Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1508 Karma: +643 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
01-03-2018, 18:51 Subject: Install Alternator Without DF Connector in SDI Car |
Hi there!
I have a car here that belongs to an acquaintance who is struggling financially.
Seat Arosa 1.7 SDI 60 hp, first registration 1999.
"The alternator failed today. A replacement is relatively expensive in this specific case, especially considering the vehicle's value, and it's impossible to find a used one."
Now I have the opportunity to get one that is identical in terms of dimensions and performance data, except that instead of the "DF" connector, it has a "W" terminal.
Both devices have a D+ connection, so it should work. There shouldn't be more than one error entry in the MSG (Message) log, or am I mistaken?
Since the installation is unfortunately complex and requires removing the entire front panel, and the outside temperatures are extremely low, I'm wondering if I can install it without any issues to get the vehicle running again.
Thank you, Rüdi.
Translated on 02-08-2026, 18:18.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18064 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
01-03-2018, 20:43 Subject: Install Alternator Without DF Connector in SDI Car |
The 1.7 SDI engine has an engine control unit (ECU) that likely expects a DF signal. Without having tried it myself, this sounds like it could cause potential problems. It's possible the ECU might start behaving erratically, a potentially installed coolant glow plug heater might stop working, or in the medium term, the battery might not charge properly.
See also:
Translated on 02-08-2026, 18:20.
Profile PM WWW Garage |
Mpire Profi-Schrauber
Joined: 10/19/2009 Posts: 351 Karma: +192 / -0 Location: Oberpfalz 2019 Skoda Octavia Premium Support
01-03-2018, 21:09 Subject: Install Alternator Without DF Connector in SDI Car |
Hello.
Without the DF, nothing works; the MSTG operates based on the generator load.
The LIMAS (alternator modules) from the AMF 1.4 TDI are also compatible. They have a current output of 120A, which is quite good, and otherwise they have the same connections to the bracket and the freewheel mechanism. The DF connection is also present and fits perfectly (P+P).
I also quickly found refurbished ones from Bosch for €78.
http://www.ebay.de/itm/BOSCH-Lichtmaschine-90A-Arosa-6H-1-7-1-9-D-SDI-VW-Lupo-6X1-Polo-6N1-6N2-6NF-SEAT/192252610554?fits=Model%3ALupo&hash=item2cc32607fa:g:mucAAOSw8vdZb4ZX
Regards, Mpire.
Translated on 02-08-2026, 18:22.
Profile PM Garage |
01-03-2018, 21:49 Subject: Install Alternator Without DF Connector in SDI Car |
What does the MSG do when the DF signal is missing?
The D+ signal alone is sufficient to initiate the operation of the Lima device.
Unfortunately, the linked part is not compatible; an exotic replacement is needed, and the cheapest option on eBay costs three digits.
Translated on 02-08-2026, 18:23.
Profile PM Garage |
01-03-2018, 22:26 Subject: Install Alternator Without DF Connector in SDI Car |
Rüdi wrote: | What does the MSG do when the DF signal is missing?
Unfortunately, the linked part is not suitable; an exotic replacement is installed, and the cheapest option at [website name] costs a three-digit amount | .
I can offer to test it on my car when I have VCDS connected. Unfortunately, this won't be possible until Saturday, as the car won't be back home until tomorrow evening.
Regards, Mpire.
Translated on 02-08-2026, 18:24.
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2400 Karma: +437 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
01-03-2018, 22:35 Subject: Install Alternator Without DF Connector in SDI Car |
Rüdi wrote: | | Unfortunately, the linked part is not suitable; an exotic replacement is installed, and the cheapest option at [website name] costs three digits. |
I admittedly don't know anything about the Arosa or the SDI, but I'm really curious:
What is so exotic about the bra that it *must* be exactly this one?
When I search for "Arosa SDI alternator" on Google Images, the results look like many other alternators from that era. Am I missing a crucial difference?
I thought that the modular design principle would mean that almost anything with the same mounting holes and connector shape would fit (since the pin configuration is usually identical as long as you stay within the production years). So, what am I missing?
The question is...
"Guste, who also installed a more powerful alternator from a Golf V in his 2005 Galaxy (which is the same as the Sharan), an alternator that was never originally included in that model."
Translated on 02-08-2026, 18:26.
Profile PM Garage |
02-03-2018, 10:03 Subject: Install Alternator Without DF Connector in SDI Car |
The design is similar to gasoline engines, it has a 90A output, and requires the connections labeled "D+" and "DF".
And that's where opinions differ; most people who have offered solutions for this car suggest using terminal "W" instead of terminal "DF," which is why I'm asking my question.
In the other terminals that you can find for this car, you will see markings labeled "L" and "DFM".
The goal is to only invest as much as absolutely necessary, especially because the project is only expected to run for a few more months and the budget is tight.
Translated on 02-08-2026, 18:28.
Profile PM Garage |
gnasch likes this. |
02-03-2018, 13:00 Subject: Install Alternator Without DF Connector in SDI Car |
Update: I found a 70A alternator in my stock that was originally installed in an A3 or Golf IV TDI. It also has the DF and W terminals. I briefly compared it to the original one installed in the Arosa, using Bosch's online parts catalog (ecat). The dimensions are identical, as mentioned before. The differences are the terminals and a pulley with a freewheel mechanism for a 6PK belt instead of a 5PK belt on the Seat.
Despite the brutal -13°C temperature, I managed to remove the front panel and extract the faulty alternator. It took a lot of fiddling, but ultimately I finished the job in just under an hour, mostly because I had to constantly search for where all the screws were hidden and change my gloves every 10 minutes.
I left the pulley on; having one extra groove doesn't matter. The belt just needs to be aligned flush with the outside edge, and then everything will line up correctly.
Connected, installed, fresh battery inserted, and the alternator is working. Charging voltage without load: 14.4 volts; with most consumers connected: 14.1 volts.
I haven't checked if there are any error codes stored. It's too cold for me to take the netbook outside, but the car is running fine for now, and the young lady is happy.
I'll see if the old alternator can be salvaged... If there are no problems, then everything will stay as it is. Otherwise, we now have some time to look for a more affordable alternator.
Translated on 02-08-2026, 18:30.
Profile PM Garage |
dieselschrauber likes this. |
03-03-2018, 7:55 Subject: Install Alternator Without DF Connector in SDI Car |
Okay, so after I had completely reassembled everything yesterday, I took it for an extensive test drive, activated all the consumers, and then used my 1551 to read the error memory -> No error entries.
The voltage is as it should be, so the device can function for now. I will provide an update if there are any new developments.
Translated on 02-08-2026, 18:32.
Profile PM Garage |
03-03-2018, 10:08 Subject: Install Alternator Without DF Connector in SDI Car |
Okay... Thanks for the feedback!
Translated on 02-08-2026, 18:33.
05-03-2018, 14:51 Subject: Install Alternator Without DF Connector in SDI Car |
For the sake of posterity:
As I understand it, the terminals are only connected to the regulator and not to the main alternator (alternator).
If a new lingerie machine costs a fortune, you could also get an identical (cheaper) basic model with different connectors and then simply replace the controller.
Greetings.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 02-08-2026, 18:34.
Profile PM Garage |
05-03-2018, 19:30 Subject: Install Alternator Without DF Connector in SDI Car |
In this version, the terminals are not connected to the regulator itself, but rather to the diode plate inside the alternator, and these connections are then brought out externally.
Profile PM Garage |
Herbert Profi-Schrauber
05-03-2018, 20:38 Subject: Install Alternator Without DF Connector in SDI Car |
When the contact DF is connected to the MSG (Main System Generator), the load regulation functions, for example, the operation of the glow plugs. Without a connection, an error code 01117 appears.
The EDC TDI (SDI) does not require terminal W; instead, it uses sensor G28 for engine speed.
The signals at the contacts are completely different.
We've been here before.
Translated on 02-08-2026, 18:35.
07-06-2018, 12:30 Subject: Install Alternator Without DF Connector in SDI Car |
And every day, the SDI consumes its kilometers (km), and soon I'll be able to work on the timing belt... there's plenty of room.
Translated on 02-08-2026, 18:36.
Profile PM Garage |
Hufe Schrauber
Joined: 06/09/2015 Posts: 64 Karma: +22 / -0 Location: Bad Münstereifel 2004 Audi A6 Avant Support
18-07-2018, 7:22 Subject: Load Signal Generator Terminal |
Hello everyone,
May I bring up this topic again?
See the attached log; I'm having a problem with the generator terminal.
It's a Volkswagen Golf 4 (Mk4) 1.9 TDI where the ESP warning light comes on intermittently.
The alternator provides 14 volts, so it's generally okay.
What I don't understand:
The connector on the Lima has two wires. One wire carries approximately 11.3 volts, and the other carries 11.8 volts.
The thick cable leading to the battery shows a voltage of 12.6 volts, or 14.xx volts when in operation.
The connections on the alternator/regulator are only labeled with B1+ and B2+. Therefore, one of the two smaller cables has no label. These "smaller" cables are red and blue and are bundled together in a connector.
One will be the power line from the AI, and the other... what? I don't understand why these two small cables are causing a reduced onboard voltage?!
And why does the error occur sporadically?
Can someone help me?
THANK YOU!!
| Description: |
 Download |
| File name: |
Log-GOLF TDI-WVWZZZ1JZ3W333140-262310km-hufe-20180626-224714230.txt |
| File size: |
5.27 KB |
| Downloaded: |
297 times |
Beste Grüße,
Hufe
Translated on 02-08-2026, 18:38.
Profile PM Email Garage |
Hufe Schrauber
23-07-2018, 13:16 Subject: Install Alternator Without DF Connector in SDI Car |
Update:
Ich habe verstanden, dass das eine die Erregerleitung vom KI Batteriesymbol ist und das andere (vermutlich) der Drehzahlabgriff sein soll, der jedoch auch Spannung führt. Strange...
After researching online, I found a broken cable located below the battery on the starter motor. The insulation was damaged, but the cable itself seemed to be okay. It involved two specific cables (the excitation and speed cables), as well as two cables leading to the air conditioning compressor.
I have insulated the cables and measured them again. Unfortunately, there is no improvement  .
Is there a way to test the Lima regulator?
Beste Grüße,
Hufe
Translated on 02-08-2026, 18:41.
