Faulty Glow Plug: VW 2.5 TDI BDG Issues
Sollten alle Glühkerzen getauscht werden, wenn eine defekt ist?
Ja, es sollten alle getauscht werden
100%
 100%  [ 5 ]
Nein, es reicht die defekte zu tauschen
0%
 0%  [ 0 ]
Total votes : 5
netrocker
Post05-02-2018, 14:40    Subject: Faulty Glow Plug: VW 2.5 TDI BDG Issues Quote
Good day.
"The following is the initial situation:"
In my Audi A4 2.5 TDI (manufactured in October 2004) with engine code BDG, one glow plug is defective (its resistance is close to zero).
The engine has 283,000 kilometers on it. The last time all six glow plugs were replaced by Audi was at approximately 203,000 kilometers, which was in January 2014.
I asked my Audi workshop master whether it's necessary to replace all six spark plugs or just the faulty one. His answer was that only the defective one needs to be replaced for this engine type. However, it's important to use the same brand and type of spark plug.
I'm now hearing from many A4 diesel drivers that you should always replace all six spark plugs at the same time.
What do you think about this? I would really appreciate a short feedback (survey), and I'd be happy to hear your explanations as well.
"Thank you very much!"
Hi netrocker,
Translated on 23-08-2026, 7:45.
Post05-02-2018, 16:46    Subject: Faulty Glow Plug: VW 2.5 TDI BDG Issues Quote
I would base the decision on the remaining lifespan and accessibility of the remaining candles.
If the remaining spark plugs have only been used for 80,000 km and are easily accessible, I would only replace that one spark plug.
However, if everything needs to be disassembled to access the spark plugs, I would replace them all.
However, I don't know what your engine looks like.
Greetings.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 23-08-2026, 7:47.
netrocker
Post05-02-2018, 17:10    Subject: Faulty Glow Plug: VW 2.5 TDI BDG Issues Quote
So, I'm not worried about the accessibility, but rather about whether the candles are stuck and will break off when you try to remove them. As is well known, aluminum, metal, and heat are not a healthy combination icon_rolleyes.gif.
Although the spark plugs were replaced in my AUDI four years ago, and I can assume they were tightened to 8 Nm, I'm still not entirely confident. If one of them breaks off and the cylinder head needs to be removed, the cost would no longer be justified considering the car's value.
Translated on 23-08-2026, 7:48.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post05-02-2018, 20:57    Subject: Faulty Glow Plug: VW 2.5 TDI BDG Issues Quote
Hello.
A few days beforehand, apply some WD-40, and then be sure to open it while the engine is warm.
Apply the correct torque when installing it on a cold engine.
It's actually mentioned somewhere in this forum if you search for "changing spark plugs."
I would only replace the defective one.
Mfg Mpire
Translated on 23-08-2026, 7:49.
netrocker
Post12-02-2018, 11:22    Subject: Faulty Glow Plug: VW 2.5 TDI BDG Issues Quote
Thank you for the feedback!
I ended up having all 6 spark plugs replaced at the Audi dealership.
Cost: 300 Euros! icon_rolleyes.gif icon_cry.gif
I sprayed some WD-40 into the spark plug well yesterday.
The mechanics said that the spark plugs would come out easily.
Thank you very much and best regards.
Andi.
Translated on 23-08-2026, 7:51.
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Spark plug fouled! Diesel Engine Technology
No new posts Spark Plug Problem: Electrical Fault Diagnosis On-Board Diagnostics (OBD)
No new posts Glow Plug Failure Causes Engine Damage in TDI Diesel Engine Technology
No new posts Spark Plug Failure: Bosch/Beru Replacement Diesel Engine Technology
