samson
02-08-2019, 15:23 Subject: DPF Cleaned: 2.0 TDI CFFB Engine |
I replaced the turbo, the EGR valve, and the differential pressure sensor on that vehicle.
The DPF has been cleaned.
What's the best way to approach learning everything from scratch?
Do I need an access code to initialize the particulate filter?
Can someone give me that?
Before the cleaning and regeneration, I tried a forced regeneration, which resulted in the error code P0299, indicating that the boost pressure regulation limit was exceeded.
The error is still occurring.
I wanted to relearn everything from scratch and then see if the problem was gone.
Translated on 25-10-2026, 17:35.
02-08-2019, 17:09 Subject: DPF Cleaned: 2.0 TDI CFFB Engine |
The error will not disappear. You can recalibrate the differential pressure sensor (not strictly necessary, but it speeds up the learning process), and the ash mass needs to be reset.
If the boost pressure is too low and the turbocharger is working correctly, you either still have a blockage in the exhaust system, the EGR valve is not closing properly, the temperature sensor on the turbocharger is not sealed, there is insufficient vacuum at the variable geometry turbocharger (due to a leak in the system, a faulty solenoid valve, or a failing vacuum pump), or there is a leak in the charge air system.
"Is there a specialized article on this topic? Please use the search function. My list is not exhaustive."
And the Autoscan feature is missing.
Translated on 25-10-2026, 17:37.
Profile PM WWW Garage |
If the boost pressure is too low and the turbocharger is working correctly, you either still have a blockage in the exhaust system, the EGR valve is not closing properly, the temperature sensor on the turbocharger is not sealed, there is insufficient vacuum at the variable turbine geometry (VTG) (due to a leak in the system, a faulty solenoid valve, or a failing vacuum pump), or there is a leak in the charge air system.
Translated on 25-10-2026, 17:39.
samson
02-08-2019, 23:29 Subject: DPF Cleaned: 2.0 TDI CFFB Engine |
"My main goal right now is to completely revamp everything."
I need to initialize the particulate filter, which requires an access code. The EGR valve is new and has been adapted. I have cleared the learned values for the differential pressure sensor.
How do I reset the ash mass? I couldn't find any information on that.
Is this the particle filter initialization with the KM value?
I'll do the autoscanning tomorrow.
Translated on 25-10-2026, 17:41.
samson
03-08-2019, 11:14 Subject: DPF Cleaned: 2.0 TDI CFFB Engine |
Here's the car scan.
| Description: |
 Download |
| File name: |
Log-VSSZZZ7NZCV-173560km-Alhambra.txt |
| File size: |
15.23 KB |
| Downloaded: |
345 times |
samson
05-08-2019, 13:25 Subject: DPF Cleaned: 2.0 TDI CFFB Engine |
Just like in this case, the particulate filter needs to be initialized in my system as well.
I need the access code for that.
/viewtopic.php?t=24243&highlight=ashes
That would adjust the ash content.
How do I get Cide?
[/url]
Translated on 25-10-2026, 17:42.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
05-08-2019, 14:56 Subject: DPF Cleaned: 2.0 TDI CFFB Engine |
Normally, the VCDS code should appear as a hint text when the mouse cursor is moved over the login input field. Is this not the case for you, or was this trick not yet known?
Translated on 25-10-2026, 17:43.
Profile PM Garage |
samson
05-08-2019, 15:59 Subject: DPF Cleaned: 2.0 TDI CFFB Engine |
For me, only the two codes for regeneration are displayed.
| Description: |
| File size: |
80.45 KB |
| Viewed: |
972 times |
Herbert likes this. |
05-08-2019, 16:14 Subject: DPF Cleaned: 2.0 TDI CFFB Engine |
Quote: | | For me, only the 2 codes for regeneration are displayed. |
That's not correct. In your Screenshot, it says e.g..
That doesn't mean it's exclusively about regeneration!
/viewtopic.php?t=27732&highlight=differential pressure sensor
Quote: |
In newer engine control units, the differential pressure sensor is often adjusted using the "Adjustment" function. |
Translated on 25-10-2026, 17:44.
samson
dieselschrauber likes this. |
05-08-2019, 22:35 Subject: DPF Cleaned: 2.0 TDI CFFB Engine |
I must have missed that.
Now I was able to initialize it.
"Thank you."
Translated on 25-10-2026, 17:45.
11-08-2019, 8:52 Subject: DPF Cleaned: 2.0 TDI CFFB Engine |
Thank you for the feedback  .
