USB Adapter: HEX-V2 Firmware Update
loft03
Post28-04-2020, 13:07    Subject: USB Adapter: HEX-V2 Firmware Update Quote
"I'm unable to update the firmware. I'm getting an error message, see the image. I've tried this with multiple internet connections..."
 File size:  22.3 KB
 Viewed:  1761 times
Translated on 01-10-2026, 12:15.
Post29-04-2020, 18:57    Subject: USB Adapter: HEX-V2 Firmware Update Quote
Ross-Tech says it's working, but the server was briefly down earlier... please just try again.
loft03
Post30-04-2020, 9:36    Subject: USB Adapter: HEX-V2 Firmware Update Quote
Unfortunately, it's still the same error.
Best regards, Georg.
 File size:  21.6 KB
 Viewed:  1578 times
Karma: +1343 / -0   Thank you, like it!
dieselschrauber likes this.
Post30-04-2020, 11:25    Subject: USB Adapter: HEX-V2 Firmware Update Quote
Try using the latest version of VCDS. I had a similar error last year that was resolved after an upgrade.
Translated on 01-10-2026, 12:16.
loft03
Post30-04-2020, 12:56    Subject: USB Adapter: HEX-V2 Firmware Update Quote
I have the latest version, but it doesn't work with the 20.4.1 version from the Ross-Tech website.
 File size:  2.21 KB
 Viewed:  380 times
Post30-04-2020, 15:24    Subject: USB Adapter: HEX-V2 Firmware Update Translating...
[Translating...]
Hmm.
Namenlos.pdf
 File name:  Namenlos.pdf
 File size:  89.19 KB
 Downloaded:  257 times
Post30-04-2020, 19:15    Subject: USB Adapter: HEX-V2 Firmware Update Quote
Okay, so it worked for Herbert, now I'm going to try updating my HEX-NET.
For those where it didn't work: If you have a firewall installed, you need to allow outgoing connections on port 11000.
Translated on 01-10-2026, 12:17.
Post30-04-2020, 20:02    Subject: USB Adapter: HEX-V2 Firmware Update Quote
Hm? It works.
 File size:  21.27 KB
 Viewed:  576 times
loft03
Post05-05-2020, 9:27    Subject: USB Update: Firewall Port 11000 Configuration Quote
It was probably due to that – I'm not familiar with firewall settings. It worked with a different internet connection.
Just out of curiosity: What does it mean?
CB:
FW:
CFB:
BL:
DS:
Interesting, because my current CB (credit balance) is "only" 0.4508, and I don't have a DS (debit standing).
 File size:  8.13 KB
 Viewed:  413 times
Translated on 01-10-2026, 12:18.
Post05-05-2020, 19:18    Subject: USB Adapter: HEX-V2 Firmware Update Quote
Code Block, Firmware, Bootloader, Dataset...
If you perform an Autoscan of a car using HEX-NET and, for example, view the measured values, VCDS Mobile remembers this for the next update, and you will then see more with VCDS-Mobile. icon_wink.gif
For the Windows-based function with VCDS, the latter is irrelevant. However, it's very useful for on-the-go use (via mobile phone).
Translated on 01-10-2026, 12:19.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Firmware Update Time: How Long Does It Take? Diesel Engine Technology
No new posts Firmware Update Failed: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts HEX-NET Firmware update Server not reachable On-Board Diagnostics (OBD)
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
