Audi A6 TDI Stuttering: VP44 Replacement Not a Fix?
Go to page: 1, 2  Next
Adel
Post08-07-2020, 11:25    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
To begin, I would like to briefly introduce myself.
I am 34 years old, I studied industrial economics, and I drive a fourth-generation Golf with a 2.5 TDI BDG engine, which currently has 275,000 kilometers on the odometer.
Regarding my issue:
About a month ago, my car suddenly started making a loud knocking noise. I had to stop and have it towed home.
Diagnosis: Faulty fuel injection pump. Error codes: "00550 Injection time control valve - Control difference - intermittent" and "00550 Injection time control valve - Signal error - intermittent".
A newly refurbished fuel injection pump was ordered, coded, installed, and dynamically adjusted. Afterward, the car ran "rough" and emitted smoke in the partial load range between 1500 and 2000 RPM.
At full load, there is no smoke, and the performance is relatively normal.
Okay, here's the translation:
"Then I removed all the injectors and had them cleaned. One of them was faulty. I repaired it, reassembled everything, but the engine still runs poorly, with no improvement. Of course, I also checked the camshafts, and they look fine!"
Now I'm at the point where I think the new ESP isn't working correctly. I'm going to remove it again and send it back to the company for inspection.
I'll keep you updated...
Has anyone ever experienced a similar problem? I haven't found anything comparable in the search results.
Translated on 27-09-2026, 13:35.
Post08-07-2020, 18:02    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Autoscan?
Please log the target value and the actual value from the start of the injection process, specifically in the area where it's not working correctly, and also beyond that point.
Translated on 27-09-2026, 13:38.
Adel
Post08-07-2020, 18:20    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Hi, do you happen to know which channels are available in the VCDS?
Alternatively, I have autocom and autodia (carport).
Greetings.
Post08-07-2020, 18:52    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Which channel do you see when you cycle through them, and how would I know if you were doing an automatic scan?
Guess measurement block 4 in the engine control unit...
Translated on 27-09-2026, 13:39.
Adel
Post08-07-2020, 21:50    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
So hab jetzt soll/ist vom Spritzbeginn geloggt. Wenn ich im Teillastbereich bei besagter Drehzahl fahre und der Motor stottert und raucht habe ich eine extreme Abweichung, ein Delta von ca 8°! Bei Volllast wo er ja auch gut geht so gut wie keine Abweichung. Was heißt das jetzt? ESP defect?
I'll submit the log tomorrow.
"LG" is an abbreviation for "Liebe Grüße," which means "Best regards" or "Best wishes" in English.
Adel
Post09-07-2020, 7:06    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Good morning, here's the log...
Einspritzbeginn SOLL_IST.csv.pdf
 File name:  Einspritzbeginn SOLL_IST.csv.pdf
 File size:  68.44 KB
 Downloaded:  523 times
Translated on 27-09-2026, 13:40.
Adel likes this.
Post09-07-2020, 19:04    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Is the timing belt tension correct? Strangely, the values are okay at higher RPMs...
Adel
Post09-07-2020, 19:07    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Do you mean the small or the large timing belt?
I suppose so...
Post10-07-2020, 8:14    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Check everything that drives the ESP system itself to see if anything is loose or if a pulley or guide roller is stuck.
Adel
Post10-07-2020, 8:25    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Okay, I will check all the timing marks on Saturday and see if anything is loose. The timing belt is 4 years old, and I've driven 70,000 km since it was replaced (just for your information).
Report back later.
Translated on 27-09-2026, 13:41.
Adel
Post14-07-2020, 6:20    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Good morning.
Slightly delayed, but there was no other way to do it given the timing.
Yesterday, we disconnected the motor: we positioned the motor at top dead center (TDC), inserted the mandrel from below, and disconnected the ESP (electrical spark plug) from the top.
After that, I removed the vacuum pump and took off the rear cover of the camshaft on the other side. The rulers/gauges wouldn't fit inside... I removed the camshaft gears, inserted the ruler/gauge, and reattached the camshaft gears.
Everything is assembled, but the car is still running just as poorly as before. I noticed that the gear (attached with 3 Allen screws) for the dynamic ESP adjustment seems to wobble slightly when the engine is running. However, the camshaft gear does not.
Could that be a possible cause?
We will also be checking the tension of the timing belt in the next few days; unfortunately, it was too late to do so yesterday.
What I also noticed is that, while it runs smoothly at higher RPMs, it doesn't seem to be delivering its full power; something is missing.
Translated on 27-09-2026, 13:43.
jarobaldu
Karma: +40 / -0   Thank you, like it!
dieselschrauber likes this.
Post15-07-2020, 10:41    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Then I would start by investigating the mechanical issue. Are the ESP brackets in good condition?
Best regards.
Adrian.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 27-09-2026, 13:44.
Adel
Post15-07-2020, 10:46    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
In the coming days, I will fix this imbalance in the gear and check the tension of the long timing belt.
I'll get back to you.
Best regards.
P.S. The ESP brackets are in good condition.
Translated on 27-09-2026, 13:45.
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
Post16-07-2020, 14:35    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Hello.
"My V6 also exhibits a somewhat wavy acceleration when using partial throttle. You can also notice it when coasting. There were absolutely no error codes in the diagnostic memory. The injectors look great. After a long search, I identified the mass airflow sensor. It indirectly determines the fuel injection amount."
Okay, please provide the German text you would like me to translate into English. I will provide only the translation.
Beste Grüße,
Hufe
Translated on 27-09-2026, 13:46.
Adel
Post16-07-2020, 17:20    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
The LMM reaches a value of 940 in third gear.
I also tried one from a different BDG (presumably a German organization), just to see, but it runs just as poorly...
I will remove these "burrs" from the camshaft sprocket in the coming days and check the timing belt.
"Lg" is a German abbreviation that stands for "Liebe Grüße," which means "Best regards" or "Warm greetings" in English.
Translated on 27-09-2026, 13:47.
Adel
Post22-07-2020, 10:14    Subject: Audi A6 TDI Stuttering: VP44 Replacement Not a Fix? Quote
Update:
Front panel removed and valve cover taken off.
The timing belt seems to be a little too loose, so it will be tightened.
We also noticed that some of the hydraulic lifters are very loose, so we're replacing them all. I'll report back again and hope that it runs correctly this time.
Translated on 27-09-2026, 13:48.
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Audi A4 B6 VP44 replaced, now showing code P1841 On-Board Diagnostics (OBD)
No new posts 1Z stutters Diesel Engine Technology
No new posts Ölkontrolleuchte leuchtet obwohl Öl vorhanden Electrical Systems, Vehicle Electronics, Multimedia
No new posts Octavia Starting Problems: ESP Repair Not the Issue? Diesel Engine Technology
