vag-driver Profi-Schrauber
25-06-2019, 6:39 Subject: Sharan 7N Steering Rack Support |
Last night, I noticed that the mounting brackets were already starting to crack. I'm talking about that aluminum die-cast part that secures the stabilizer bar behind the splash shield.
I definitely need to replace that before my vacation.
Is a re-alignment necessary afterwards? To me, it looks like the drill holes are longitudinal, so I'm missing the fixed point. However, I know that VW didn't perform an alignment on my old Sharan. Is there a trick to this?
Andreas
Translated on 27-10-2026, 18:24.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
dieselschrauber likes this. |
26-06-2019, 2:12 Subject: Sharan 7N Steering Rack Support |
hello,
If you're referring to the lower control arm mounting points:
don't think too much.
Remove and replace either 3 or 6 screws... nothing else needs to be disassembled, and no wheel alignment is required.
Translated on 27-10-2026, 18:25.
26-06-2019, 12:12 Subject: Sharan 7N Steering Rack Support |
That's exactly what I meant. I ordered the reinforced version from Meyle HD. They will be replaced tonight.
Andreas
Translated on 27-10-2026, 18:26.
27-06-2019, 9:40 Subject: Sharan 7N Steering Rack Support |
The exchange has been completed. In the picture, you can already see a noticeable visual difference. I can't say how long the bearing will last. The driving performance is great again.
| Description: |
| File size: |
5.16 MB |
| Viewed: |
600 times |
Andreas
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1512 Karma: +646 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
28-06-2019, 7:58 Subject: Sharan 7N Steering Rack Support |
Unfortunately, these bearings are undersized; the same ones are used in the Polo 9N, and they don't last forever.
Profile PM Garage |
