Audi A8 Trailer Hitch Coding - Data Bus Error
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
matthias.stender
Karma: +9 / -0   Thank you, like it!
Post19-07-2021, 23:40    Subject: Audi A8 Trailer Hitch Coding - Data Bus Error Quote
I have installed a Westfalia trailer hitch and a vehicle-specific wiring harness on my Audi A8 4H2. Unfortunately, the fuse block No. 5, which is described in the wiring harness instructions as being located in the rear, is not present. Therefore, I made the connection to the first fuse block as required and obtained the remaining voltages from fuse blocks 4 and 6. I connected the bus line to the AHK (trailer hitch) control unit according to the instructions. The control unit is also correctly recognized, and I was able to adjust (almost) all of the AHK coding parameters, except for:
1) I can still correctly set the coding for the Gateway_19 (diagnostic interface) for trailers with the number 69.
"I am unable to set the EZE_09 electronic central electrical system control unit code because the provided access authorization code, 31347, does not work. Westfalia claims the code comes from Audi, and Audi claims it comes from Westfalia. The code also does not work on an A4 (supplied by JĂ€ger), for which it should be valid."
How do I obtain the necessary authorization to install a trailer hitch that complies with the "under 10 - adaptation and networking" regulations?
"Now, in addition, the bus no longer recognizes my entire optical data bus in the rear; I had to remove all the connectors and relays in the back to be able to properly connect the additional cables. However, the Westfalia "illiteracy" documentary isn't very good, so I hope I haven't made any mistakes."
What could cause a complete interruption of the entire optical data bus? Unfortunately, I can't identify which cable is connected to which control unit, or whether this could be a consequence of the incorrect coding mentioned above. Neither the MMI nor various other components (see scan) are working. The optical data bus shouldn't be affected by the additional connectors, unless I accidentally loosened a cable for the optical coupling of the data bus? It must be located in the rear, which is the only area that was open.
Here is the error message that seems most relevant to me:
Address 19: Diagnostic interface (J533)
Label file: * None
Part number SW: 4H0 907 468 AC, Part number HW: 4H0 907 468 AC.
Component: J533 -- Gateway H12 0037
Revision: -------- Serial Number: 00000000830005
Encoding: 00CD077D00
Operating number: WSC 02391 785 00200
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 72BC2752B42EAB2B897-8026
Battery monitoring control unit:
Subsystem 1 - Part number SW: 4H0 915 181 F, HW: 4H0 915 181 F.
Component: J367-BDM H08 0181
Serial number: 00000000001911022285
Voltage stabilizer:
Subsystem 2 - Part number SW: 8K0 959 663 C, HW: 8K0 959 663 C.
Component: J532_DCDCStab H05 0006
Serial number: 13044001407021200410
"One error found:"
0267 - Optical data bus.
U1049 00 [009] - Interruption.
confirmed - checked since last deletion
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 1.
Lost Count: 175
Mileage: 218,124 km
Date: 2021.07.18
Time: 04:30:35
Voltage at terminal 30: 12.5 V.
Voltage at terminal 15: 0.0 V.
Engine control unit temperature: 41 °C.
System status: Awake_Timer_active.
IN ESP_standstill flag: standstill detected.
Engine running: off.
IN ZAS_Te_X: from
Status, terminal 15, via CAN: off.
Status Terminal 15: off.
Data field: 0
And here is the complete VCDS scan:
Monday, July 19, 2021, 10:32:49:06315
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: DRV 21.3.0.0 HEX-V2 CB: 0.4543.4
Data as of: 20210314 DS325.0
shop.dieselschrauber.org
Vehicle Identification Number: WAUZZZ4H2DN026221
License plate: A-MS 537
Mileage: 218,150 km. Repair order: datac.
Vehicle type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 28 34 36 3B 3C 42
46 47 52 53 55 56 _ 62 69 6C 6D 6F 72 81 85 88 89 8B 8E 8F
90
Mileage: 218,150 km
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
06-Passenger seat adjustment -- Status: OK.
08-Climate control/heating unit -- Status: Error 0010 (A servo motor is stuck - this is a known issue).
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
13-meter distance rule -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Circuit board module -- Status: unreachable 0100
18-Heater -- Status: OK 0000
19-pin diagnostic interface -- Status: Error 0010.
28-Heating/Climate: Current status: OK.
34-Level regulation -- Status: OK.
36-seat adjustable passenger seat -- Status: OK 0000.
3B Sensor Electronics -- Status: OK 0000
3C Lane Change -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Soundsystem -- Status: unreachable 0100.
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: unreachable 0100.
5F-Information Selection. I -- Status: unreachable 0100.
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
6C Rear-view camera -- Status: OK 0000
6D tailgate -- Status: OK 0000
6F Comfort System II -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
81-Selector lever -- Status: OK 0000
85-Camera Controller -- Status: Error 0010.
88-Multicontour driver's seat -- Status: OK 0000
Front passenger seat with 89 multi-contour settings -- Status: OK.
8B Distance Rule 2 -- Status: Error 0010.
8E-Image processing -- Status: Error 0010.
Left-side 8F seatbelt pretensioner -- Status: OK.
90-degree belt tensioner, right side -- Status: OK.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module (J623-CDTA)
Label file: None.
Part number SW: 4H0 997 401
Part number HW: 4G0 907 401
Component: 3.0TDI EDC17 H40 0004.
Revision: 53H40---
Encoding: 0A2A401A056601020000
Operating number: WSC 42182 003 1048576
ASAM Dataset: EV_ECM30TDI0114H0997401 001004
ROD: EV_ECM30TDI0114H0997401.rod
VCID: 6A8C3F329CFE63EB317-803E
No error codes found.
Readiness: 0 0 0 0 0
Address 02: Transmission (J217) Label file: | DRV\0BK-927-156.clb
Part number SW: 4H1 927 158 BG, HW: 0BK 927 156 AG.
Component: 0BK 30 TDIRdW H16 1011
Revision: --H16---
Encoding: 000001
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_TCMALX51011 002018
ROD: EV_TCMALX51011_002_AU64.rod
VCID: 76B41B42D846B70BA5F-8022
Address 03: Brake Electronics (J104)
Label file: 4H0-907-379.clb
Part number SW: 4H0 907 379 E, Part number HW: 4H0 907 379 E.
Component: ESP PREMIUM H10 0352
Revision: -------- Serial Number: --------------
Encoding: 60E5A30006A7C500E300
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 3430E14A8EBAE51B5BB-8060
Address 05: Access/Startup Authorization (J393)
Label file: .DRV\8K0-907-064-05.clb
Part number SW: 4H0 907 064 CB
Part number HW: 4H0 907 064 CB
Component: BCM2 2.0 H33 0433
Revision: 00002001
Encoding: 05A72F46000000000000
Operating number: WSC 02313 785 00200
VCID: 6B823A3693847AE34A1-803E
Address 06: Front Seat Adjustment (J521)
Label file: None
Part number SW: 4H0 959 760 D, Part number HW: 4H0 959 760 D.
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000051858949
Encoding: 0018320000047201000001010101112131313333283333
VCID: 3430E14A8E3AE51B5BB-8060
Address 08: Climate Control/Heating (J255)
Label file: | DRV\4H0-820-043.clb
Part number SW: 4H0 820 043 K, Part number HW: 4H0 820 043 K.
Component: Climate control, 4 zones, H20 0130.
Encoding: 361101B83C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 2808053A427291FBE73-807C
"One error found:"
0137 - Defrost actuator motor for the right-side window.
B10D8 22 [009] - Upper limit exceeded.
confirmed - checked since last deletion.
Error priority: 3
Error frequency: 6.
Lost Count: 176
Mileage: 218,122 km
Date: 2021.07.18
Time: 04:20:16
Address 09: Central Electronics (J519)
Label file: .DRV\4H0-907-063-V1.clb
Part number SW: 4H0 907 063 CD, HW: 4H0 907 063 D.
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001510337
Encoding: 26002010C034AFE38B810007A0001D0C009CC30806010101800008406001
VCID: 6C80392A968A7DDB43B-8038
Subsystem 1 - Part number SW: 4H1 955 119 C, HW: 4H1 955 119 A, Label file: DRV\1KX-955-119.CLB.
Component: WWS641 121121 H35 0080
Serial number: 130205200703
Encoding: 0045F7
Subsystem 2 - Part number SW: 8K0 955 559 C, HW: 8K0 955 559 C, Label file: DRV\8K0-955-559.CLB.
Component: RLS H04 0003.
Serial number: 10312393
Encoding: 025523
Subsystem 3 - Part number: SW: 4H0 941 531, HW: 4H0 941 531.
Component: E1 - LDS H07 0044.
Serial number: 13 02 2013 00000193
Subsystem 4 - Part number SW: 4H0 907 705 K, HW: 4H0 907 705 C.
Component: EVLS-SG H08 0300
Serial number: WA104612000002734529.
Encoding: 020300
Subsystem 5 - Part number SW: 4H0 907 658, HW: 4H0 907 658.
Component: AQ_Hum_Sensor H03 0003
Serial number: EE48C496000000000001.
Address 10: Parking Assist 2 (J446) Label file: | DRV\4H0-919-475-7X2.clb
Part number SW: 4H0 919 475 AA, Part number HW: 4H0 919 475 AG.
Component: PARKING ASSIST ACC H01 0083
Revision: 11001001 Serial number: 61061305300203
Encoding: A90B02
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BE285EB128903370D-8024
Address 13: Distance Control (J428)
Label file: | DRV\4H0-907-561.clb
Part number SW: 4H0 907 561 B, Part number HW: 4H0 907 561 B.
Component: ACC3 H19 0410
Serial number: 00000000000000
Encoding: 7F04010201
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2A0CFF325C7EA3EBF17-807E
4 error codes found:
11264 - Sensor for automatic distance control.
C110B 49 [009] - Internal electronic fault.
[FAULT_UAR_NVK8_31]
Error priority: 7
Error frequency: 1.
Lost Count: 175
Mileage: 218,122 km
Date: 2021.07.18
Time: 04:23:38
Engine control unit temperature: 34 °C.
Voltage at terminal 15: 12.556 V.
Velocity_vehicle_reference: -0.01 m/s
Longitudinal acceleration (vehicle reference): 0.00 m/sÂČ
91648 - Functionality limited due to missing message.
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_BV_POSITION]
Sporadically - confirmed - checked since last deletion.
Error priority: 6
Error frequency: 1.
Lost Count: 216
Mileage: 218,150 km
Date: 2021.07.18
Time: 17:09:42
Control unit temperature: 40 °C.
Voltage at terminal 15: 14.328 V.
Velocity_vehicle_reference: 8.11 m/s
Longitudinal acceleration relative to the vehicle: -0.03 m/sÂČ.
92416 - Functionality limited due to received error value.
U1113 00 [009] - -
[FAULT_CIS_LRRS_FAIL]
Error priority: 6
Error frequency: 6.
Lost Count: 176
Mileage: 218,122 km
Date: 2021.07.18
Time: 04:20:17
Voltage at terminal 15: 12.122 V.
93440 - Functionality limited due to received error value.
U1113 00 [008] - -
[FAULT_CIS_VIDEO_FAIL]
Error priority: 6
Error frequency: 1.
Lost Count: 216
Mileage: 218,150 km
Date: 2021.07.18
Time: 17:09:40
Voltage at terminal 15: 14.261 V.
Velocity_vehicle_reference: 7.16 m/s
Longitudinal acceleration of the vehicle (relative to the vehicle's frame of reference): 0.81 m/sÂČ.
Address 15: Airbag (J234) Label file: | DRV\4H0-959-655.clb
Part number SW: 4H0 959 655 C, Part number HW: 4H0 959 655 C.
Component: Airbag
10.43 H43 0040
Revision: -------- Serial Number: 003JG00BXTUC
Encoding: 30314246323430303033554A304C34483053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 3634DB4298C6F70B65F-8062
Crash sensor for driver-side side airbag:
Serial number: 3575HRB400E50CQ0FHFB.
Crash sensor for side airbag, passenger side.
Serial number: 3585HRB400K50CQ0A8UJ
Rear side airbag crash sensor (driver's side).
Serial number: 3515JRB400250DEKJ0U6
Crash sensor for rear side airbag, passenger side.
Serial number: 3525JRB400450DEKM8VL
Crash sensor for front airbag, driver's side:
Serial number: 3554VRB401I50D5SBI8P
Crash sensor for front airbag, passenger side.
Serial number: 3564VRB401I50D5SFHBW.
Address 16: Steering wheel electronics (J527)
Label file: .DRV\4H0-953-568.clb
Part number SW: 4H0 953 568 G, Part number HW: 4H0 953 568 G.
Component: Steering module. Part number: H03 0005.
Revision: -------- Serial Number: 90815MBF0002N
Encoding: 00003C
VCID: 372AD6469F4C0E037E9-8062
Subsystem 1 - Part number SW: 4H0 951 528 A, HW: 4H0 951 528 A.
Component: E221 - MFL H08 0010
Serial number: 24 11 2012 A0129992
Address 17: Control panel module (J285)
Label file: | DRV\4H0-920-xxx-17.clb-SRI1
Part number SW: 4H0 920 930 M, Part number HW: 4H0 920 930 M.
Component: TDieRDWACC--- H50 0515
Revision: 34081076 Serial number: 658180213592036
Encoding: 138608001F440008000000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU64.rod
VCID: 3038ED5A7AA2D93B3F3-8064
Analog clock:
Subsystem 1 - Part number SW: 4H0 919 204 H, HW: 4H0 919 204 H.
Component: Analog clock D4 H05 0225.
Serial number: 2130206001597
Address 18: Auxiliary Heater (J364)
Label file: .DRV\8R0-265-105.clb
Part number SW: 4H0 265 105 E
Part number HW: 4H0 265 105 E
Component: Auxiliary heater, model H24 0260.
Revision: 66006006 Serial number: 20130131222726
Encoding: 5D1F01
VCID: 2410110A3EDA759BCBB-8070
Label file: * None
Voltage stabilizer:
"One error found:"
Error priority: 2
Error frequency: 1.
Lost Count: 175
Mileage: 218,124 km
Date: 2021.07.18
Time: 04:30:35
IN ZAS_Te_X: from
Data field: 0
Address 28: Heating/Climate control (E265) Label file: | 4H0-919-158.clb
Part number SW: 4H0 919 158 K, Part number HW: 4H0 919 158 K.
Component: Climate control vent H16 0121
Coding: 2100000000
ASAM Dataset: EV_AirCondiHeck 001039
ROD: EV_AirCondiRear.rod
VCID: 3828D57A92D2017B773-806C
Address 34: Level Control (J197)
Label file: .DRV\4G0-907-553.clb
Part number SW: 4H0 907 553 E, Part number HW: 4H0 907 553
Component: AIR DAMPER H17 0099
Encoding: 008003
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E04F3226096CFCB2DF-807A
Address 36: Seat adjustment for driver (J136)
Label file: None.
Component: MEM-FS H08 0153
Revision: AA000000 Serial Number: 00000051858819
Encoding: 00183B0000057201000001010101112131313333203333
Address 3B: Sensor electronics (J849)
Label file: None.
Part number SW: 4H0 907 637 K, Part number HW: 4H0 907 637 F.
Component: SARA 6D, Part Number: H02 0056.
Revision: -------- Serial Number: EJ1BPA7700KNGO
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372AD6469FCC0E037E9-8062
Address 3C: Lane Change
Label file: DRV\4G0-907-566-V1.clb
Part number SW: 4H0 907 566 A
Part number HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial Number: 6PZ 010 287-07
Encoding: 0010101
VCID: 2E04F3226C16CFCB2DF-807A
Subsystem 1 - Part number: 4H0 907 568 A.
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-27.
Subsystem 3 - Serial Number: 5F14.02.1300H02000AMS14909
Subsystem 4 - Serial number: S14909.
Address 42: Door electrical driver (J386) Label file: .4H0-959-793.clb
Part number SW: 4H0 959 793 R
Part number HW: 4H0 959 793 G
Component: TSG FA H06 0273
Revision: -------- Serial Number: 0000052468981
Encoding: 011F12005E00628202083013
Operating number: WSC 02312 785 00200
VCID: 48C8A5BAE2B271FB073-801C
Address 46: Comfort System (J393) Label file: .DRV\4H0-907-064-46.clb
Revision: 00002001 Serial number: 0300722069
Encoding: 011A0E2000B93485B320C7C42E03010F0000000000000000000000000000
Operating number: WSC 02311 785 00200
Subsystem 1 - Part number: 4H0 951 177.
Component: DWA sensor H01 0010.
Subsystem 2 - Part number: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501.
Subsystem 3 - Part number SW: 4H0 959 591, HW: 4H0 959 591.
Component: J245 PS50.030 H07 0006.
Serial number: WOO2016086.
Encoding: 901F00
Subsystem 4 - Part number SW: 4H0 947 135 G, HW: 4H0 947 135 G.
Component: Roof electronics H13 0080.
Serial number: A2013000000000679540.
Encoding: 010000
Subsystem 5 - Part number SW: 4H0 959 591 A, HW: 4H0 959 591 A.
Component: V252 PS010 H05 0005
Serial number: WOO1000W46H
Subsystem 6 - Part number SW: 3AA 962 243, HW: 3AA 962 243.
Component: GEB.F.Heckoef H12 0719
Serial number: 84346539
Address 47: Soundsystem.
unavailable
Address 52: Power door lock, front passenger side (J387) Label file: .4H0-959-792.clb
Part number SW: 4H0 959 792 H HW: 4H0 959 792 H
Component: TSG BF H06 0273
Revision: -------- Serial Number: 0000049219155
Encoding: 011F12005E00628202083002
Operating Number: WSC 30483 001 1048576
VCID: 3D26C46EBD702453A45-8068
Address 53: Parking brake (----)
Label file: DRV\4H0-907-801.clb
Part number SW: 4H0 907 801 F, HW: 4H0 907 801 A.
Component: EPB-4 H03 0013
Revision: -------- Serial Number: 00000000601746
ASAM Dataset: EV_ParkBrake 001027
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B02FA365384BAE30A1-807E
Address 55: Headlight Range Adjustment (J431) Label file: | DRV\8X0-907-357.clb
Part number SW: 4H0 907 357 B. Part number HW: 4H0 907 357 B.
Bauteil: ....LWR12.... H02 0010
Serial number: 130221-0002-008
Encoding: 11116F101002A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 2D06F42E6D90B4D3145-8078
Address 56: Radio.
unavailable
Adresse 5F: Informationselek. I.
unavailable
Address 62: Door electric, left/right (J388) Label file: .4H0-959-795.clb
Part number SW: 4H0 959 795 E, Part number HW: 4H0 959 795 E.
Component: TSG HL H06 0273
Revision: -------- Serial Number: 0000052263623
Encoding: 010F12004000628202083003
Address 69: Trailer (J345) Label file: .DRV\4H0-907-383-V1.clb
Part number SW: 4H0 907 383 C. Part number HW: 4H0 907 383 C.
Component: Trailer H12 0100
Revision: 5H001001 Serial Number: 00000461731745
Encoding: 0100000000000000
VCID: 2D06F42E6D10B4D3145-8078
Address 6C: Rear-view camera (J928)
Label file: * None
Part number SW: 4H0 907 428 A, Part number HW: 7P6 907 441 D.
Component: TopView H05 0150
Revision: 11001001 Serial number: 82330JF0072270
Encoding: 0208000001010000010102000000
ASAM Dataset: EV_CameraSystemTopViewAUDI 006025
ROD: EV_CameraSystemTopViewAUDI_005.rod
Address 6D: Rear door (----)
Label file: | DRV\4H0-959-107.clb
Part number SW: 4H0 959 107 AB
Part number HW: 4H0 959 107 M
Component: HDSG Module H11 0043
Revision: 10011001 Serial Number: 035300072
Encoding: 0210044001
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6E843322A0168FCB6DF-803A
Address 6F: Comfort System II (J773) Label file: * None
Part number SW: 4H0 907 412 Part number HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial Number: 000000098973
Encoding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 639252167BD432A3F21-8036
Address 72: Door electric, high, right (J389) Label file: .4H0-959-795.clb
Component: TSG HR H06 0273
Revision: -------- Serial Number: 0000052263907
Address 81: Selector lever (J587)
Label file: 3Y0-927-731.clb
Part number SW: 4H1 927 731 A, Part number HW: 4H1 927 731 A.
Component: GSM-LL H08 0083
Revision: 0L0D5015 Serial Number: SN130116 0172
ASAM Dataset: EV_GSM2x3Mono 001017
ROD: EV_GSM2x3Mono_AU64.rod
Address 85: Camera Control Unit.
unavailable
Address 88: Multi-contour driver's seat (J873)
Label file: * None
Part number SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00009474314402.
Encoding: 662FF2
ASAM Dataset: EV_IVBDriveSideFrnt 001003
ROD: EV_IVBDriveSideFront.rod
VCID: 2F3AEE26679CC6C3269-807A
Address 89: Multi-contour passenger seat (J872)
Label file: * None
Serial number: 00009474205902
Encoding: 262FF2
ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8B: Distance Regulation 2.
unavailable
Address 8E: Image Processing.
unavailable
Address 8F: Left seat belt pretensioner.
unavailable
Address 90: Right seat belt pretensioner.
unavailable
End --(Duration: 02:46, Battery Voltage Start/End: 14.4V/12.9V. Voltage Drop: 0.0V)----
Fehler sind dafĂŒr da nur einmal gemacht zu werden
Translated on 27-08-2026, 17:49.
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
dieselschrauber likes this.
Post20-07-2021, 1:39    Subject: Audi A8 Trailer Hitch Coding - Data Bus Error Quote
Hello Mathias,
To encode the AHK on the A8, the correct CODE 20113} for control unit 09 must be used.
Please check if your installation instructions are for the MLB platform. There are several things to consider regarding the coding, especially for vehicles with features like camera systems and adaptive cruise control.
The optical data bus is quite easily damaged; even a small bend in the fiber optic cables can cause it to stop working properly.
Check the plug where you were connected to see if the cable is bent or damaged.
Michael.
matthias.stender
Post20-07-2021, 8:43    Subject: Audi A8 Trailer Wiring Coding - Fault Diagnosis Quote
Thanks, Michael. The unlocking code worked – it's also displayed in the current VCDS version. I should have been able to see that myself – sorry about that!
But the ring break diagnosis likely reveals my problem:
Control unit Electrical Optical
Diagnosis interface: OK. Error: None.
Information selection. I. I.O. I.O.
Control panel insert: OK.
Radio: OK
Soundsystem Error Error
The diagnostic interface has a fault in the optical data transmission. I had to really struggle to get the fuse holders out from the back and rewire them.
I have a control unit with thick yellow cables located to the left of the fuses, which seems to connect to the MMI. Or, where is the connection for the diagnostic interface located?
If it's the blind plug to the right of the fuses, that's where I have the trailer hitch control unit plugged in, but it doesn't have a glass fiber connection.
I've attached two pictures that illustrate the scenario.
Best regards, Matthias.
 Habe den Bereich rot umrandet
 File size:  2.14 MB
 Viewed:  4210 times
 Hier musste ich das AHK SteuergerĂ€t zusĂ€tzlich auf den Bus einpinnen
 File size:  1.44 MB
 Viewed:  2528 times
Translated on 27-08-2026, 17:51.
Ich_Can_nix
Post20-07-2021, 22:31    Subject: Audi A8 Trailer Hitch Coding - Data Bus Error Quote
Hello Matthias,
In your error scan, the radio is not accessible. Your sound system has an error on the MOST bus.
If the error didn't exist before, it's definitely related to your work.
If I interpret your photo correctly, the central control unit for the comfort system is located above the fuses. Behind that is the radio! Since you said you were "messing around" with it quite a bit, I would look for the problem there. The MOST bus is also located near the radio.
A slight kink in the fiber optic cable is enough to cause it to malfunction, even if a red light is still visible at the end of the cable. Using a test plug, you can disconnect the device from the bus and check whether the radio itself is faulty or if the cable is the problem.
What limitations or errors are currently present in the vehicle?
Can you please clear all the errors again and then display the scan results with the current errors?
Michael.
Translated on 27-08-2026, 17:54.
matthias.stender
Post21-07-2021, 8:58    Subject: Audi A8 Trailer Hitch Coding - Data Bus Error Quote
Hi Michael, the scan you requested is currently showing no errors after I cleared all previous errors and re-initialized all the AHK components. If the radio is located behind the fuse box (the Bose unit is on the left side and is also connected via fiber optic cable to the MOST system), I can try disconnecting and re-checking it. I haven't actually accessed the radio yet, as it's located behind the fuse box. The radio is showing "OK" in the ring break diagnosis.
"However, the diagnostic interface is electrically okay, but there are visual errors. The entire sound system is completely faulty. Everything related to the MMI is not working – from the camera to the ACC, radio, media, navigation, and even the climate control/rear sensors, because the sound system is neither electrically nor visually accessible."
Control unit / Electronic control unit (ECU) - Electrical, Optical.
Diagnoseinterface i.O. Error.
Informationselek. I i.O. i.O.
Control panel insert, OK. OK.
Radio: OK, OK.
"Where is the optical input located on the diagnostic interface? Knowing its location would help me systematically troubleshoot this. Where can I find a schematic diagram or wiring diagram? That would definitely make things much easier."
Thank you, Matthias.
Translated on 27-08-2026, 17:57.
matthias.stender
Post21-07-2021, 11:15    Subject: Easy Fix: Simple Solution to Your Problem Quote
Oh crap... it was so easy...
The top fuse on Pack 6, which is brown and rated at 30A, was blown. Unfortunately, reality didn't match the instructions, and I noticed this by comparing it to the pictures I took beforehand.
That was the fuse for the radio/sound system receiver. Without it, the MMI (Multi Media Interface) and the camera, as well as the ACC (Adaptive Cruise Control), etc., won't work.
At least, after that, the radio and navigation system immediately started working again.
However, I'm still encountering an error, and I can't activate any settings or the heated seat function in the MMI.
5F-Information Selection. I -- Status: Error 0010.
Address 5F: Information selection. I (J794)
Label file: .DRV\4E0-035-6xx-5F.clb
Part number SW: 4H0 035 670 P, HW: 4H0 035 670 N.
Component: H-BNT-EU H45 0798
Revision: -------- Serial Number: 179B%0D7508266
Encoding: 020100000001FBEF75B88B1E00000003080001000000000000
VCID: 313EE85E7128D03330D-8064
Subsystem 1 - Part number: 8R0 060 884 FC
Component: EUR 2018 2601
Subsystem 2 - Part number SW: 4H0 919 604 G, HW: 4H0 919 604 G.
Component: DU8 D4 SV NB H48 0021
Serial number: AUZ8ZDCC9004W9.
Subsystem 3 - Part number SW: 4H1 919 600 H, HW: 4H1 919 600.
Component: E380 BDT D4 H09 0065
Serial number: 00000000105404
Subsystem 4 - Part number: 8R0 060 961 E
Component: CD Database 4949.
2 error codes found:
03157 - Functional impairment due to communication disorder.
000 - -
Error status: 01100000
Error priority: 6
Error frequency: 22
Lost Count: 176
Mileage: 218,157 km
Time: 0.
Date: 2021.07.20
Time: 17:14:54
Binary value: 10111111 11101010
Binary value: 10001100 10001111
Binary value: 00000000 00000110
Binary value: 00000000 00000000
03278 - Functionality limited due to missing message.
000 - -
Error priority: 6
Error frequency: 1.
Lost Count: 176
Mileage: 218,157 km
Time: 0.
Date: 2021.07.20
Time: 17:14:37
Binary value: 00000000 00010000
Translated on 27-08-2026, 18:04.
matthias.stender
Post21-07-2021, 13:35    Subject: Problem Solved: No More Errors! Quote
I've re-checked the list of installed components, turned off the car, and let it sit for an hour. Afterward, all the errors were gone, and I was able to clear the remaining warning message, which hasn't reappeared. Thank you for your help!
Matthias.
Translated on 27-08-2026, 18:10.
Post21-07-2021, 19:17    Subject: Audi A8 Trailer Hitch Coding - Data Bus Error Quote
Thank you for the feedback.
Translated on 27-08-2026, 18:11.
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Question about Jaeger E-Satz Coding Audi A6 4F On-Board Diagnostics (OBD)
No new posts Cross Acceleration Sensor Error 058 F - Fix On-Board Diagnostics (OBD)
No new posts High-pressure generator (G65) 009 - Ground interruption/s... Transmission, Chassis, Body & Interior
No new posts Data Bus Software Status Monitoring: Error 18263 On-Board Diagnostics (OBD)
