ABS/ESP Test: Air in Brake System Won't Go Away
Go to page: 1, 2, 3  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post26-08-2010, 23:17    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Hi, I've made a big mistake. While bleeding the brakes on my Leon (2003) with an ARL engine, I accidentally emptied the reservoir. This caused air to get into the ABS/ESP unit. Since refilling the reservoir and bleeding the brakes again hasn't improved the spongy brake pedal feel, I'll probably have to take it to the workshop. There, they'll use a diagnostic tool to electrically activate the pump, which will bleed the system, and then the reservoir needs to be quickly refilled.
My question is: Can the hydraulic unit also be controlled using VCDS?
Can someone explain the procedure to me?
Best regards, Ronny.
reflexsilber met.
Translated on 04-09-2026, 4:58.
Post26-08-2010, 23:23    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Hello Ronny,
Sure, just go to the ABS section and make the basic adjustments, see:
/viewtopic.php?t=22474
Translated on 04-09-2026, 5:00.
RedR32
Avatar-RedR32
Post26-08-2010, 23:26    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Thanks, Rainer. It's raining heavily here, and I can't sleep either.
reflexsilber met.
Schraubenabreisser
Post29-02-2020, 15:11    Subject: Bleed ABS: How to Bleed ABS Brakes Quote
dieselschrauber wrote:
Hello Ronny,
Best regards, Rainer
Hello diesel mechanics,
Now that I finally own my own VCDS software and no longer have to rely on borrowed copies, I have a question regarding the hydraulic unit bleeding procedure after replacing the brake hoses on my Passat.
After replacing all the brake hoses and experiencing a slight fluid loss, I initially bled the brakes using a conventional pressure bleeding device at 1 bar. Then, in the second step, I tried to bleed the brakes using VCDS, but I only received error messages in the basic settings (block 1, 2, etc.), and I haven't been able to bleed the brakes with VCDS (even after watching YouTube videos). There are no error codes stored in the system.
Can my software version VCDS DRV 19.6.2 do that?
Since the pedal is still slightly soft, I would like to proceed with this step.
Ah, yes, driving with regulated ABS was perfectly possible yesterday, even with the snow.
Thank you for your help. Best regards, Marco.
 File size:  9.16 KB
 Viewed:  2426 times
 File size:  82.74 KB
 Viewed:  3497 times
Fahrzeuge:
Passat 3BG V6 TDI 4 Motion MKB BAU, Golf IV TDI, Golf III GT AFN, diverse T3
Translated on 04-09-2026, 5:02.
Post01-03-2020, 10:50    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Unfortunately, it is not possible to determine which options are available from the image "8226F2F0-8AA9-4EAD-8454-9DAAD74AD2EF.jpeg".
The specific basic settings channels available are determined by the respective control unit, not by VCDS.
Please provide a clear Screenshot of the available options in your brake control unit and a system scan.
Translated on 04-09-2026, 5:04.
Schraubenabreisser
Post01-03-2020, 11:16    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Please provide a readable Screenshot of the available options in your brake control unit and an Autoscan.
 File size:  94.68 KB
 Viewed:  2716 times
Fahrzeuge:
Translated on 04-09-2026, 5:05.
Schraubenabreisser
Post01-03-2020, 16:03    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Please provide a readable Screenshot of the selection options in your brake control unit and an auto-scan.
 File size:  97.21 KB
 Viewed:  1489 times
Fahrzeuge:
Translated on 04-09-2026, 5:06.
Post01-03-2020, 16:09    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
icon_rolleyes.gif Please copy the Autoscan text here.
Furthermore, you need to complete the system function test for the brake control unit. This involves driving the vehicle and applying the brakes, starting with light pressure and gradually increasing it until they lock up.
Translated on 04-09-2026, 5:07.
Schraubenabreisser
Post02-03-2020, 15:25    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Okay, I will work on the system function test for the brake control unit today or tomorrow. Thank you in advance for this information.
Here's the car scan, unfortunately with some errors and likely a faulty VP44 injection pump.
VCDS
The Windows-based VAG/VAS emulator runs on Windows 10 x64.
VCDS Version: DRV 19.6.2 Data version: 20191020 DS308.0
www.Ross-Tech.de
Dealer/Workshop name:
Company number: 000 00000 000000
Self-diagnosis protocol.
Sunday, March 1, 2020, 3:14:25:14233 PM.
Vehicle Identification Number: WVWZZZ3BZ4E185856
License plate: -
Mileage: 294,760 km
Repair order: 03/20
Vehicle type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 294,760 km
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Unit
Label file: DRV\059-907-401-AKE.clb
Part number: 8E0 907 401 J
Component: 2.5l/4VTEDC G000AG 0005
Encoding: 03006
Operating number: WSC 05314
VCID: 2C141A60DE3CAE2F2A-4AE0
Subsystem 1 - Part number: 00006059
Component: 130 106LC 106LCV79820195390
WVWZZZ3BZ4E185856 VWZ7Z0C8517387
"One error found:"
00550 - Injection start control.
08-00 - Limit exceeded.
Readiness: 0 0 X X X
Address 02: Transmission. Label file: DRV\01V-927-156.lbl.
Part number: 8D0 927 156 EA
Part number: AG5 01V 2.5l TDI, Roadworthy certificate number: 2223.
Encoding: 01101
Operating number: WSC 05311.
VCID: 70ACCE1032948ACF56-5118
"One error found:"
18265 - End-of-line signal.
P1857 - 35-10 - Error message from the engine control unit - Intermittent.
VCDS
Page 2.
License plate: -
Address 03: Brake electronics
Label file: DRV\4B0-614-517.lbl
Part number: 4B0 614 517 H.
Part: ABS/ESP all-wheel drive 3428.
Encoding: 04457
VCID: 2600E848C0D0947FFC-51A8
"One error found:"
01486 - System function test enabled.
35-00 - -
Address: 08. Climate/Heating Control. Label file: DRV\3Bx-907-044.lbl.
Part number: 3B1 907 044 J.
Part: CLIMATRONIC B5GP 0006
Encoding: 17000
VCID: 281CE670CAC4820FCE-5118
2 error codes found:
00603 - Actuator motor for footwell/defrost flap (V85)
37-10 - defective - intermittent.
01272 - Actuator motor for central locking (V70).
Address 15: Airbag Label File: DRV\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 C.
Part number: 0E AIRBAG VW61 04 0003.
Encoding: 12357
VCID: 2404F240B6EC666FE2-50F4
"One error found:"
00532 - Power supply voltage.
07-10 - Signal too weak - Sporadic.
Address 17: Control panel module
Label file: DRV\3B0-920-xx5-17.lbl
Part number: 3B0 920 849 A
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V04.
Encoding: 21115
Operating number: WSC 70599.
VCID: 2600E848C0D0947FFC-50F4
"One error found:"
01326 - Control unit for multifunction steering wheel (J453)
49-00 - No communication.
VCDS
Page 3.
License plate: -
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001.
Encoding: 00006
VCID: 70ACCE1032948ACF56-50F4
01303 - Transmitting and receiving device for telephone (R36).
Address 37: Navigation Label file: DRV\3B0-919-887.lbl
Part number: 3B0 919 887 H.
Component: Navigation BNO 0102
Encoding: 00002
Operating number: WSC 00000
VCID: 373E350C177A1DF757-4AC2
"One error found:"
65535 - Control unit defective.
00-00 - -
Address 46: Comfort System
Label file: DRV\1C0-959-799.lbl
Part number: 1C0 959 799 B.
Component: 8S Comfort Device HLO 0003.
Encoding: 00259
VCID: 362038081070E4FF4C-4AE0
Subsystem 1 - Part number: 1C1959801.
Component: 8S Control Unit.FS KLO 0202
Subsystem 2 - Part number: 1C1959802.
Component: 8S Control Unit.BF KLO 0202
Subsystem 3 - Part number: 1C0959811
Component: 8S Control Unit.HL KLO 0202
Subsystem 4 - Part number: 1C0959812
Component: 8S Control Unit.HR KLO 0202
01135 - Sensors for interior monitoring.
36-00 - Interruption.
00928 - Driver's side central locking control unit (F220)
27-10 - implausible signal - sporadic.
VCDS
Page 4.
License plate: -
Address 47: Soundsystem
Label file: DRV\1J0-035-456.lbl
Part number: 1J0 035 456 J
Component: Sound processor 3 0002.
Encoding: 00611
Operating number: WSC 32433.
No error codes found.
Address 55: Headlight range adjustment. Label file: DRV\4Z7-907-357.lbl.
Part number: 4Z7 907 357.
Component: dynamic LWR D09.
Encoding: 00008
VCID: 044492C0162C866F82-4AE0
Address 56: Radio Label file: DRV\3B0-035-186.lbl
Part number: 3B0 035 186 D
Component: Radio BNO 0102.
Encoding: 00400
VCID: 200CFE50A2F47A4F86-4AC2
00852 - Front speakers.
00853 - Rear speakers.
Address 76: Parking assist module
Label file: DRV\3B0-919-283.lbl
Part number: 3B0 919 283.
Bauteil: Parkingsyst. PA RDW D01
Encoding: 01114
VCID: 6582AF44FD565F6735-5118
End -------- (Duration: 04:02, Battery voltage start/end: 13.9V/14.2V)
Fahrzeuge:
Translated on 04-09-2026, 5:26.
Post02-03-2020, 18:31    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Have you finished the system function test yet?
Was ist der Kontext?
Translated on 04-09-2026, 5:44.
Schraubenabreisser
Post03-03-2020, 12:36    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Unfortunately, the system function test is not yet complete.
Driving with the ABS initially illuminated, and then performing braking maneuvers, only caused the ABS warning light to turn off. Subsequently, braking with ABS did not help to complete the test as indicated by the diagnostic system.
I didn't even bother to bleed the system again.
I'm going to take a little more time tonight and try it again icon_wink.gif.
Thank you for asking.
Fahrzeuge:
Translated on 04-09-2026, 5:45.
Karma: +1343 / -0   Thank you, like it!
dieselschrauber likes this.
Post03-03-2020, 14:25    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Hi there.
You must perform the test correctly, for example, like this:
/viewtopic.php?t=26751 or
http://wiki.ross-tech.com/wiki/index.php/ESP_System_Function_Test
It's important to build up pressure at the beginning and then execute the subsequent driving maneuvers, especially when taking turns.
Translated on 04-09-2026, 5:46.
Schraubenabreisser
Post04-03-2020, 10:57    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Thank you for the reminder. I will revisit this and address it according to the guidelines in the next few days, as I won't be able to do it today. Of course, I will provide feedback again.
Marco
Fahrzeuge:
Translated on 04-09-2026, 5:47.
RĂŒdi
Post04-03-2020, 11:30    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
And I had to repeat the whole process multiple times, as I personally experienced with my Passat 3B and 3BG 4-Motion.
Schraubenabreisser
Post06-03-2020, 9:50    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
Hello everyone,
Thank you for the information. Yesterday, I was able to work on the topic for about an hour, but I couldn't find more time.
Unfortunately, it hasn't changed much, except that my car now has an off-road look thanks to the unpaved area and countless puddles.
I followed the instructions carefully and would like to describe my process. I'm sure I made a small mistake somewhere in the procedure, even though I repeated it 20 times.
- Connect VCDS to check if the system test is still active.
-Turn on the ignition, start the engine (I have an automatic transmission, in Park).
-VCDS displays a message indicating "Active," the ABS/ESP warning light is illuminated, and a warning sound is emitted.
-VCDS terminated.
-both symbols are still lit.
- Apply the brakes with increased brake pressure, and the ESP (Electronic Stability Program) will disengage.
- Select driving mode D and accelerate to 20 km/h.
- Maintain speed and turn the steering wheel 90 degrees.
-Circular motion at speeds exceeding 20 km/h until ABS is activated.
- Stopped and re-read the memory, unfortunately, no success.
Repeated attempts with left turns, sometimes right turns, and sometimes with the steering wheel turned 180 degrees have unfortunately not been successful so far.
Perhaps you have another idea on how I can achieve my goal, or you might be able to identify an error in the process?
Thank you, best regards, Marco.
Fahrzeuge:
Translated on 04-09-2026, 5:49.
Post06-03-2020, 12:09    Subject: ABS/ESP Test: Air in Brake System Won't Go Away Quote
You're not patient enough. I once had this mode in an A3 8L and had to drive around for a while to get it to work.
Anyway, I learned from that not to activate any test modes carelessly. icon_cool.gif
Translated on 04-09-2026, 5:51.
No new posts P1000 - OBD2 System Test Incomplete Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts ABS Light On: Troubleshooting Air in Brake Lines On-Board Diagnostics (OBD)
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts Glow Plug Not Turning Off? Engine Won't Start. Diesel Engine Technology
