Two-Mass Flywheel: Testing & When to Replace
Martininii
Karma: +24 / -1   Thank you, like it!
Post11-01-2021, 0:30    Subject: Two-Mass Flywheel: Testing & When to Replace Quote
When is it better to replace a dual-mass flywheel rather than reusing it?
A Sachs clutch kit was installed in my car. Unfortunately, I can't find any documentation that specifies the permissible axial play or radial runout for the flywheel. On the Sachs website, I only found that the radial play should not exceed 6 teeth when the flywheel is rotated. Is that all there is to it? This is for a BLS engine.
The tipping angle is not specified at all; it is only mentioned that it may vary depending on the design.
https://aftermarket.zf.com/de/de/sachs/technik-in-der-praxis/praxis-tipps-fuer-werkstaetten/kupplungssysteme/zms-pruefen/
To put it in terms of "teeth," the play in my dual-mass flywheel is between 2.25 and 2.5 teeth. And there's a 2mm amount of play in the tilt.
Unfortunately, I couldn't find anything about that in this forum.
Caddy 3 mit BLS Motor, 105PS, DPF (0603/AGB)
Renault Laguna 2 mit F9Q Motor, 107PS/120PS (3004/158)
Translated on 13-09-2026, 23:56.
dieselschrauber and Herbert likes this.
Post11-01-2021, 8:19    Subject: Two-Mass Flywheel: Testing & When to Replace Quote
I think it's very difficult to make a clear statement about that.
The small radial play seems good at first glance. I don't know your mileage.
Given that it has already been installed for over 100,000 km, I would recommend replacing it, considering the mileage and the specific application.
"I once managed to drive over 380,000 km with the original clutch and dual-mass flywheel (DMF). The DMF was probably worn out since around 200,000 km, but then it failed quite suddenly... that made it clear."
The clutch still looked good. But when you have everything disassembled, you might as well replace it. I did it in the garage, over a pit. That made me want to only have to do that experience once X.
Translated on 13-09-2026, 23:58.
Karma: +649 / -0   Thank you, like it!
Post14-01-2021, 4:09    Subject: Two-Mass Flywheel: Testing & When to Replace Quote
Hi.
I also base my decision on the amount of work involved in changing the clutch, as well as the cost factor associated with the dual-mass flywheel (DMF).
For a Sharan/Galaxy with a 6-speed transmission, I would always replace it, regardless of its condition. However, if the transmission can be removed in a maximum of 2 hours, it might not be necessary to replace it.
Regarding durability, there are no clear statements; some fail after only 50,000 km, while others run perfectly fine with 500,000 km.
Translated on 14-09-2026, 0:00.
Martininii
dieselschrauber likes this.
Post14-01-2021, 9:04    Subject: Two-Mass Flywheel: Testing & When to Replace Quote
Well, in that case, it's usually best to install a new clutch kit. And if you need a workshop, that's even more important.
In my case, it's not really that expensive.
Thank you for the answers!
Translated on 14-09-2026, 0:01.
Post15-01-2021, 7:06    Subject: Two-Mass Flywheel: Testing & When to Replace Quote
Unfortunately, that's exactly the case, even though it goes against the idea of the forum. Due to the installation situation, it's ultimately better to replace everything at once...
No new posts Passat V157: How to Replace and Calibrate CBDC Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dual-Mass Flywheel: Benefits & Explained Diesel Engine Technology
No new posts Two-Mass Flywheel Error Images Diesel Engine Technology
No new posts Two-mass flywheel end of life Transmission, Chassis, Body & Interior
No new posts Defective Dual Mass Flywheel: Symptoms & Repair Diesel Engine Technology
