Author
Message
abicim Joined: 11/26/2020 Posts: 23 Karma: +7 / -0 Location: FurtwangenPremium Support
30-11-2020, 19:13 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
Hello everyone,
I have a Golf 5, manufactured in 2006, and for some time now, I've been hearing a noise when the car is stationary.
During the ride, everything seems normal and there are no unusual sounds. What could it be?
Thank you in advance.
File size:
4.44 MB
Viewed:
1468 times
Your browser does not support the video element.
Translated on 26-10-2026, 21:35.
Profile PM
alevuz Schrauber Joined: 11/27/2011 Posts: 113 Karma: +32 / -0 Location: TirolPremium Support dieselschrauber likes this.
01-12-2020, 15:56 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
Hello...
Suspected ZMS failure ---- You can't press the clutch pedal with a DSG transmission, so doing so might make it quieter...
He's shaking quite a bit.
It's difficult to verify that with a DSG, unfortunately...
SG.
Manfred.
Touareg V10 TDI (AYH)
Profile PM
02-12-2020, 20:56 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
Is there an alternative to ZMS? Or can I be sure that the ZMS is defective?
Translated on 26-10-2026, 21:36.
Profile PM
Rüdi Profi-Schrauber Joined: 03/05/2005 Posts: 1514 Karma: +649 / -0 Location: Nord/Osthessen2001 Audi A4 Avant Premium Support dieselschrauber likes this.
06-12-2020, 10:19 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
Alternatively, the transmission, but that needs to be removed anyway.
Be prepared to potentially spend around 2000 euros if a repair shop gets involved.
Profile PM Garage
dieselschrauber Administrator Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen2018 Volkswagen T6
08-12-2020, 21:03 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
I'd like to check if the noise is still present when there's some torque applied to the drivetrain.
When starting uphill, use minimal gas. If the noise doesn't decrease, I wouldn't rule out other causes besides the dual-mass flywheel (DMF), such as tensioners and idler pulleys in the belt drive.
Just remove the engine cover; it's just clipped on.
Wie ist denn der Kilometerstand? Untuned engine?
Translated on 26-10-2026, 21:37.
Profile PM WWW Garage
abicim Joined: 11/26/2020 Posts: 23 Karma: +7 / -0 Location: FurtwangenPremium Support dieselschrauber likes this.
08-12-2020, 21:19 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
The noise is only present when the engine is idling, not when there is torque being applied.
Mileage: 162,000 km
Engine: Untuned.
Timing belt: replaced at 139,000 km.
Best regards, Orhan.
Translated on 26-10-2026, 21:38.
Profile PM
08-12-2020, 21:22 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
abicim wrote:
The noise is not present when there is torque, but only when idling.
Mileage: 162,000 km
Engine: Untuned.
Best regards, Orhan
Okay, then I'll focus on the powertrain.
Translated on 26-10-2026, 21:39.
08-12-2020, 21:23 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
Okay, so ZMS?
Profile PM
Hufe Schrauber Joined: 06/09/2015 Posts: 64 Karma: +22 / -0 Location: Bad Münstereifel2004 Audi A6 Avant Support dieselschrauber likes this.
10-12-2020, 9:21 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
Hi!
Based on the metallic "clanging" sound combined with the engine wobble, I also suspect a worn-out dual-mass flywheel (DMF).
Reason: I experienced the same issue with my 1.9 PD TDI. I ignored it (because it had 260,000 km on it) and ended up paying a high price. I broke down on the highway due to engine failure. The imbalance in the dual-mass flywheel (DMF) was so severe that the crankshaft broke after the second cylinder.
Used engine from a recycling center plus installation: 3500,-
Beste Grüße,
Hufe
Translated on 26-10-2026, 21:40.
Profile PM Email Garage
10-12-2020, 12:39 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
Do I need to pay special attention to the dual-mass flywheel (DMF) when replacing it in a DSG automatic transmission, or is it similar to replacing it in a manual transmission?
Translated on 26-10-2026, 21:41.
Profile PM
dieselschrauber Administrator Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen2018 Volkswagen T6 abicim likes this.
10-12-2020, 19:38 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
abicim wrote:
Do I need to pay special attention to the dual-mass flywheel (DMF) when replacing it in a DSG automatic transmission, or is it similar to a manual transmission?
If you want to do it yourself, I recommend getting the relevant repair manuals from Erwin.
Without a stage or pit in a heated workshop, it's unlikely to work out.
Translated on 26-10-2026, 21:42.
12-12-2020, 17:03 Subject: Golf 5 2.0 TDI DSG: Engine or Transmission Noise?
Quote
"Heating is overrated; it only works for me in the summer."
Profile PM Garage
