pit.dahl
12-10-2017, 21:25 Subject: Polo 6R: Coming Home, Leaving Home, Door Lock |
Hello, I have two questions about my wife's Polo 6R (BEB-00114), which has a 66kW gasoline engine.
Is it possible to program "Coming Home" and "Leaving Home" functions using a suitable software program?
Is it possible to program the car so that the doors automatically lock when it starts moving? I'm not sure what this feature is called.
The workshop says it's not possible.
I would appreciate it if someone could answer this for me.
Thank you very much. Best regards, Pit.
Translated on 10-09-2026, 12:15.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
13-10-2017, 7:59 Subject: Polo 6R: Coming Home, Leaving Home, Door Lock |
Hello Pit,
The automatic door locking feature at speeds above 15 km/h should not be a problem. Regarding the rest, it's difficult to say much, as this requires support from the relevant control units. At least a system scan would be necessary.
Perhaps someone will come forward with a vehicle like that.
Translated on 10-09-2026, 12:16.
Profile PM WWW Garage |
pit.dahl
13-10-2017, 8:24 Subject: Polo 6R: Coming Home, Leaving Home, Door Lock |
dieselschrauber wrote: | Hello Pit,
The automatic door locking feature at speeds above 15 km/h should not be a problem. Unfortunately, we can't say much about the rest, as this requires support from the relevant control units. At least a system scan would be necessary.
Best regards, Rainer |
Hello Rainer,
Thank you for the quick response.
Pit
Translated on 10-09-2026, 12:17.
Turbinchen Profi-Schrauber
Joined: 04/10/2008 Posts: 200 Karma: +75 / -0 Location: 95615 Marktredwitz 2014 Audi A4 Avant Support
dieselschrauber likes this. |
13-10-2017, 18:42 Subject: Polo 6R: Coming Home, Leaving Home, Door Lock |
CH/LH only works if the vehicle has the rain/light sensor. This is indicated by the "Auto" setting on the light switch.
If that's not present, it won't work because, in the 6R, the lighting is "hardwired," meaning it doesn't go through a control unit. At least, that was the case with my old 6R Highline.
It supports secure locking/unlocking, and depending on the configuration, it may also offer a few other features.
Translated on 10-09-2026, 12:18.
Profile PM Garage |
pit.dahl
13-10-2017, 20:00 Subject: CH/LH |
Turbinchen wrote: | CH/LH only works if you have the rain/light sensor. It can be identified by the "Auto" setting on the light switch.
Safe lock/unlock functions, and depending on the equipment, there are a few other features. |
Hi Turbinchen, it has a rain sensor, but it doesn't have an "auto" setting on the headlight switch, so it probably won't work.
"Safe Lock/Unlock would be a good start, but what other features would be beneficial?"
Thank you and best regards.
Pit.
Translated on 10-09-2026, 12:19.
14-10-2017, 11:16 Subject: Polo 6R: Coming Home, Leaving Home, Door Lock |
Here's the translation:
Volume of the parking assistance system, seatbelt warning, windshield wiper activation, enable MFA (Multi-Function Display) if the conditions are met, and with the rain sensor, it's likely that the windshield wipers can also be automatically activated.
It all depends on the equipment and the control units installed.
Greetings.
Translated on 10-09-2026, 12:21.
Profile PM Garage |
pit.dahl
27-10-2017, 12:06 Subject: Polo 6R: Auto Lock/Unlock Repair |
pit.dahl wrote: | dieselschrauber wrote: | Hello Pit,
The automatic door locking feature at speeds of 15 km/h should not be a problem. Regarding the rest, it is unfortunately difficult to say anything, as this must be supported by the corresponding control units. At least one Autoscan would be necessary here.
Hello Rainer,
Best regards, Pit | .
Hello Rainer,
Here's the Auto-Scan file for the Polo. I'll try to enable the Auto Lock/Auto Unlock function in the next few days.
Has anyone had any experience with Polo or tried that before?
Pit
Log-Polo 6R-23710km.txt
| Description: |
 Download |
| File name: |
Log-Polo 6R-23710km.txt |
| File size: |
7.58 KB |
| Downloaded: |
1085 times |
Golf 7 TDI 2.0 110 KW Sound
Translated on 10-09-2026, 12:22.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
28-10-2017, 4:58 Subject: Polo 6R: Coming Home, Leaving Home, Door Lock |
Quote: | | Has anyone had any experience with Polo or done that before? |
Yes, it's mine.
- Auto-lock enabled.
- Using the NSW (New South Wales) light as a turn signal doesn't offer much benefit in terms of visibility.
- Turning light active up to approximately 70 km/h.
- Hazard lights activate upon full braking.
- Flashing brake lights are activated during emergency braking.
and also unlocked a few other features on the navigation system (Bluetooth, hands-free system, DAB).
Translated on 10-09-2026, 12:24.
pit.dahl
06-11-2017, 8:34 Subject: Polo 6R: Coming Home, Leaving Home, Door Lock |
bloesch wrote: | Quote: | | Has anyone had any experience with Polo or done this before? |
Yes, it's mine.
and I also unlocked a few other features on the navigation system (Bluetooth, hands-free system, DAB) | .
Hello Bloesch,
Thanks for the information. I've now tried to enable the auto-lock/unlock feature and disabled the headlight washer function, let's see if it works.
I also find the feature about the hazard lights activating during hard braking interesting. I once tried to activate the signaling function when opening and closing the car, but it sounded awful because it used the regular car horn. I deactivated it again.
Thank you very much, and best regards.
Pit.
Translated on 10-09-2026, 12:26.
UwesTouran
Joined: 11/09/2017 Posts: 1 Karma: +0 / -0 Location: Rumeln-Kaldenhausen
10-11-2017, 9:50 Subject: Polo 6R: Coming Home, Leaving Home, Door Lock |
For LH and CH, there are modules available from various providers, including those from China. This allows it to function. Alternatively, you can convert to a BNS system with a LIN bus, as is used in vehicles with start-stop systems or GTI models.
Uwe.
Translated on 10-09-2026, 12:28.
pit.dahl
11-11-2017, 12:56 Subject: Polo 6R: Coming Home, Leaving Home, Door Lock |
UwesTouran wrote: | For LH and CH, there are modules available from various providers, including those from China. This allows it to work. Alternatively, you can convert to a BNS system with a LIN bus, as is the case with vehicles with start-stop automatic systems or GTI models.
Uwe |
Hello Uwe,
Thank you for the information, but modifications or accessories seem too complicated for me; the CH/LH functionality isn't that important to me.
The automatic lock/unlock feature is working, thank you.
Pit
Translated on 10-09-2026, 12:29.
