Sharan 7N Steering Rack Support
vag-driver
Post25-06-2019, 6:39    Subject: Sharan 7N Steering Rack Support Quote
Last night, I noticed that the mounting brackets were already starting to crack. I'm talking about that aluminum die-cast part that secures the stabilizer bar behind the splash shield.
I definitely need to replace that before my vacation.
Is a re-alignment necessary afterwards? To me, it looks like the drill holes are longitudinal, so I'm missing the fixed point. However, I know that VW didn't perform an alignment on my old Sharan. Is there a trick to this?
Andreas
Translated on 27-10-2026, 18:24.
bloesch
dieselschrauber likes this.
Post26-06-2019, 2:12    Subject: Sharan 7N Steering Rack Support Quote
hello,
If you're referring to the lower control arm mounting points:
don't think too much.
Remove and replace either 3 or 6 screws... nothing else needs to be disassembled, and no wheel alignment is required.
Translated on 27-10-2026, 18:25.
vag-driver
Post26-06-2019, 12:12    Subject: Sharan 7N Steering Rack Support Quote
That's exactly what I meant. I ordered the reinforced version from Meyle HD. They will be replaced tonight.
Andreas
Translated on 27-10-2026, 18:26.
vag-driver
Post27-06-2019, 9:40    Subject: Sharan 7N Steering Rack Support Quote
The exchange has been completed. In the picture, you can already see a noticeable visual difference. I can't say how long the bearing will last. The driving performance is great again.
 File size:  5.16 MB
 Viewed:  600 times
Andreas
Karma: +646 / -0   Thank you, like it!
Post28-06-2019, 7:58    Subject: Sharan 7N Steering Rack Support Quote
Unfortunately, these bearings are undersized; the same ones are used in the Polo 9N, and they don't last forever.
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Problems? Get Expert Help Now! Transmission, Chassis, Body & Interior
No new posts Steering Golf V On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Golf 6: Heavy Steering - Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Steering Noise: Causes and Solutions Transmission, Chassis, Body & Interior
