VW Polo 9N Front Door Skin - Right Side
chli1976
Karma: +185 / -0   Thank you, like it!
Post09-08-2018, 10:44    Subject: VW Polo 9N Front Door Skin - Right Side Quote
I have a Polo here where the right-hand door won't open.
There are no error codes stored in the system's memory.
I've now connected the wires leading to the motor to the connector on the comfort control unit, and I can hear a faint noise, but I still can't open the door.
I tried the same thing on the driver's side, and here the button goes in and pops out.
Does anyone know a trick to get the door open?
I once had a similar issue with an A4 from 2001, but it was on a rear door. I removed the trim panel and then managed to damage the lock. However, that car also didn't have the aluminum cover.
VCDS
Translated on 09-08-2026, 4:32.
chli1976
dieselschrauber likes this.
Post09-08-2018, 11:39    Subject: VW Polo 9N Front Door Skin - Right Side Quote
Okay, I've loosened the door panel as much as possible. It won't come off at the A-pillar, but I was able to loosen it about 20-25 cm at the B-pillar. Then I removed the screws for the window glass, took out the window, and used a long chisel through the window opening to destroy the lock mechanism in the area where the motor is located. Now I've managed to open the door.
VCDS
Translated on 09-08-2026, 4:33.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo 9N, Vibrationen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CV Joint Leak: Right Side Drive Shaft Transmission, Chassis, Body & Interior
No new posts Beim Golf 3 fällt immer das rechte Licht aus! Warum? Diesel Engine Technology
No new posts Polo 6R On-Board Diagnostics (OBD)
No new posts VW Polo TDI: Specs, Features, & More Diesel Engine Technology
