005769 - Data bus driver P1689 - 000, 049472 - Body control module
3bAFN
Karma: +33 / -0   Thank you, like it!
Post20-01-2021, 22:49    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
Hello everyone,
I'm having a problem with the aftermarket GRA (Gas Return Actuator) on my Polo; it's not working.
I measured the lever and also tested a second one that was definitely working.
The body control module starts with the code 6Q1, which means it must cooperate with the cruise control system.
I hadn't experienced this data bus error problem before.
Can someone help me or give me some tips on where to start looking for the problem?
Thank you.
Address 01: Engine Control Module
Label file: DRV\045-906-013-BMS.CLB
Control unit part number: 045 906 013 E. Hardware: 045 906 013 E.
Component and/or version: R3 1.4L EDC G000SG 4271
Encoding: 0003071
Operating number: WSC 52477 141 84266
VCID: 112FDB100B35770E95-514A
2 error codes found:
005769 - Data bus driver.
P1689 - 000 - Implausible message from the electronic central electrical system.
Environmental conditions:
Error status: 01100000
Error priority: 3.
Error frequency: 1
Lost Counter: 255
Mileage: 202,627 km
Time: 0
Speed: 0 RPM.
Speed: 0.0 km/h
Last: 0.0%
Voltage: 11.86 V
Binary value: 11101100
Binary value: 10000000
(no unit): 255.0
049472 - Body Computer 1 / Central Electronics.
U0140 - 000 - No communication.
Error priority: 3.
Error frequency: 1
Lost Counter: 255
Mileage: 202,627 km
Time: 0
Speed: 0 RPM.
Speed: 0.0 km/h
Last: 0.0%
Voltage: 11.86 V
(no unit): 0.0
Readiness: 0 0 0 0 1
Log-rgregrg.txt
 File name:  Log-rgregrg.txt
 File size:  2.17 KB
 Downloaded:  378 times
dieselschrauber likes this.
Post21-01-2021, 7:51    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
A vehicle scan is always the basic prerequisite here.
Since we don't know how and where you connected the cables to the electrical system, we might as well pull out our crystal ball. It would certainly be a good idea to carefully check all connection points and see if anything else was damaged during the work.
Then, once everything is correctly coded, it's quite simple to check the switch positions and button presses in the measured values.
Okay, let's continue.
3bAFN
Post21-01-2021, 8:11    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
Unfortunately, I can only provide the Autoscan results later tonight.
It includes a wiring harness from Kufatec, which was installed according to the instructions provided.
I unlocked the cruise control function in the engine control unit with the code 11463. This is also evident in the measurement data blocks of the control unit.
When checking the switch positions, only ON and OFF are recognized. Nothing else.
Sören
3bAFN
Post21-01-2021, 19:30    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
Here's the vehicle's diagnostic scan data.
Thursday, January 21, 2021, 6:25:32 PM: 23565
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: DRV 20.4.1.1
Data as of: 20200709 DS317.0
www.Ross-Tech.de
Vehicle Identification Number: WVWZZZ9NZ8Y219830 License Plate:
Mileage: 202,680 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
Mileage: 202,680 km
"Der schnelle braune Fuchs springt über den faulen Hund."
Label file: DRV\045-906-013-BMS.clb
Part number SW: 045 906 013 E HW: 045 906 013 E
Part: R3 1.4L EDC G000SG 4271
Revision: --H03--- Serial number: VWZ5Z0H3171058
Encoding: 0003071
VCID: 112FDB100B35770E95-512E
3 error codes found:
P1689 - 000 - Implausible message from the electronic central electrical system - Intermittent.
Error status: 00100000
Error priority: 3.
Error frequency: 1
Lost Counter: 255
Mileage: 202,627 km
Time: 0
Speed: 0 RPM.
Speed: 0.0 km/h
Last: 0.0%
Voltage: 11.86 V
(no unit): 255.0
Error priority: 3.
Error frequency: 1
Lost Counter: 255
Mileage: 202,627 km
Time: 0
Speed: 0 RPM.
Speed: 0.0 km/h
Last: 0.0%
Voltage: 11.86 V
(no unit): 0.0
001384 - Switch for GRA (E45)
P0568 - 000 - Implausible signal.
Error priority: 3.
Error frequency: 1
Lost Counter: 255
Mileage: 202,627 km
Time: 0
Speed: 0 RPM.
Speed: 0.0 km/h
Last: 0.0%
Voltage: 10.94 V
Binary value: 11000000
(no unit): 255.0
Readiness: 0 0 0 0 0
Address 03: Brake Electronics Label file: DRV\6R0-907-37x-ESP80.clb
Part number: 6Q0 907 379 AS
Component: ESP 8.0 front
H05 0003
Operating Number: WSC 00788 785 00200
VCID: 0E15C06C1A0B68F688-5168
Subsystem 1 - Part number: 6Q0 907 379 AS
H05 0003
No error codes found.
or error codes are not supported by the control unit.
or communication errors occurred.
Address 08: Climate Control/Heating Module. Label file: DRV\6Q0-820-045.lbl
Part number: 6Q0 820 045.
Component: Air conditioner X0850
VCID: 6ADDACFC1623E4D6B4-5168
"1 error found:"
65535 - Control unit defective.
00-00 - -
Address 09: Central Electronics
Label file: DRV\6Qx-937-049-B.lbl
Part number: 6Q1 937 049.
Component: ON-BOARD NETWORK SWITCH. 1S30
Encoding: 01038
Operating number: WSC 13765
VCID: 78F986B4588F464632-5168
"1 error found:"
00907 - Load Management Procedure.
35-00 - -
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 K
Part number: 17 AIRBAG VW51 0N 0011.
Encoding: 12599
Operating number: WSC 00788
VCID: 2C516AE4DC573AE686-5168
Address 17: Control panel module
Label file: DRV\6Q0-920-xxx-17.lbl
Part number: 6Q0 920 804 JX.
Component: VDO V08 COMBINATION INSTRUMENT.
Encoding: 01132
Operating number: WSC 37826
VCID: 1029DE14503F7E069A-5168
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 1S30
Encoding: 00014
VCID: 70E9BE9430FF1E06FA-514A
Address 25: Immobilizer
Label file: DRV\5J0-920-xxx-25.clb
Component: VDO V08 IMMOBILIZER.
Encoding: 01132
VCID: 1029DE14503F7E069A-514A
WVWZZZ9NZ8Y219830 VWZ5Z0H3171058
Address 44: Steering Assist
Label file: DRV\6Q0-423-156.clb
Part number: 6R0 423 156.
Part: Power Steering Unit - TRW - V272
Encoding: 10110
Operating Number: WSC 00000
VCID: 6DD7A7E027CDF3EED1-514A
Address 46: Comfort System. Label file: . DRV\6Q0-959-433.clb
Part number: 6Q0 959 433 G.
Component: 40 Comfort Devices 0002
Encoding: 00017
VCID: 3F8B2DA83D21B17E33-4B28
Address 56: Radio Label file: DRV\1K0-035-1xx-56.lbl
Part number SW: 6Q0 035 152 G, HW: 6Q0 035 152 G.
Component: Radio 9NK 0008
Revision: 00005000 Serial number: VWZ4Z4H1060528
Encoding: 0020200
VCID: 2E5560ECBA4B48F6A8-514A
End----------------------------(Duration: 04:06)-----------------------------
Post21-01-2021, 20:55    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
I suspect there's a faulty wiring issue. First, from the GRA lever's on/off switch.
Ich_Can_nix
Karma: +248 / -0   Thank you, like it!
Post22-01-2021, 1:48    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
It appears to be a faulty signal line.
Since the error only occurs sporadically, it could be a problem with the connection between the brake light switch and the engine control unit.
Pin A36 - when the ignition is on and the brake pedal is pressed, a voltage of 11-14 volts should be present.
Pin A 60, ignition on, brake pedal pressed = 0 volts.
The Polo was never available with GRA. Some engine control units (ECUs) are unable to process the brake pedal signal.
For some 1.2 and 1.4 models, the GRA (presumably a feature or function) can be activated, but it still doesn't work.
The problem is often the control unit. Possibly, the GRA (Gear Ratio Adaption) function still needs to be activated in the engine control unit.
Waved.
vag-driver
Post22-01-2021, 15:16    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
Your battery voltage is below 12.4V. I would fix that first.
Otherwise, as mentioned before, carefully check for errors in the work that has already been done. Another possibility is that the wiring harness is actually not properly assembled.
Andreas
3bAFN
Post24-01-2021, 14:53    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
Hello everyone,
I checked all the components today. The GRA switch is functioning exactly as it should. I tested everything using the XS3 connector on the BNS. Therefore, I can rule out a defect in the wiring harness.
I also measured the two CAN bus lines from the Body Control Module (BCM) to the Message System Gateway (MSG). Everything seems to be perfectly fine here as well.
The GRA switch, when in the ON position, also conducts electricity to the MSG (I don't know the exact pin right now), but when in the OFF position, no electricity flows.
I temporarily reinstalled the old BNS unit using parts with the 6Q2 part number. I can delete the errors, but they immediately reappear.
Post24-01-2021, 16:10    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
When the GRA switch is in the ON position, it also conducts current to the MSG
I would like to check if it a) directs to the correct pin and b) if the power supply is coming from the correct pin.
Specifically, based on my own experience, I would check to see if the connector was accidentally inserted in the wrong orientation (plugged in from the wrong side).
Ich_Can_nix
Post24-01-2021, 20:12    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
Good evening.
I agree with Rainer; it looks like some kind of wiring.
Can you really trace all functions (on/off, set, etc.) in the actuator diagnostics or based on the diagnostic trouble codes (DTCs)? That could significantly narrow down the possibilities regarding the wiring of the switch.
How did you transfer the coding data from the vehicle's control unit?
You converted from Basic 6Q2 to Medium 6Q1.
Perhaps you could double-check the encoding to see if everything was transmitted correctly.
I believe something else is also not quite right. You should take another close look at the coding icon_wink.gif 01038.
Have you replaced anything else, or just added the GRA (Gear Range Actuator)? Was the "control unit error - climate control" issue present before? Did you perhaps make a scan before you started installing the GRA?
3bAFN
Post24-01-2021, 22:59    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
Thank you for your responses.
I may have expressed myself poorly.
The entire system was checked for continuity using a multimeter. In the measurement blocks, I can only see ON, OFF, as well as clutch and brake functions. I don't see anything related to "Set," "Res," or other functions that are supposed to be controlled via the BNS (Bus Network System). Therefore, we are conducting a multimeter test to rule out any issues with the lever or the wiring.
I'm sure the cables are in the right place inside the plug. I have cross-referenced the pin assignments of the BNS.
I transferred the code 01038 from the originally installed 6Q2 to the 6Q1. Based on the VCDS information, I haven't found anything that needs to be changed in the coding.
The air conditioning malfunction has been happening before.
I am particularly concerned about data bus errors. Especially since they weren't there before, and they're also reappearing with the old 6Q2, even though I removed the GRA connector from the BNS.
Ich_Can_nix
dieselschrauber and Herbert likes this.
Post25-01-2021, 1:26    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
Good evening.
Your vehicle's body control module also functions as a gateway. Since the GRA was likely also activated when switching to the old control unit, there is also an error message in this case.
Did you disconnect the GRA connector from the body control module? The entire connector? The drive bus is connected to it! Then an error message should appear.
It's not easy to help you from a distance, so I'm just going to offer a few suggestions on how you might proceed.
If you haven't had any other errors besides the climate control unit, the potential sources of the problem can be relatively easily narrowed down.
1 Control unit.
2. Wiring harness.
3. GRA Lever.
I would like to decode the GRA signal and then see what other errors you might have.
Then, I would reinstall the old lever and disconnect the wiring harness. This would allow you to test whether the new control unit is working correctly. If you still have errors, it could be the new control unit. Then try the old version and check for errors.
If you no longer encounter any errors at a particular point, you start upgrading again.
I don't want to create any more problems for you, but please take a look at the coding aids in VCDS.
Software part number 6Q?-937-049-C and later:
+00001 = Attachment device installed.
+00002 = Rear hatch remote unlocking installed.
+00004 = Active electrical load management.
+00008 = Interior light control.
+00016 = Backrest detection system installed.
+00032 = Heated front seats installed.
+00064 = Heated windshield installed.
+00128 = heated exterior mirrors installed.
+00256 = Headlight wipers installed.
+00512 = Rain sensor installed.
+01024 = Rear hatch remote unlock pulse.
+08192 = Rear wiper with comfort function installed.
+16384 = Electric fuel pump relay installed.
If I'm not completely mistaken, the 01038 doesn't fit. I'm seeing a remote unlocking feature for the rear hatch in your vehicle icon_question.gif icon_exclaim.gif. I can't see that feature in your vehicle's configuration.
Perhaps one of the VCDS experts here could take a look and chime in if I'm wrong.
There were also engine control units in the Polo models that did not support the GRA (Gasoline Direct Injection) system. Specifically, there were issues with this regarding the 1.2L and 1.4L vehicles. If you inquire about it, you'll find out whether your control unit is affected.
https://www.vag-tuning.com/shop2/product_info.php?info=p177_audi-a2-1-2l-3l-tdi--gra-freischaltung.html&XTCsid=08d7e3ac3fbf24f411a4baca675365e3
Perhaps you could include another scan next time so we can see where we are with your issue.
Waved.
3bAFN
Post30-01-2021, 19:06    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
Hello everyone,
Thank you very much for all your tips and suggestions.
The solution to the problem was the vehicle's onboard computer.
Originally, a 6Q2937049F was installed, and I installed a 6Q1937049. However, not even the interval wiping function worked with this.
A 6Q1937049C is currently installed. "Everything works perfectly, except the illumination of the hazard light switch is noticeably brighter than with the 6Q2."
Best regards.
Sören.
Post31-01-2021, 16:18    Subject: 005769 - Data bus driver P1689 - 000, 049472 - Body control module Quote
Thank you for the feedback.
No new posts Document: Lack of power during cold starts with 2.5 engin... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fehler 18262 P1854 Datenbus Antrieb Hardware defekt On-Board Diagnostics (OBD)
No new posts Audi A8 Trailer Hitch Coding - Data Bus Error On-Board Diagnostics (OBD)
No new posts Data Bus Software Status Monitoring: Error 18263 On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Konzern Datenbus, Eindrahtbetrieb, Fehlercode 01336 (Gel�... On-Board Diagnostics (OBD)
