Clicking Noise Steering Belt Drive, Polo 9N3
stolley
Karma: +38 / -1   Thank you, like it!
Post18-10-2018, 7:24    Subject: Clicking Noise Steering Belt Drive, Polo 9N3 Quote
Hello everyone,
This morning, after starting the engine (1.4L PD TDI, 432,000 km), I noticed the following:
A clicking sound can be heard in the area of the belt drive (serpentine belt, vehicle with air conditioning) when turning the steering wheel. After a few kilometers, the sound disappeared.
The power steering system in this Polo uses an electric pump. Therefore, steering the vehicle puts a greater load on the alternator, correct?
Can the tensioner make a clicking sound?
Or, to put it another way: it can't possibly be that the clicking sound is coming from the crankshaft, right?!
Volker.
Translated on 02-10-2026, 6:21.
dieselschrauber and Rüdi likes this.
Post18-10-2018, 7:49    Subject: Clicking Noise Steering Belt Drive, Polo 9N3 Quote
stolley wrote:
The power steering in this Polo uses an electric pump. Therefore, does steering result in a greater load on the alternator, correct?
Okay.
Check the free-running mechanism of the generator, if present in this model (remove the belt and manually rotate the rotor abruptly in both directions). If the free-running mechanism is stuck, the arm with the tensioner usually starts to swing.
Translated on 02-10-2026, 6:23.
stolley
Post19-10-2018, 17:15    Subject: Clicking Noise Steering Belt Drive, Polo 9N3 Quote
Roger wrote:
Check the freewheel of the generator, if present on this model (remove the belt, manually rotate the rotor abruptly in both directions). If the freewheel is stuck, the arm with the tensioner usually starts to swing.
Thank you for the tip!
I'll definitely check that out!
Translated on 02-10-2026, 6:24.
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Clicking Noise: Causes & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Painting Terms: A Comprehensive Glossary Technical Articles
No new posts Polo 6N1: Clicking Noise - Diagnosis & Repair Transmission, Chassis, Body & Interior
No new posts Steering Wheel Crack Noise: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Steering Knuckle Noise: Causes & Fixes Diesel Engine Technology
No new posts Polo 6N TDI: Rattling Noise - Diagnosis & Repair Transmission, Chassis, Body & Interior
