Polo 9n fog lights turn on with ignition
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
abc_turner
Post16-05-2020, 18:31    Subject: Polo 9n fog lights turn on with ignition Quote
Hello. I hope someone can help me. On my father's Polo, the fog lights are turning on when the ignition is turned on, even without pressing the switch. The switch is in the "off" position. The car has daytime running lights. Is that related to it?
I checked the fuse box. The tfl pin was connected. That didn't help. The nsw light still comes on when the ignition is on. I disconnected the pin for the nsw. Then it turns off. So, the electricity comes from the switch.
Is this necessary because of the daytime running lights? Or is the switch defective? Please help.
Translated on 04-07-2026, 9:17.
vag-driver
Post17-05-2020, 11:56    Subject: Polo 9n fog lights turn on with ignition Quote
It's possible that the switch is faulty. Do you have the option of trying a different switch to test? It would also be helpful to run a diagnostic check via the OBD interface. Then you can at least see the error messages, if there are any.
Andreas
Translated on 04-07-2026, 9:19.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kombiinstrument Polo ab 10.99 bis 09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Light Flashing: DPF & Engine Error Codes Diesel Engine Technology
No new posts white P21W, which glow red (Passat with clear NSL) Transmission, Chassis, Body & Interior
No new posts Zündung an oder aus bei Masseanschluß an Batterie Diesel Engine Technology
No new posts Supply voltage for steering angle sensor G85: Ignition an... On-Board Diagnostics (OBD)
