Replacing the engine control unit (ECU) for an Audi A4 B5 V6 30V
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post15-01-2018, 8:17    Subject: Replacing the engine control unit (ECU) for an Audi A4 B5 V6 30V Quote
Good day.
I would like to temporarily replace the engine control unit (ECU) for testing purposes. To do this, I have acquired a used one with the same part number. I know how to pair the ECU and the WFS (presumably a related module), and I will be using VCDS for that process.
I'm interested in knowing which encodings and adaptations are best to transfer from the current MSG format.
"On the main page, there's a coding code. How do I transfer it?"
Are there any other adaptation channels whose values would also be meaningful to adopt?
Translated on 15-07-2026, 2:07.
Post15-01-2018, 10:31    Subject: Replacing the engine control unit (ECU) for an Audi A4 B5 V6 30V Quote
Which engine control unit are you referring to? Check "Autoscan"; it contains the coding information for the various control units.
Adaptation: The B5 model is likely older, and therefore probably has no adaptations applied. More details can be found using the Autoscan feature.
Translated on 15-07-2026, 2:08.
No new posts Passat V157: How to Replace and Calibrate CBDC Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Steering Pump Audi V6 TDI - Replacement? Diesel Engine Technology
No new posts Replacing xenon ballast, Audi A3, but how? Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Adjust the engine control unit (ECU) for Audi A3/8P On-Board Diagnostics (OBD)
No new posts Audi engine control unit (ECU) AAT - engine On-Board Diagnostics (OBD)
