VCDS: CAN Bus Not Ready - Troubleshooting
A4CabCH
1999 Audi A4 Avant
Post28-04-2021, 15:13    Subject: VCDS: CAN Bus Not Ready - Troubleshooting Quote
Hello everyone.
I updated my VCDS to version 21.3.0 today because I wanted to run a scan to check for any error codes.
Interface detected.
CAN: Not ready.
Can someone help me figure out what's causing this?
I last read data using version 18.7 (I think), and it worked fine with various vehicles.
Today, I received an error message on my A4 B5, which has always worked perfectly before.
"While the system runs through the car scan, no control unit data is displayed, and when attempting to access a control unit, such as the engine control unit, the message 'Control unit not recognized' appears."
Thank you for your help.
Problemkind: A4 B5 Avant quattro 1.8T MKB: APU
Translated on 07-09-2026, 18:54.
Post28-04-2021, 20:49    Subject: VCDS: CAN Bus Not Ready - Troubleshooting Quote
Could you please show me the Autoscan? Has anything been modified on the car in the meantime? Are the pins in the diagnostic connector still in place?
Translated on 07-09-2026, 18:56.
A4CabCH
1999 Audi A4 Avant
dieselschrauber likes this.
Post29-04-2021, 11:07    Subject: VCDS: CAN Bus Not Ready - Troubleshooting Quote
Hello Rainer,
It's resolved itself. I tried it again later, and then it worked... icon_smile_thumb_up.gif
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS HEX-USB+CAN: CAN bus not ready On-Board Diagnostics (OBD)
No new posts CAN Error: Not Ready - Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts CAN Communication Error: Not Ready After Test Electrical Systems, Vehicle Electronics, Multimedia
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
