Rain gutter for Sharan 7N
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
vag-driver
Post19-04-2016, 13:16    Subject: Rain gutter for Sharan 7N Quote
Here's the translation:
"I have successfully applied the following encoding:"
Select STG 09 (Onboard network).
STG Long Coding -> Function 07.
Byte 4.
Enable bit 5.
Enable bit 6.
Choosing a rain and light sensor (RLS).
Byte 0.
Enable bit 2.
However, the sensor apparently does not react to water when the vehicle is closed. In several forums, there are reports that the automatic window and panoramic roof closing function is not available on the Sharan (manufactured in 2011).
Who can provide clarification here?
Translated on 08-07-2026, 7:54.
Post19-04-2016, 13:34    Subject: Rain gutter for Sharan 7N Quote
Please always include an Autoscan when answering such questions...
Translated on 08-07-2026, 7:55.
vag-driver
Post20-04-2016, 10:02    Subject: Rain gutter for Sharan 7N Quote
Sure, please provide the text you would like me to translate.
Wednesday, April 20, 2016, 07:19:34:19385
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 15.7.4.1
Data as of: 20160226
Vehicle Identification Number: WVWZZZ7NZBV023072 License plate: xyz
Mileage: 97120 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 7N (7N0)
Scan: 01 03 05 08 09 10 15 16 17 18 19 25 2B 36 37 42 44 46 47 4F
52 53 55 56 61 62 69 6C 6D 72 77 BE BF
Vehicle Identification Number: WVWZZZ7NZBV023072 Mileage: 97120 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
10-Parking Assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer -- Status: OK 0000
2B steering column lock. -- Status: OK 0000
36-seat adjustable passenger seat -- Status: OK 0000.
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam angle adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000.
69 followers -- Status: OK 0000
6C Reverse Camera -- Status: OK 0000
Rear hatch (6D) -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
77-Phone -- Status: OK 0000
Rear left sliding door -- Status: OK 0000.
Rear right sliding door -- Status: OK 0000.
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-CFGB)
Label file: DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 F, HW: 03L 907 309 Q.
Component: R4 2.0L EDC H24 0257
Revision: 44H24--- Serial number:
Encoding: 0019001A043401080000
Operating Number: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01103L906018F 003003
ROD: EV_ECM20TDI01103L906018F_VW36.rod
VCID: 2D573FB17C5A8756E5-8078
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics Label file: 7N0-614-109.clb
Part number SW: 7N0 614 109 L, HW: 7N0 614 109 L.
Component: J104 C3 450M VDD4 0008
Revision: --H07--- Serial Number: 00000003531178
Encoding: 0023072
Operating number: WSC 00020 790 00000
VCID: 366510DD410CC48E94-8062
Address 05: Access/Startup Authorization (J518)
Label file: DRV\5K0-959-434.clb
Part number SW: 5K0 959 434 A, HW: 5K0 959 434 A.
Part number: VWKESSYPQ35GP 085 0802
Revision: 00085000 Serial Number: 0140603123
Encoding: 03100C
ASAM Dataset: EV_KESSY_PQ35GP A01018
ROD: EV_KESSY_PQ35GP.rod
VCID: 336329C99A7ED1A6B3-8066
Address 08: Climate Control/Heating (J255)
Label file: DRV\5K0-907-044.clb
Part number SW: 5K0 907 044 J HW: 5K0 907 044 J
Part: Clima-Sharan H11 0104.
Revision: 00002001
Encoding: 0000000109
ASAM Dataset: EV_ClimatronicSharan A01005
ROD: EV_ClimaAutoSharaBasis_VW36.rod
VCID: 326D2CCD6564D8AEB8-8066
Slave 1:
Subsystem 1 - Part number SW: 7N0 907 049 B, HW: 7N0 907 049 B.
Part number: KBT-H 004 0102.
Serial number: 20101220000000011735.
Address 09: Central Electronics (J519)
Label file: DRV\1K0-937-08x-09.clb
Part number SW: 5K0 937 087 M, Part number HW: 5K0 937 087 M.
Part: BCM PQ35 H 011 0046
Revision: BE011001
Encoding: 4E510A3BE937F3C0500800C0740009E443551408676D25F2E4808700A2C1
Operating number: WSC 00020 790 12345
VCID: 3F8B75F9AE3605C647-806A
Subsystem 1 - Part number SW: 7N1 955 119 A, HW: 7N1 955 119, Label file: DRV\1KX-955-119.CLB.
Component: WWS 110905 31 0032
Encoding: 000D9D
Subsystem 2 - Part number SW: 7N0 955 559 HW: 7N0 955 559 Label file: DRV\7N0-955-559.CLB
Part number: RLFS 021 0022.
Encoding: 0780BB
Subsystem 3 - Part number: 7N0 951 171.
Component: DWA sensor 00 002 0205.
Encoding: 000000
Subsystem 4 - Part number: 1K8 951 605 A
Part: LIN BACKUP HO H11 9004
Encoding: 000000
Address 10: Parking Assist 2 (J446) Label file: DRV\1Q0-919-475.clb
Part number SW: 7N0 919 475 HW: 7N0 919 475
Component: PARKING ASSIST 8K H04 0010
Revision: -------- Serial Number: 80231034802665
Encoding: 318001
ASAM Dataset: EV_EPHVA18VW4280000 001005
FILE: EV_EPHVA18VW4280000.rod
VCID: 78F9DEE5C398F2FE46-802C
Address 15: Airbag (J234) Label file: 5K0-959-655.clb
Part number SW: 7N0 959 655 B, Hardware number: 7N0 959 655 B.
Part number: VW10Airbag01L H07 0013
Serial number: 003GFPR2BKD3
Encoding: 00314C
ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3E7508FDA13C0CCE4C-806A
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60A4062A139DP
Encoding: 000000
Crash sensor for side airbag, passenger side:
Subsystem 2 - Part number: SW: --- HW: ---
Component: S. Sensor, Front, Left --- ---
Serial number: 3503ETS6013C227139DC
Encoding: 000000
Rear side airbag crash sensor (driver's side):
Subsystem 3 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60B0E429139DQ
Encoding: 000000
Crash sensor for rear side airbag, passenger side:
Subsystem 4 - Part number: SW: --- HW: ---
Component: S. Sensor, Front, Right --- ---
Serial number: 3523ETS606E783913DD.
Encoding: 000000
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS60EF6F3913DD0.
Encoding: 000000
Address 16: Steering Wheel Electronics (J527)
Label file: DRV\5K0-953-569.clb
Part number SW: 5K0 953 501 BM, HW: 5K0 953 569 L.
Component: STEERING MODULE 009 0136
Revision: FF010039 Serial Number: 20101213300280
Encoding: 110A240000
Operating number: WSC 40517 000 1048576
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 76E5D0DDC98C848E54-8022
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 3C8 959 537 D HW: 3C8 959 537 D Label file: DRV\3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Encoding: E20000
Address 17: Control panel module (J285)
Label file: DRV\5K0-920-xxx-17.clb
Part number SW: 7N0 920 870 A, Hardware: 7N0 920 870 A.
Component: KOMBI H20 0420
Serial number: 00000000000000
Encoding: 140F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 306926C56B68EABECE-8064
Address 18: Auxiliary heater
Label file: DRV\1K0-815-007.clb
Part number: 7N0 963 272 A
Component: Standing heater 043 4730
Revision: 00043000 Serial number: 09022127000000
Encoding: 0031142
VCID: 336329C9527ED1A6B3-8066
Address 19: Diagnostic interface (J533)
Label file: DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 D, HW: 1K0 907 951.
Component: J533 Gateway H35 0614.
Revision: H35
Serial Number: 041210F2003181
Encoding: 468002
Operating number: WSC 00000 864 716674
VCID: 316F23C16862E3B6C1-8064
Address 25: Immobilizer (J334)
Label file: DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0420
Serial number:
Encoding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADDF4AD8D34506EC0-803E
Address 2B: Steering column lock. (J764)
Label file: DRV\5K0-905-861.clb
Part number SW: 5K0 905 861 A, HW: 5K0 905 861 A.
Component: ELV-PQ35 H20 0220
Revision: 00000000 Serial Number: 10000090905004
Encoding: 4100000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E5538BD715CFC4EDC-807A
Address 36: Seat adjustment for driver (J810) Label file: 3C0-959-760.lbl
Part number SW: 3C8 959 760 A, HW: 3C8 959 760 A.
Component: Seat Memory H05 2201
Revision: 00H05000
Encoding: 000018
Operating number: WSC 12336 024 394758
VCID: 336329C9927ED1A6B3-8066
Address 37: Navigation (J0506)
Label file: DRV\1T0-035-680.clb
Part number SW: 1T0 035 680 C HW: 1T0 035 680 C
Component: RNS-MID H42 2720
Revision: AB001001 Serial Number: VWZ6Z7K4353137
Encoding: 06050002010000A000
VCID: 2E5538BD795CFC4EDC-807A
Address 42: Door electrical driver (J386) Label file: 7N0-959-793.clb
Part number SW: 7N0 959 793 E, HW: 7N0 959 793 A.
Part number: TSG FA H04 0400
Revision: Serial number: 0000110558255
Encoding: 01153E20DE00411001
VCID: 44817A15C7D0661E1A-8010
Address 44: Steering Assist
Label file: DRV\5N1-909-144.clb
Part number SW: 5N1 909 144 L, HW: 5N1 909 148 G.
Component: J500__APA-BS, Class 325, 0802.
Revision: 1AH03729 Serial Number: 00103480158201
Encoding: 0000258
VCID: 3B7301E97A2E19E66B-806E
Address 47: Soundsystem (R12) Label file: 5K0-035-456.clb
Part number SW: 5K0 035 456 A, HW: 5K0 035 456 A.
Component: Corporate Amplifier 8K H06 0180.
Revision: -------- Serial Number: BP218809236600
ASAM Dataset: EV_AudioAmplifier8ChannelBNO1 A01003
ROD: EV_AudioAmplifier8ChannelBNO1.rod
VCID: 2859CEA553B8A27E16-807C
Address 4F: Central Electricity II (J520)
Label file: DRV\1K0-907-532.clb
Part number SW: 7N0 907 532, HW: 1K0 907 951.
Component: EZE_2 H35 0614
Revision: H35
Encoding: 050B0500
VCID: 6FEBE5B9BED6B54697-803A
Subsystem 1 - Part number SW: 8R0 959 591 A, HW: 8R0 959 591.
Part number: J245EE20SKB13 H02 0220
Subsystem 2 - Part number SW: 8R0 959 591 A, HW: 8R0 959 591.
Part number: J394EE20SKB13 H02 0220
Address 52: Power door lock, front passenger side (J387)
Label file: 7N0-959-792.clb
Part number SW: 7N0 959 792 E, HW: 7N0 959 792 A.
Part: TSG BF H04 0400
Revision: Serial number: 0000110694398
VCID: 43837909C2DE612623-8016
Address 53: Parking brake
Label file: DRV\3AA-907-801.clb
Part number SW: 3AA 907 801 D HW: 3AA 907 801 D
Part number: J540 EPB4 VW-53083 0006.
Revision: H18 Serial Number: 00000000131217
Encoding: 0024067
VCID: 326D2CCDAD64D8AEB8-8066
Address 55: Headlight range adjustment. Label file: DRV\5M0-907-357-V2.lbl
Part number SW: 5M0 907 357 D, Hardware number: 5M0 907 357 D.
Component: AFS Control Unit 0149
Revision: 00H04000 Serial Number:
Encoding: 3555545
VCID: 356717D15C0ACF969D-8060
Subsystem 1 - Part number: 1T0 941 329
Label file: 3D0-941-329.CLB
Component: AFS-Lst. Module l 0001
Encoding: 00000054
Subsystem 2 - Part number: 1T0 941 329
Component: AFS-Lst. module r 0001
Encoding: 00000054
Address 56: Radio (J0506) Label file: DRV\1T0-035-680.clb
Address 61: Battery Management (J840)
Label file: DRV\1K0-907-534.clb
Part number SW: 7N0 907 534, HW: 1K0 907 951.
Component: Battery management system H35 0614.
Serial number: 041210F2003181.
Encoding: 030B085A
VCID: 71EFE3C1A8E2A3B681-8024
Subsystem 1 - Part number SW: 1K0 915 181 F, HW: 1K0 915 181 A.
Part: J367-BDM H07 0150
Address 62: Door electric, left/right (J388) Label file: 7N0-959-794.clb
Part number SW: 7N0 959 794 F, HW: 7N0 959 795 B.
Component: TSG HL H03 0400
Revision: Serial number: 0000111312028
Encoding: 01007C200000411001
VCID: 4685601DF1EC540E04-8012
Address 69: Trailer (J345) Label file: DRV\7N0-907-383.clb
Part number SW: 7N0 907 383 HW: 7N0 907 383
Component: Trailer H07 0101
Revision: 3I001002 Serial number: 00000138883202
Encoding: 410C040001000000
VCID: 73E3E9C9D2FE91A673-8026
Address 6C: Rear-view camera
Label file: DRV\5N0-907-441.clb
Part number SW: 7N0 907 441 HW: 7N0 907 441
Part: J772__Rearview 0020
Revision: 00H08000 Serial Number: 525PA8-J0Y0329
Encoding: 0030011
VCID: 6ED5F8BD79DCBC4E9C-803A
Address 6D: Rear hatch (----) Label file: DRV\7N0-959-107.clb
Part number SW: 7N0 959 107 B, HW: 7N0 959 107 A.
Component: HDSG Module H11 0803
Revision: 41011001 Serial Number: 330000559
Encoding: 0733334003
ASAM Dataset: EV_HDSGVW428 201133
ROD: EV_HDSGVW428_SE36.rod
VCID: 366510DD890CC48E94-8062
Address 72: Door electric, upper right (J389) Label file: 7N0-959-794.clb
Component: TSG HR H03 0400
Revision: Serial number: 0000111314705
Address 77: Phone (J412)
Label file: DRV\3C8-035-730-A.clb
Part number SW: 5N0 035 730 D, Hardware number: 5N0 035 730 D.
Component: Telephone 009 0511
Revision: -------- Serial Number: 35909603087080
Encoding: 020100000100000000010000
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_SE36.rod
VCID: 295FCBA148B29B7609-807C
Address BE: Rear left sliding door (J558)
Label file: 7N0-959-244.clb
Part number SW: 7N0 959 244 HW: 7N0 959 244
Component: Sliding door_l 005 2213
Serial number: 10481927.
ASAM Dataset: EV_AST A03002
ROD: EV_AST.rod
Address BF: Rear right sliding door (J731)
Component: Sliding door_r 005 2213
Serial number: 10481904.
ROD: EV_AST.rod
End----------------------------(Duration: 05:17)-----------------------------
Translated on 08-07-2026, 8:36.
vag-driver
Post21-04-2016, 19:55    Subject: Rain gutter for Sharan 7N Quote
Who will become smarter from the car scan?
Post21-04-2016, 21:30    Subject: Rain gutter for Sharan 7N Quote
Byte 4
Enable bit 5.
Activate bit 6
Do you seriously expect someone to now check byte 4, bits 5 and 6 of *your* control unit?
Why don't you just take a Screenshot of the coding dialogue?
Translated on 08-07-2026, 8:37.
vag-driver
Post22-04-2016, 9:57    Subject: Rain gutter for Sharan 7N Quote
Sure, here's the translation:
"Please find the dialogue attached."
 Codierung Regenschließen Sharan 7N
 File size:  81.97 KB
 Viewed:  1339 times
 File size:  71.14 KB
 Viewed:  3135 times
Translated on 08-07-2026, 8:38.
Post22-04-2016, 10:27    Subject: Rain gutter for Sharan 7N Quote
In mehreren Foren gibt es Aussagen, dass das Regenschließen der Fenster und des Panaoramadaches beim Sharan (EZ 2011) nicht möglich ist.
Well...
vag-driver
Post22-04-2016, 10:31    Subject: Rain gutter for Sharan 7N Quote
Unfortunately, I had hoped that you would have a brilliant idea. icon_cry.gif
Herschdorfer
Post29-04-2018, 22:43    Subject: Rain gutter for Sharan 7N Quote
I'm bringing up this old thread again.
I had a 7N cable connected, and it was possible to code that into the BCM, and the menu option is available in the MFA.
Okay, so I thought I should probably encode the RLHS as well. However, it doesn't accept the encoding that includes the umbrella symbol.
Is the issue with the umbrella holders still present in the 7N model?
Has anyone ever seen the 7N model reject a code in the RLHS format (RLHS 037 0059)?
Translated on 08-07-2026, 8:39.
vag-driver
Post02-05-2018, 21:03    Subject: Rain gutter for Sharan 7N Quote
Yes, because otherwise the sensor cannot enter a sleep mode to save power, and neither can the comfort control unit.
Andreas
hadez16
Avatar-hadez16
Post06-06-2018, 11:54    Subject: Rain gutter for Sharan 7N Quote
RLHS = No rain closure.
RLFS = Umbrella closure.
Translated on 08-07-2026, 8:40.
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop Action: Sharan, Mass Flow Meter Connection Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rain closure and backup horn close/open On-Board Diagnostics (OBD)
No new posts Retrofitting MFA to the Sharan Diesel Engine Technology
No new posts AUY Sharan: Power Loss - Troubleshooting Guide Diesel Engine Technology
No new posts Chip tuning for a Sharan 115 PD automatic? Diesel Engine Technology
