Audi S5 8T, 4.2L Manual Transmission, ACC Coding
gabor.ruppert
Post18-11-2019, 16:39    Subject: Audi S5 8T, 4.2L Manual Transmission, ACC Coding Quote
I want to retrofit ACC (Adaptive Cruise Control) into my S5. Everything is installed and coded except for the sensor itself.
I received instructions, but unfortunately, the S5 with manual transmission is not documented.
2BA0 is the coding for S4/S5 models with automatic transmission and without a trailer hitch.
The control unit is located at address 13 and has the identifier J428. The coding is a six-digit number with two zeros at the beginning.
I would be very grateful if someone could provide information about the CAUA system, specifically regarding its operation with a manual gear shift.
Sure, here's the translation:
"Thank you in advance!"
Translated on 12-07-2026, 1:50.
Post21-11-2019, 23:09    Subject: Audi S5 8T, 4.2L Manual Transmission, ACC Coding Quote
Just in case someone with a similar configuration to yours can help you, an automatic system scan would be very useful!
Translated on 12-07-2026, 1:51.
gabor.ruppert
Post23-11-2019, 15:04    Subject: Solution? Quote
At first glance, the same encoding seems to work for all S4/S5 models. So far, I haven't encountered any problems. It's possible to switch between modes without issue, and a message appears indicating that the speed is too low.
Code:
Saturday,23,November,2019,07:37:23:38133
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ8T29Axxxxxx   License Plate:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 08 09 13 15 16 17 19 36 42 46 52 53 55 56 77
VIN: WAUZZZ8T29Axxxxxx   Mileage: 115360km-71681miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAUA)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 J    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0004
   Revision: 76H10---
   Coding: 01140003180F0220
   Shop #: WSC 06325 123 12345
   VCID: 41DEBE7C5180855F869-8014
No fault code found.
Readiness: 0000 1001
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AH    HW: 8K0 907 379 AH
   Component: ESP8 quattro  H04 0230
   Revision: --------    Serial number: --------------
   Coding: 110D00
   Shop #: WSC 06325 000 00000
   VCID: 7F5AF88467F433AFB0D-802A
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 BP    HW: 8K0 907 064 BP
   Component: BCM2 1.1      H90 0247
   Revision: 00002001
   Coding: 030000
   Subsystem 1 - Part No SW: 8T0 959 754 Q    HW: 8T0 959 754 Q
   Component: FBSAUDIB8 IDG  H37 0060
   Serial number: 0509000005389011
   Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: ELVAUDIB8  H36 0041
   Serial number: 0209000011616009
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001235192
   Coding: C80170250F2400001000
   VCID: 42DCB17054869E479F3-8016
Address 08: Auto HVAC (J255)       Labels:. 8Tx-820-043-3Z.clb
   Part No SW: 8T1 820 043 AD    HW: 8T1 820 043 AD
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C3000000    Serial number: 01120220091392
   Coding: 48020006
   VCID: 73B224B45BBC67CFC45-8026
Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H24 0253
   Revision: 05024001    Serial number: 00000000223287
   Coding: 260050914134AF010009000000005D5D0F1C038800010141000000
   VCID: 3038EBB8EA2A1CD7797-8064
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 030309  H13 0040
   Serial number: SWF09030030611
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10406395
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0090
   Serial number: 00000000000203090611
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561     HW: 8K0 907 561
   Component: ACC2          H09 0080
   Serial number: 00000000000000
   Coding: 002BA0
   Shop #: WSC 12345 123 12345
   VCID: 6FBA28C43794432F20D-803A
Address 15: Airbags (J234)       Labels:* 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0038JD1ELPHZ
   Coding: 30313433363030303030554A304C38543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
   ROD: EV_AirbaECUVWAUDI010_A02.rod
   VCID: 3C20CF8836E2E8B7D5F-8068
   Crash sensor for side airbag: driver side:
   Serial number: 6334MSME4463792EM
   Crash sensor for side airbag: front passenger side:
   Serial number: 6344MSME4433472FG
   Crash sensor for side airbag: rear: driver side:
   Serial number: 6352QSME0F1A4908O
   Crash sensor for side airbag: rear: passenger side:
   Serial number: 6362QSME151B510CE
   Crash sensor for front airbag: driver side:
   Serial number: 63732SME77213936.
   Crash sensor for front airbag: front passenger side:
   Serial number: 63832SME00225604J
Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HK700028
   Coding: 00001E
   Shop #: WSC 06335 123 12345
   VCID: 3E24C580207EFAA7FBB-806A
   Component: E221 - MFL  H02 0003
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 115368 km
                    Time Indication: 0
                    Date: 2019.11.22
                    Time: 18:04:45
Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 931 B    HW: 8T0 920 931 B
   Component: KOMBIINSTR.   H32 0224
   Revision: 00200000    Serial number: 9D7654239
   Coding: 0F0D010007000008000000
   VCID: 3634DDA0084E32E723B-8062
Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
   Part No SW: 8T0 907 468 S    HW: 8T0 907 468 J
   Component: GW-BEM 6CAN   H06 0101
   Revision: HB500049    Serial number: 4900H09430000D
   Coding: 000303
   VCID: 51FE8E3C81E075DF169-8004
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0160
   Serial number: 1906BD04250209
Address 36: Seat Mem. Drvr (J136)       Labels:. 8T0-959-760.clb
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001235217
Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Component: TSG FA        H11 0250
   Revision:             Serial number: 0000008518133
   Coding: 011C02224000120102
Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0117211829
   Coding: 011A0680003904400330000000000000
   Subsystem 1 - Part No: 8K0 951 177
   Component: DWA-Sensor  H02 0040
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Component: TSG BF        H11 0250
   Revision:             Serial number: 0000008531863
   Coding: 011C02224C00120102
   VCID: 40D8BB785A8A8C57897-8014
Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 00000000327134
   Shop #: WSC 00000 000 00000
   VCID: 3332E4B41B3C27CF045-8066
Address 55: Headlight Range        Labels: 8K0-907-357.clb
   Part No: 8K5 907 357
   Component: Dynamische LWR  H01 0010
   Revision: 00000001    Serial number:
   Coding: 0000002
   Shop #: WSC 06324 000 00000
   VCID: 77AA10A443C40BEFF8D-8022
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 195 AA    HW: 8T1 035 195 AA
   Component: Symphony3     H01 0300
   Revision: 00000003    Serial number: AUZ5Z4I1084698
   Coding: 050004820404850053D9470001
   VCID: 76B41DA048CE72E7E3B-8022
2 Faults Found:
02259 - Information Display and Control Head (Front) (J685)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 230
                    Mileage: 115358 km
                    Time Indication: 0
                    Date: 2019.11.22
                    Time: 13:14:26
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 230
                    Mileage: 115358 km
                    Time Indication: 0
                    Date: 2019.11.22
                    Time: 13:14:29
Address 77: Telephone        Labels: 8P0-862-335.lbl
   Part No SW: 8T0 862 335 C    HW: 8T0 862 335 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005062046
   Coding: 0010390
   VCID: 3A2CC9903056D687C73-806E
End----------(Elapsed Time: 01:23, VBatt start/end: 12.3V/12.3V)-----------
Translated on 12-07-2026, 1:52.
Post23-11-2019, 15:32    Subject: Audi S5 8T, 4.2L Manual Transmission, ACC Coding Quote
Hello.
Was zeigt der Codierungsassistens für das ACC-Steuergerät eigentlich an? SScreenshots?
No new posts Gear oil change T6 manual transmission Troubleshooting & Guides
No new posts Document: Flange, Wave, Gearbox 012 and 01A Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Audi RS6: Airbag Coding After Steering Wheel Install On-Board Diagnostics (OBD)
No new posts AFN TCU: Automatic & Manual Transmission Control On-Board Diagnostics (OBD)
No new posts Engine control unit cannot be coded for manual transmission On-Board Diagnostics (OBD)
No new posts Decoding 01002: What Does This Code Mean? On-Board Diagnostics (OBD)
