locked. I don't know if it's still possible to start the vehicle using the key after that. Disconnecting the battery will not remove the lock.
Translated on 09-09-2026, 8:35.
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unlock/Enable the Audi A3's outside temperature display Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Activate AHK on Audi A4 B8 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Unlock TV on Audi A8: Easy Guide Transmission, Chassis, Body & Interior
No new posts MMI Plus: Unlock Audi A6 (4G) Hidden Menu Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A3 Immobilizer Malfunction: Fix It Now! Diesel Engine Technology
