VW Auxiliary Heater with Standby Heater - Not Functioning
Go to page: 1, 2  Next
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
georgmech
Post17-02-2021, 20:32    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
The Seat Alhambra 7N does not have a built-in auxiliary heating function.
The error memory indicated a short circuit in the temperature sensor, which I replaced. I was able to clear the error codes, but the function still doesn't work.
I can start the auxiliary heater in workshop mode, and there are still no error codes stored. The heater is unlocked; it's a Webasto system with a cable kit and a remote control. The ventilation system turns on, but the water pump and the heater do not.
Does anyone have any ideas? What should come out of pin 1 on the cable that connects to the heating device? It's coming from inside.
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Back to top Profile PM Email
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
dieselschrauber likes this.
Post17-02-2021, 21:28    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
Good evening.
I'm trying to figure out how to use your auxiliary heater.
The first thing that comes to mind spontaneously when there are no errors stored and the ventilation turns on is the summer mode!
Is the system set to recirculation mode / summer operation? Then the heating won't turn on either.
Otherwise, I would appreciate it if you could tell me more about the car. Ideally, just use the automatic scan.
The flame sensor is located on pin 1.
Michael.
Post17-02-2021, 21:52    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
... and please initiate Autoscan.
georgmech
Post17-02-2021, 23:15    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
It is a Seat Alhambra 7N CFF 2.0 103 kW, manufactured in 2013.
Wednesday, February 17, 2021, 10:15:04 PM: 44616
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: DRV 20.12.0.3
Data as of: 20210211 DS322.1
www.Ross-Tech.de
Vehicle Identification Number: VSSZZZ7NZDV517172 License plate:
Vehicle type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 20 22 25 2E 36 37 42 44 46 4C
4F 52 53 55 56 61 62 69 6C 6D 72 BE BF
Vehicle Identification Number: VSSZZZ7NZDV517172 Mileage: 138,960 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
10-Parking Assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
20-High Beam Assist -- Status: OK 0000
22-All-wheel drive -- Status: OK 0000
Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-seat extension. Drive. -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
4C Tire Pressure II -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam angle adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000.
69 followers -- Status: OK 0000
6C Reverse Camera -- Status: OK 0000
Rear hatch (6D) -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
Rear left sliding door -- Status: OK 0000.
Rear right sliding door -- Status: OK 0000.
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-CFFB) Label file: . DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 NE. Part number HW: 03L 906 018 M.
Part: R4 2.0l TDI H28 9978
Revision: 44H28--- Serial number:
Encoding: 0019001A043601080000
Operating number: WSC 05219 605 00000
ASAM Dataset: EV_ECM20TDI01103L906018NE 003011
ROD: EV_ECM20TDI01103L906018H_VW36.rod
VCID: 7AFDA9D4FD7111544E-802E
No error codes found.
Readiness: 0 0 0 0 1
Address 03: Brake Electronics Label file: 7N0-614-109.clb
Part number SW: 7N0 614 109 P HW: 7N0 614 109 P
Component: J104 C3 450M VD07 0030
Revision: --H07--- Serial Number: 00000006851090
Encoding: 0019073
Operating number: WSC 00020 790 00000
VCID: 3A7D69D475F1D1540E-806E
Address 08: Climate Control/Heater (J255) Label file:| DRV\5K0-907-044.clb
Part number SW: 7N0 907 044 J, Hardware number: 7N0 907 044 J.
Part: Clima-Sharan H01 0303
Revision: 00001K03
Encoding: 0210104549
Operating Number: WSC 00020 999 00000
ASAM Dataset: EV_ClimatronicSharan A01005
text
ROD: EV_ClimaAutoSharaBasis.rod
VCID: 377B70E08EE3CC3CF1-8062
Slave 1:
Subsystem 1 - Part number SW: 7N0 907 049 B, HW: 7N0 907 049 B.
Part number: KBT-H 004 0102.
Serial number: 20130408000000111575.
Address 09: Central Electronics (J519)
Label file: . DRV\1K0-937-08x-09.clb
Part number SW: 5K0 937 086 M, Part number HW: 5K0 937 086 M.
Part: BCM PQ35 M 021 0068
Revision: BC021001
Encoding: 40590A3B89251AC0508800C87400896443559388636D2F626484C72000C1
VCID: 3E7565C4A9D9FD7432-806A
Subsystem 1 - Part number SW: 7N1 955 119 A, HW: 7N1 955 119, Label file: DRV\1KX-955-119.CLB.
Component: WWS 130320 31 0032
Serial number: 130402115200
Encoding: 004DBD
Subsystem 2 - Part number SW: 7N0 955 559 HW: 7N0 955 559 Label file: DRV\7N0-955-559.CLB
Part number: RLFS 021 0024.
Serial number: Y13M04D08H00M33S13S1
Encoding: 0280DD
Address 10: Parking Assist 2 (J446) Label file:| DRV\1Q0-919-475.clb
Part number SW: 7N0 919 475 A, HW: 7N0 919 475.
Part: PARKING ASSIST 8K H06 0012
Revision: -------- Serial Number: 28231309504209
Encoding: 318002
ASAM Dataset: EV_EPHVA18VW4280000 001005
FILE: EV_EPHVA18VW4280000.rod
VCID: 397F76D8B8F7DA4C07-806C
Address 15: Airbag (J234) Label file:| DRV\5K0-959-655.clb
Part number SW: 7N0 959 655 C, HW: 7N0 959 655 C.
Part number: VW10Airbag004 H12 0014
Serial number: 003LGP6UAC2$
Encoding: 003034
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3F8B18C0A6D3F47C39-806A
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60AC52C5179D0
Encoding: 000000
Crash sensor for side airbag, passenger side:
Subsystem 2 - Part number: SW: --- HW: ---
Component: S. Sensor, Front, Left --- ---
Serial number: 3503ETS6030ACC1179DR
Encoding: 000000
Rear side airbag crash sensor (driver's side):
Subsystem 3 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60DB33C2179DY
Encoding: 000000
Crash sensor for rear side airbag, passenger side:
Subsystem 4 - Part number: SW: --- HW: ---
Component: S. Sensor, Front, Right --- ---
Serial number: 3523ETS60871DC1179DX
Encoding: 000000
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS602015C517DDA
Encoding: 000000
Address 16: Steering Wheel Electronics (J527) Label file:| DRV\5K0-953-569.clb
Part number SW: 5K0 953 501 BA, HW: 5K0 953 569 H.
Component: STEERING MODULE 016 0140
Revision: FF010041 Serial Number: 20130409101832
Encoding: 118A240000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 6ADD99948DD1A1D4BE-803E
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 1P0 959 538 D HW: 1P0 959 538 D Label file: DRV\3C8-959-537.CLB
Component: E221__MFL-TAP H02 0103
Encoding: E20000
Address 17: Terminal block insert (J285) icon_neutral.gif Label file: DRV\5K0-920-xxx-17.clb-SRI1
Part number SW: 7N5 920 870 G, HW: 7N5 920 870 G.
Component: KOMBI H05 0715
Serial number: 00000000000000
Encoding: 141F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 3B736CD0B2CBE85C15-806E
Address 18: Auxiliary heater
Label file: DRV\1K0-815-071.clb
Part number: 7N0 963 271 E.
Component: Auxiliary heater 051 2940
Revision: 00051000 Serial number: 09024297000000
Encoding: 0000011
VCID: 36657DE441E93534EA-8062
Address 19: Diagnostic interface (J533)
Label file: . DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 AH, Hardware number: 7N0 907 530 AH.
Component: J533 Gateway H50 1634.
Revision: H50 Serial Number: 070413F1000337
Encoding: 468202
VCID: 76E5BDE4C16975342A-8022
Address 20: High Beam Assist (J844) Label file: . DRV\8K0-857-511.clb
Part number SW: 7N0 857 511 P, HW: 8P0 857 511 C.
Component: FLA H04 0012
Revision: AA001002
Encoding: 0201816B74745D545420363E01
VCID: 40891B3CD32D8B8440-8014
Address 22: All-wheel drive
Label file: DRV\0AY-907-554-V1.clb
Part number SW: 0AY 907 554 E, HW: 0AY 907 554 E.
Component: Haldex 4Motion 0043
Encoding: 0000005
Operating Number: WSC 00000 000 00000
VCID: 4D973208D47F56ECBB-8018
Address 25: Immobilizer (J334) Label file:| DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0715
Serial number:
Encoding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
Address 2E: Media Player 3 (J650) Label file: . DRV\5N0-035-342.lbl
Part number SW: 5N0 035 342 F, Hardware: 5N0 035 342 F.
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial Number: 7664560647
Encoding: 020100
VCID: 2A5D5994455161D47E-807E
Address 36: Seat adjustment. Drive. (J810) Label file: 3C0-959-760.lbl
Part number SW: 3C8 959 760 C, HW: 3C8 959 760 C.
Component: Seat Memory. Part Number: H05 2901.
Revision: 00H05000
Encoding: 000018
Operating number: WSC 12336 024 394758
VCID: 35677AE89CEF3E2CE3-8060
Address 37: Navigation (J794) Label file:| DRV\1K0-035-27x-37.clb
Part number SW: 5P0 035 191 N, Hardware: 5P0 035 191 N.
Part: RNS315-EU H59 0321
Serial number: SEZAZ2N0228667
Encoding: 040004010400240000061001
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 36657DE489E93534EA-8062
Data storage devices:
Subsystem 1 - Part number: 3AA 919 866.
Component: EUR_W_V4 0050
Address 42: Door electronics. Driver (J386) Label file: .7N0-959-793.clb
Part number SW: 7N0 959 793 G. Part number HW: 7N0 959 793 G.
Component: TSG FA H03 0553
Revision: Serial number: 0000056907911
Encoding: 01112E209E00411001
VCID: 46850D24F109A5B47A-8012
Address 44: Steering Assist
Label file: DRV\5N1-909-144.clb
Part number SW: 5N1 909 144 P, HW: 5N1 909 148 J.
Component: J500__APA-BS, Class 325, 1202.
Revision: 1BH04737 Serial Number: 00130800123801
Encoding: 0000258
VCID: 3F8B18C06ED3F47C39-806A
Address 4F: Central Electricity II (J520)
Label file: . DRV\1K0-907-532.clb
Part number SW: 7N0 907 532, HW: 7N0 907 530 AH.
Component: EZE_2 H50 1634
Encoding: 050B0500
VCID: 6FEB8880BE3344FCE9-803A
Subsystem 1 - Part number SW: 8R0 959 591 A, HW: 8R0 959 591.
Part number: J245EE20SKB13 H05 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part number SW: 8R0 959 591 A, HW: 8R0 959 591.
Part number: J394EE20SKB13 H05 0220
Address 52: Door opener (or electric door release). Co-driver. (J387) Label file: .7N0-959-792.clb
Part number SW: 7N0 959 792 G, Hardware number: 7N0 959 792 G.
Component: TSG BF H03 0553
Revision: Serial number: 0000056397673
Encoding: 01112C209E00411001
VCID: 45870A28CC0FAEAC73-8010
Address 53: Parking brake
Label file: DRV\3AA-907-801.clb
Part number SW: 3AA 907 801 H HW: 3AA 907 801 H
Part number: J540 EPB4 VW-86594 0010.
Revision: H19 Serial Number: 00000000872471
Encoding: 0024167
Address 55: Headlight range control (J745) Label file: . DRV\5M0-907-357-V3.clb
Part number SW: 5M0 907 357 F, HW: 7L6 907 357 C.
Component: AFS-ECU H04 0111
Revision: -------- Serial Number: --------------
Encoding: 068A00000B000000
Operating number: WSC 00020 999 39850
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
Left headlight power output stage:
Subsystem 1 - Part number: 1T0 941 329 B Label file: 3D0-941-329.CLB
Right_headlamp_power_output_stage:
Subsystem 2 - Part number: 1T0 941 329 B Label file: 3D0-941-329.CLB
Address 61: Battery Management (J840) Label file: . DRV\1K0-907-534.clb
Part number SW: 7N0 907 534, HW: 7N0 907 530 AH.
Component: Battery management system H50 1634.
Serial number: 070413F1000337
Encoding: 330F7859
VCID: 71EF8EF8A807520CFF-8024
Subsystem 1 - Part number SW: 1K0 915 181 H, HW: 1K0 915 181 A.
Part number: J367-BDM H07 0180.
Serial number: 40095I17061491190598
Address 62: Door electric, high, left (J388)) Label file: 7N0-959-794.clb
Part number SW: 7N0 959 794 J, HW: 7N0 959 794 H.
Part: TSG HL H01 0556
Revision: Serial number: 0000057146854
Encoding: 01006C200000411001
Operating Number: WSC 21644 002 1048576
VCID: 4A9D3914E51141D49E-801E
Address 69: Trailer (J345) Label file: . DRV\7N0-907-383.clb
Part number SW: 7N0 907 383 HW: 7N0 907 383
Part: Trailer H09 0120
Revision: 3I001003 Serial number: 00008160089143
Encoding: 410C040001000000
VCID: 73E384F0D21B601C0D-8026
Address 6C: Rear-view camera
Label file: DRV\5N0-907-441.clb
Part number SW: 7N0 907 441 HW: 7N0 907 441
Part: J772__Rearview 0020
Revision: 00H11000 Serial Number: 525 PA8J331797
Encoding: 0030011
VCID: 6ED5958479394DF4E2-803A
Address 6D: Rear door (----) Label file:| DRV\7N0-959-107.clb
Part number SW: 7N0 959 107 E, HW: 7N0 959 107 A.
Component: HDSG Module H11 0243
Revision: 41011001 Serial Number: 074300636
Encoding: 0733334003
ASAM Dataset: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
Address 72: Door electrical, high, right (J389) Label file: .7N0-959-794.clb
Part: TSG HR H01 0556
Revision: Serial number: 0000057146914
Address BE: Rear left sliding door (J558)) Label file: 7N0-959-244.clb
Part number SW: 7N0 959 244 B, Hardware number: 7N0 959 244 B.
Component: Sliding door_l 005 2414
Serial number: 13103660.
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
VCID: 387973DC83FDC344F8-806C
Address BF: Rear right sliding door (J731)
Component: Sliding door 005 2414.
Serial number: 13114747.
ROD: EV_AST.rod
End----------------------------(Duration: 04:39)-----------------------------
georgmech
Post17-02-2021, 23:29    Subject: Screenshot Quote
Perhaps this will help.
Post17-02-2021, 23:40    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
If the error memory shows no entries after a failed attempt to start the heater, it is likely that no start attempt actually occurred.
Has the auxiliary heater ever functioned as a standing heater?
I can start the auxiliary heater in workshop mode, and I still don't have any error codes stored. The heater is unlocked; it's a Webasto wiring harness with a remote control installed. The ventilation system turns on, but the water pump and the heater do not.
Not that some smart person installed the auxiliary heating cable kit, but they forgot to properly flash the auxiliary heater. icon_razz.gif
There are also ways to do it without flashing the device, but these methods use an intermediary electronic component and, for example, the Webasto clock to control it.
What exactly is installed?
As a pre-heater, it starts (if nothing else is configured) at a temperature below 5°C when the engine is started.
Karma: +438 / -0   Thank you, like it!
dieselschrauber and Duese likes this.
Post17-02-2021, 23:45    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
And what does the aforementioned summer mode say?
Depending on the year of manufacture, it can be adjusted either in the MFA's "STH" menu or in the "STH" menu of the radio/navigation system.
That would perfectly match your error. If the driver has set the system to summer mode, then it will now behave properly when you press the STH button. It is true that it doesn't make sense in the winter, but the software doesn't care icon_wink.gif.
Guste.
georgmech
Post18-02-2021, 10:50    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
Okay, our technician says it's a T90 (D90) radio remote control installed. When you turn on the transmitter, you see the three bars on the display. What we've just noticed is that on the receiver, the 8-pin connector has the yellow cable plugged into pin 1, but could it possibly be that it should be plugged into pin 2? It's not very easy to see. But the customer, who is new, said that the heating had worked before, but who knows if that's true or if someone else has already tampered with it?
Ich_Can_nix
Post18-02-2021, 11:51    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
Good morning.
It's definitely much easier icon_smile.gif for my Fin.
Yellow wire connected to pin 2 - correct.
Is the summer mode enabled?
Switch between heating and ventilation.
Press the ON and OFF buttons within 1 second, 2 times.
briefly activate.
The indicator light changes color. The next time the remote control is used, the heating device will execute the selected operating mode until the operating mode is changed.
 File size:  174.9 KB
 Viewed:  723 times
georgmech
Post18-02-2021, 13:34    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
Okay, I've checked again, the cable is connected to PIN 2, and the heater is set to "heat." I double-checked both to be sure. I'm also not sure if the auxiliary heater kicks in when the engine starts, because it's constantly too warm. Does the auxiliary heater also work based on the coolant sensor? However, it does work in workshop mode. I was even thinking about ordering a coolant temperature sensor and spraying it with freezing spray.
georgmech
Post18-02-2021, 14:03    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
There's voltage on the yellow cable; could someone have tampered with the coding? Is it possible to use VCDS to send a Screenshot with all the important settings that can be changed?
Ich_Can_nix
Post18-02-2021, 14:45    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
If it starts up in diagnostic mode, then it should be working correctly.
Otherwise, it would terminate and record an error.
Can you hear or feel the auxiliary water pump running?
Then I can think of two more possibilities.
1.) Rainer, did you install the software correctly? Is the auxiliary heater upgrade complete?
2) Which retrofit kit was installed? Was it an original Webasto kit or an aftermarket accessory? The accessory kits are available with a tilt switch for summer mode! In this mode, only the ventilation function is activated.
Have you checked if there's an additional toggle switch installed near the fuse box?
You can also bypass the connector for the temperature sensor; if you do that, it should start.
Michael.
georgmech
Post18-02-2021, 16:05    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
Okay, I just disassembled the water pump and discovered that it doesn't start automatically.
If I give it a push, it moves, but it doesn't start on its own. I'm surprised that I didn't find any errors, because it should be drawing too much power in that case. Well, I hope it works now.
Thank you in advance for your great tips.
georgmech
Post18-02-2021, 19:43    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
Okay, so the heating system now runs for a longer time in workshop mode, and the water pump is also running, which is new. However, the heating system still doesn't turn on with the remote control.
Could the issue be related to the wiring of the Webasto cable harness, or to the programming?
Is there anyone who can take a look at my TeamViewer issue and help me fix it, for a fee?
Otherwise, I still have three days of work left.
Ich_Can_nix
Post19-02-2021, 0:10    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
Good evening, Georg,
Basically, we can also access your auxiliary heater remotely using TeamViewer.
If you want to get rid of some money, you can gladly donate it to Kinderträume e.V. Or you can create a ticket with Rainer.
I don't want anything...
And it's also questionable whether I can actually help you using TeamViewer.
I still have a few questions, though.
Does the auxiliary heater run automatically during normal operation, or only in diagnostic mode? Are the auxiliary heater, water pump, and temperature sensor working properly now?
What exactly does the remote control do?
Does the fan turn on, or what's happening?
How does the LED on the remote control behave?
The vehicle was delivered with an auxiliary heater - if it works, it does what it's supposed to do.
Then the source of the error can be found in the retrofitted parts.
Were you looking for the toggle switch? Can we rule him out?
An accessory kit may include an additional control unit within the wiring harness. Is there such a control unit?
Is it definitely an organic product? Webasto installation kit?
Which pin does the yellow cable connect to on the radio receiver?
Is there a timer?
Do you have the diagnostic software from Webasto?
Org. Do you have the wiring diagrams for the vehicle?
Keep the issue of W and H buses in mind.
Michael.
georgmech
Post19-02-2021, 0:22    Subject: VW Auxiliary Heater with Standby Heater - Not Functioning Quote
Thank you for everything. The heater had a defect in the control unit, which is strange. I now received a used one and installed it. Then, following your instructions, I configured it with VCDS, and it started up immediately. It seems like the electronics on the old HG unit have no connection to pin 2, because it's behaving as if it doesn't want to turn on at all.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Allroad Luftfahrwerk - keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: Troubleshooting Guide (99) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary Heater Upgrade for Parking Heaters Transmission, Chassis, Body & Interior
No new posts Auxiliary Heater for Audi A4 2.5 Qtip Transmission, Chassis, Body & Interior
No new posts Umrüstung Zuheizer->Standheizung On-Board Diagnostics (OBD)
No new posts Zuheizer entsperren zur Standheizung On-Board Diagnostics (OBD)
