Joined: 04/12/2002 Posts: 18102 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
Rüdi likes this. |
20-12-2022, 20:56 Subject: Airbag-coding with VCDS
**Introduction:**
This document provides instructions on how to code airbags using a VCDS (VAG-COM Diagnostic System).
**Safety Precautions:**
* Always disconnect the battery before working on the airbag system.
* Wear appropriate safety glasses and gloves.
* Be careful when handling airbag components, as they can be fragile.
* If you are not comfortable working on the airbag system, consult a qualified technician.
**Tools and Materials:**
* VCDS diagnostic system
* VCDS cable
* Airbag module
* Replacement airbag (if necessary)
* Screwdrivers
* Pliers
* Wire strippers
* Electrical tape
**Procedure:**
1. Connect the VCDS diagnostic system to the vehicle's OBD-II port.
2. Turn on the ignition and select the "Airbag" diagnostic mode.
3. Select the airbag module you want to code.
4. Follow the on-screen instructions to enter the coding mode.
5. Enter the desired airbag code using the VCDS interface.
6. Confirm the code and save it to the airbag module. |
Airbag coding with VCDS for index-based airbag control units.
| Description: |
**Introduction:**
* VCDS cable
* Airbag module
* Screwdrivers
* Pliers
* Wire strippers
* Electrical tape
**Procedure:**
 Download |
| File name: |
Airbag-Codierung.pdf |
| File size: |
541.2 KB |
| Downloaded: |
15984 times |
