Peugeot 206 and the error memory.
Stummel
Post24-07-2011, 20:00    Subject: Peugeot 206 and the error memory. Quote
hi
My girlfriend has a 2004 Peugeot 206... something with a 1.0 or 1.1 liter gasoline engine... a real gas guzzler... well, whatever. The thing is, the check engine light has been on almost constantly for about 9 months. The car runs fine, as always, without any issues or noticeable problems when the light is on.
The problem is that the workshop won't start working on it for less than €80, and the last two times they ran diagnostics (before my time), nothing came up (it's probably a loose connection). I don't want to waste any more money without getting any results.
I have an 'old' KKL interface for RS232 (like the one from the shop... a square box with a switch and 4 LEDs for DIY projects) and a new OBD cable from Rosstech, but unfortunately, the new cable doesn't support KKL. With the old interface, I can only test the communication or OBD support in the free VAGcom version. However, with the VAGcom version for the new cable, it seems not to work because of the missing K-line?
hat einer vieleicht ne Idee welche einfache gratis Software bei dem Hobel die Fehlercodes rausdrückt?? icon_smile.gif
Sincerely,
Marc.
Translated on 09-07-2026, 5:59.
Stummel
Post25-07-2011, 10:17    Subject: Peugeot 206 and the error memory. Quote
Hello.
Well, hu+au received the package three weeks ago. I guess that wasn't quite right, but whatever.
Due to my psychic abilities, I asked here about software that would allow me to 'get to the bottom of' icon_smile.gif the issue with my device... my VCDS doesn't work (it's partly shareware, partly a faulty cable...). } I understand that without an error message, it's clear that no one here can give me an answer... } but if I had one, I could probably fix the problem myself.
Sorry for the text, it's from my phone...
Huh?! Wasn't there a post here just a moment ago?? Oh well, it doesn't matter icon_smile.gif
Translated on 09-07-2026, 6:01.
Post25-07-2011, 10:28    Subject: Peugeot 206 and the error memory. Quote
The kit can support K1 and L/K2 lines, which isn't the problem. I think if anything is possible, it would be through OBD2. Check if version 409.1 is compatible with your hardware; I don't even remember if it already has the OBD2 button.
Translated on 09-07-2026, 6:02.
Karma: +1102 / -0   Thank you, like it!
Post25-07-2011, 10:33    Subject: Peugeot 206 and the error memory. Quote
"206 models produced after the 2004 facelift are OBD2 compatible. They can be identified externally by their clear headlights and other taillights, and internally by the thicker indicator, light, and windshield wiper stalks, as well as a flat, compact remote control for the radio. A simple controller from a hardware store is sufficient for reading the data. First, read the data, and then you can proceed."
Translated on 09-07-2026, 6:03.
Stummel
Post25-07-2011, 11:39    Subject: Peugeot 206 and the error memory. Quote
Hi there.
Okay. I thought the hardware might be able to do it... I tried with some 3.xx version, and it only tested the OBD functionality, which seemed okay... but I can't read any data. I'll try to get the RPOer today and see if that works... Is it possible to exchange the 'expensive' original Rosstech cables (without a K-line) for one with a K-line, perhaps with an extra charge?
Translated on 09-07-2026, 6:04.
Post25-07-2011, 12:17    Subject: Peugeot 206 and the error memory. Quote
Can the "expensive" original Rosstech cables without a K-line possibly be exchanged
Vendors are asking where you got the "original Rosstech cable" from.
Exchange at my place:
- if the goods are mine.
- if it has not been used at all, or hardly at all, meaning the condition is like NEW.
- if less than 3 months have passed since the purchase.
Upgrade to other hardware:
Please provide the details via private message/email, including the customer data.
Translated on 09-07-2026, 6:05.
Stummel
Post28-07-2011, 16:56    Subject: Peugeot 206 and the error memory. Quote
hiho
Okay, it took a while, but that sometimes happens... I've now got VAGCOM 409 and tried it again with the old adapter cable... Diagnostics on VW vehicles only work if I click the OBDII button; otherwise, I just get what's shown in the picture.
What's not working? Or why isn't it outputting anything anywhere? It seems like the OBD system itself is working, though?
Sincerely,
Marc.
 File size:  84.42 KB
 Viewed:  5714 times
Translated on 09-07-2026, 6:07.
Post29-07-2011, 18:32    Subject: Peugeot 206 and the error memory. Quote
This VAG-COM freeware from 2004 only checks whether OBD-2 would work.
It seems that only the later versions supported OBD-2. VCDS definitely supports it, though.
Der Sinn eine Freeware von 2004 zu supporten ist aber ganz sicher nicht gegeben. icon_wink.gif
If you want to proceed with OBD-2, click on the link at the bottom of the signature...
Translated on 09-07-2026, 6:08.
redzeck
Post16-04-2021, 20:36    Subject: Software for error code readers from other manufacturers Quote
I have a "VCDS/OBD2 diagnostic system KKL+CAN" from 2015, and I have been using it without any problems since then.
The adapter is labeled "HEX-USB+CAN".
Can I use this adapter to read the error codes from, for example, a Peugeot vehicle that uses OBD2?
And if it's possible, which program should I use for that?
Thank you and best regards, Michael.
Bagger versetzen Berge
Translated on 09-07-2026, 6:09.
Post16-04-2021, 20:41    Subject: Re: Software for error code readers from other manufacturers Quote
Thank you and greetings, Michael
You can try the OBD2 button in VCDS.
Translated on 09-07-2026, 6:10.
Karma: +647 / -0   Thank you, like it!
Post19-04-2021, 17:00    Subject: Peugeot 206 and the error memory. Quote
I tried it on a 206+ HDI, but it didn't work.
Translated on 09-07-2026, 6:11.
Post19-04-2021, 17:08    Subject: Peugeot 206 and the error memory. Quote
Thank you for your feedback! Knowing the year of construction would have been helpful.
redzeck
dieselschrauber likes this.
Post19-04-2021, 18:16    Subject: Peugeot 206 and the error memory. Quote
The same thing didn't work with the 2008/9 Peugeot 206.
"Once I find another program, I'll get back to you..."
Michael.
Translated on 09-07-2026, 6:12.
Post20-04-2021, 5:18    Subject: Peugeot 206 and the error memory. Quote
dieselschrauber wrote:
Rüdi wrote:
I tried it on a 206+ HDI, no luck.
Best regards, Rainer
It was from 2009.
Translated on 09-07-2026, 6:13.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post20-04-2021, 19:30    Subject: Peugeot 206 and the error memory. Quote
Hello everyone.
I've already tried this on a Renault Megane 1.9 dci, year 2005, and it didn't work. It also doesn't work on a Citroen C5 2.2 HDI, first series.
BMW, Alfa, Fiat, and Ford are all addressing issues related to emissions.
The French, or rather their cars, are probably somewhat "unique" and are not compatible with VCDS.
Even the universal testers, which cost around 50€, don't work with most French cars, although they can read and erase data from almost all other brands.
We need extra equipment for the 3 French cars, costing around €100. Google provides a good selection when searching for "OBD diagnostics Renault Peugeot."
Regards, Mpire.
Translated on 09-07-2026, 6:14.
No new posts Review and Installation: Kenwood KDC-DAB 4551U in a Peuge... Troubleshooting & Guides
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Peugeot 307: Specs, Problems & Common Issues On-Board Diagnostics (OBD)
No new posts Peugeot 807: Specs, Review & Price Diesel Engine Technology
No new posts Part number fuel injection pump Peugeot 1.9TD Diesel Engine Technology
No new posts Peugeot 306 HDI: Misfire & Hesitation (05/2000) Diesel Engine Technology
