The engine is installed in a Seat Leon Syncro. The engine and turbocharger (Garrett GT1749VB) have approximately 70,000 km (43,500 miles) on them. It has been chipped and a DPF (Diesel Particulate Filter) has been retrofitted. The described problem occurred even without the chip and without the DPF. It is obviously a problem that occurs more frequently with the ARL engine.
Here's the translation:
There is always a drop of oil hanging from the connections to the intercooler and on the turbocharger itself
. Occasionally, a drop will also fall off
. This certainly doesn't noticeably affect the oil consumption, which is about 1 liter per 5000 km... rather less. Nevertheless, the oil loss is not desirable. The axle boot underneath the turbocharger is always very oily }.
Is it really necessary to accept this oil leak, or are there ways to fix it or at least minimize it? I was wondering if it could be related to the oil return line from the turbocharger (only the supply line was replaced according to Garrett's instructions). Or could it be due to inadequate crankcase ventilation?
Helpful suggestions are very welcome!
Best regards from the Westerwald region...
Hardy.
