stolley wrote: |
| The power steering in this Polo uses an electric pump. Therefore, does steering result in a greater load on the alternator, correct? |
Okay.
Quote: |
Can the tensioner make a clicking sound?
Check the free-running mechanism of the generator, if present in this model (remove the belt and manually rotate the rotor abruptly in both directions). If the free-running mechanism is stuck, the arm with the tensioner usually starts to swing.
