High-pressure pump screw sheared off, need help
bindpe
Karma: +5 / -2   Thank you, like it!
Post13-06-2019, 12:59    Subject: High-pressure pump screw sheared off, need help Quote
Hello.
I wanted to replace the turbocharger on my Opel 1.7 CDTI (17DTR), but unfortunately, one of the screws broke off in the process.
The pump is driven by the timing belt in this engine and is located in a very unfavorable position between the engine block and the splash guard.
Does anyone have a good suggestion for me? Should I try to drill it out, or should I just remove it altogether?
How would you approach that?
Thank you very much.
 File size:  1.9 MB
 Viewed:  1210 times
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 07-07-2026, 4:31.
Post13-06-2019, 19:04    Subject: High-pressure pump screw sheared off, need help Quote
In that spot, I wouldn't expect to find any rust, so a stripped screw should be relatively easy to remove.
I would try to drill a hole in the center of the screw and then use an extractor.
Translated on 07-07-2026, 4:32.
bindpe
Post13-06-2019, 20:25    Subject: High-pressure pump screw sheared off, need help Quote
No, there's no rust there, I have no idea why the screw broke off.
I took another look at it carefully, and there's no way to drill in that space while it's installed. I guess I'll have to remove the pump.
Have you ever disassembled a common rail pump before? Is there anything I should be aware of?
Spritmonitor.de
Translated on 07-07-2026, 4:33.
Post13-06-2019, 21:17    Subject: High-pressure pump screw sheared off, need help Quote
Please pay close attention to cleanliness! Make sure to thoroughly bleed the system before attempting to start it. icon_idea.gif
bindpe
Post15-06-2019, 7:07    Subject: High-pressure pump screw sheared off, need help Quote
Thank you for the information.
I will pay attention to cleanliness.
"How can I best bleed the system? Unfortunately, the car doesn't have a pre-lift pump, and the manufacturer's repair manual doesn't have any information about it either."
Thank you.
Spritmonitor.de
Translated on 07-07-2026, 4:34.
No new posts Doku A3 8L, Korrosion an Schraube Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Screw broken off in the turbocharger Diesel Engine Technology
No new posts V6 TDI Timing Belt Tensioner: Broken Bolt. Diesel Engine Technology
No new posts Missing screw from brake disc assembly (torn off) - is th... Transmission, Chassis, Body & Interior
No new posts Zylinderkopfdichtung defekt - bitte um Hilfe Diesel Engine Technology
