Two cars, split into two separate posts for better clarity.
He experienced the problem with the differential pressure sensor as described earlier, which could also have been resolved through other means. I still cannot access or adapt the function via VCDS.
The steering and braking electronics were temporarily unresponsive, and the control unit is not responding.
Access via laptop, battery operation, no antivirus software, no other use besides VCDS. The battery is so good that it could power a Tesla
Friday, May 3, 2019, 7:56:07 PM: 00397
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x86.
VCDS Version: RKS 18.9.0.2 HEX-V2 CB: 0.4436.4
Data as of: 20181004 DS296.0
http://shop.dieselschrauber.org/en
Vehicle Identification Number: TMBGE61Z962226440
License Plate: OCTI
Mileage: 344,440 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 69 72 76
77 7D
Mileage: 344,440 km
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: Error 0010.
52-door electric passenger door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking assist -- Status: OK 0000
77-Phone -- Status: OK 0000
7D Auxiliary Heater -- Status: OK 0000
Address 01: Engine Control Module
Label file: DRV\03G-906-021-BMM.clb
Part number SW: 03G 906 021 GD Hardware:
Part: R4 2.0L EDC G000SG 8484
Revision: --H02--- Serial Number: SKZ7Z0E3357007
Encoding: 0000072
Operating number: WSC 11111 111 11111
VCID: 678A4B8D936DCCEF3FF-8032
No error codes found.
Readiness: 0 0 0 0 1 0
Address 03: Brake Electronics
Label file: DRV\1K0-907-379-MK60-F.lbl
Part number SW: 1K0 907 379 AA, Hardware: 1K0 907 379 AA.
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0006786
Operating number: WSC 73430 790 00000
VCID: 71BE25D5ADA9025F61B-8024
Address 08: Climate Control/Heating. Label file: DRV\1K0-907-044.lbl
Part number: 1Z0 907 044 J
Component: Climatronic PQ35 084 0305
Operating Number: WSC 00000 000 00000
VCID: 3D26C9E5A171B63FB53-8068
"One error found:"
00229 - Refrigerant pressure.
002 - lower limit exceeded.
Address 09: Central Electronics Label file: .DRV\3C0-937-049-23-H.lbl
Part number SW: 3C0 937 049 E, HW: 3C0 937 049 E.
Component: On-board network module H37 1002.
Revision: 00H37000 Serial Number: 00000003908076
Encoding: E18A8F130004140000110D000000000000087F065C
VCID: 2B02F7BD4F05288F1B7-807E
Subsystem 1 - Part number: 1Z1 955 119 A
Label file: DRV\1KX-955-119.CLB
Component: Wiper SK351 012 0401.
Encoding: 00065525
Subsystem 2 - Part number: 1K0 955 559 T
Label file: DRV\1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Encoding: 00208933
"One error found:"
02395 - Lamp for front right side marker light (M3).
012 - Electrical fault in the circuit.
Environmental conditions:
Error status: 01101100
Error priority: 2
Error frequency: 1.
Lost Count: 46
Mileage: 344,445 km
Time: 0.
one
Voltage: 11.75 V
one
one
text
aus
text
out
text
from
text
from
Address 15: Airbag
Label file: DRV\1K0-909-605.lbl
Part number SW: 1K0 909 605 S, HW: 1K0 909 605 S.
Part: Q2 AIRBAG VW8 026 0800
Revision: 09026000 Serial Number: 0038ND0VR66V
Encoding: 0020786
VCID: 3C20C4E1BA6BBF3782D-8068
Subsystem 1 - Serial number: 6332MSME0E7517409.
Subsystem 2 - Serial number: 6342MSME0F3F1830H
Subsystem 3 - Serial number: 6351HSME0934223D3
Subsystem 4 - Serial number: 6361HSME09340E79E.
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 AG, Hardware number: 1K0 953 549 AG.
Component: J0527 034 0070
Encoding: 0002042
VCID: 77AA1BCDC3CD5C6FAFF-8022
Subsystem 1 - Part number: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Control panel module
Label file: DRV\1K0-920-xxx-17.lbl
Part number: 1Z0 920 841 E
Component: COMBINATION INSTRUMENT VD1 0920
Encoding: 0005101
Operating number: WSC 24448 002 1048576
VCID: 3828D8F18E539317665-806C
Address 19: Diagnostic interface
Label file: .DRV\1K0-907-530-V1.clb
Part number SW: 1K0 907 530 F, HW: 1K0 907 951.
Component: Gateway H10 0120
Revision: H10
Serial number: 28001061220238
Encoding: 7D3F4FC8072302
VCID: 2A0CF2B940FF3187E01-807E
Address 25: Immobilizer
Label file: DRV\1K0-920-xxx-25.clb
Component: IMMO VD1 0920
Address 37: Navigation
Label file: DRV\1T0-919-887.lbl
Part number: 1Z0 919 887 B
Component: Navigation 0412
Encoding: 0000002
VCID: 47CAAB0DF3ADECEF1FF-8012
Address 42: Door electric driver
Label file: DRV\1K0-959-701-MIN2.lbl
Part number: 1T0 959 701 B
Component: Door Seal 024 2345
Encoding: 0000246
VCID: 3634D6C984476567749-8062
Address 44: Steering Assist
Label file: DRV\1Kx-909-144-G2V2.clb
Part number: 1K1 909 144 K
Component: EPS_ZFLS, Size 5, Part Number D06 1701.
VCID: 3332EFDD9735704F537-8066
Address 46: Comfort System. Label file: .DRV\1K0-959-433-MIN.clb
Part number: 1K0 959 433 AK
Component: KSG 0401
Encoding: 00D002007F2D8505484FC61004CC
VCID: 79AE1DF5F5D94A1FD9B-802C
Subsystem 5 - Part number: 1Z0 951 171 A
Component: Tilt Sensor 008
Encoding: 00000000
Operating number: WSC 00000
Subsystem 6 - Component: Sounder, No Answer.
Subsystem 7 - Part number: 1Z0 951 171 A
Component: Interior monitoring 008.
"One error found:"
01134 - Alarm horn (H12)
004 - No signal/communication.
Address 52: Door electric, passenger side.
Label file: DRV\1K0-959-702-MIN2.lbl
Part number: 1T0 959 702 B.
Encoding: 0000246
VCID: 372ADBCD834D9C6F6FF-8062
Address 55: Headlight range adjustment.
Label file: DRV\1T0-907-357.lbl
Part number: 1T0 907 357.
Component: Dynamic LWR 0003.
Encoding: 0000007
VCID: 74B02CC1D2BB37778AD-8020
Address 56: Radio
Label file: DRV\1T0-035-095.lbl
Part number: 1T0 035 095.
Component: Radio 0412
Encoding: 0004400
VCID: 6B8237BD8F85E88F5B7-803E
Address 62: Door electric, left/right.
Label file: DRV\1K0-959-703-GEN2.lbl
Part number: 1K0 959 703 E
Component: Door seal 021 2435
Encoding: 0000144
VCID: 323CEAD9682F7947581-8066
Address 69: Trailer
Label file: DRV\8P0-907-383.lbl
Part number SW: 8P0 907 383 HW: 8P0 907 383
Component: ANHAENGERELEKTR H01 0010
Encoding: 0000001
VCID: 76B416C9C4C72567B49-8022
Address 72: Door electric strike, right side.
Label file: DRV\1K0-959-704-GEN2.lbl
Part number: 1K0 959 704 E
Encoding: 0000144
Address 76: Parking Assist
Label file: DRV\1Z0-919-283.lbl
Part number SW: 1Z0 919 283 C. Hardware: 1Z0 919 283 C.
Component: Parking Assist System, 8-Channel, Part Number H04 0020.
Encoding: 0010001
VCID: 3E24CEE9AC77AD27AC9-806A
Address 77: Telephone Label file: DRV\5P0-862-335.lbl
Part number SW: 5P0 862 335 B, HW: 5P0 862 335 B.
Component: FSE_2P5x H21 0060
Revision: 00000001 Serial Number: 00000000391371
Encoding: 0000411
Address 7D: Auxiliary Heater
Label file: DRV\1K0-963-235.lbl
Part number SW: 1K0 963 235 E, Hardware number: 1K0 963 235 E.
Component: PTC element 0404
Revision: 00900000 Serial number:
VCID: 2D06F9A5711126BF053-8078
End--(Duration: 01:28, Battery voltage start/end: 11.9V/11.8V. Initial voltage: 11.9V)---
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
