Passat 3B / ABS/ESP light on / Error code 00302
karlstein12
Post08-08-2021, 19:56    Subject: Passat 3B / ABS/ESP light on / Error code 00302 Quote
Hello everyone,
I have a "00302 Relay for solenoid valve (J106)" error code on my Passat 3B 1.9 TDI PD (manufactured in March 2000), and I'm not sure what to do.
Background:
A few weeks ago, I had a problem where the ABS/ESP system was activating unnecessarily when I was lightly braking. I then checked it with VCDS and found the error code "00597 - Wheel speed sensor signal inconsistent, sporadic."
I also noticed that the rear left wheel speed signal was fluctuating slightly.
To quickly get rid of the annoying rattling noise, I removed the fuse for the ABS system, and then the car could be driven normally (of course, with error messages and warnings displayed on the instrument panel).
Okay, so I fixed the sensor yesterday, and the signal is now working correctly, but the error 00302 is still appearing, along with corresponding warning messages in the control unit. (The original error 00597 is gone.)
The relay itself seems to be functioning correctly, and there is voltage present when the ignition is turned on.
I don't know how to proceed from here.
Do you see a connection between the two errors? Was driving without a safety device harmful?
Perhaps someone can help me.
Thank you in advance and best regards.
Rupert.
Translated on 06-07-2026, 15:08.
Post10-08-2021, 19:33    Subject: Passat 3B / ABS/ESP light on / Error code 00302 Quote
"Without a fuse, nothing can happen. Please post an Autoscan." Since the problem relates to ABS/ESP, I'm moving the topic to the relevant section.
Translated on 06-07-2026, 15:10.
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J ABS Light: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J up to week 38/2000, ABS control light is on. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P2002 Passat 2.0 TDI BMR Diesel Engine Technology
This topic is locked, you cannot edit or reply. P2563 Passat CC: Diagnose & Lösungen (2.0 TDI) Diesel Engine Technology
No new posts Passat Starting Problems: No Error Code, Help! Diesel Engine Technology
No new posts Passat V6 TDI Won't Start: Error Code 1044 Diesel Engine Technology
